Osram Lightify Tunable White Bulb - Default Settings when powered on
The Osram Lightify android app has this neat feature of changing the default dimmer level and color temperature to the bulb. So, when the bulb is power-cycled, it retains this setting instead of using the default dimmer level of 100% and color temp or 2700K. However, since I am using the bulbs with SmartThings, I have to reset the bulbs to pair them to the ST hub. From the SmartThings app, I don’t see such a feature to change this default dimmer level and color temperature setting.
Will SmartThings enhance the android app to include this neat feature?
Thanks.
Jace
Have you had any luck locking in the default dimmer and color temp? Luckily I saw your comment here before I bought any of these myself. I like the idea, but the utility seems limited without the ability to set the default.
