OSRAM Lightify RGBW Bulbs a NO NO
Is there anyway that I can make my osram lights cycle threw colors using the ST hub? I have 10 bulbs and one outdoor led strip that I would like to be able for them to cycle threw colors automatically or even change colors if something triggers them
Sure you can as long as the app supports it - I use CoRE to do that in an alarm state as an example …
I am new to Smartthings and have been lurking in these forums for a little while, but I recently came across an issue that I’m hoping someone can help me out with. I have an Osram Lightify RGBW light bulb about 35-40’ away from my hub and through maybe 2 walls. When I am in the Smartthings app under Things and tap to either turn it off or turn it on, it turns on or off, but then gets stuck in reporting its state as either “Turning On” or “Turning Off”. It is not changing from “Turning On” to “On” or “Turning Off” to “Off”. Does anyone have any suggestions as to what may be going on and possibly a way to fix it?
It doesn’t seem like it would be a range issue given that it executes the command, but doesn’t correctly report it’s state, but I could be wrong (it’s been known to happen). I have an Osram Lightify RGBW bulb between it and the hub. If it is a range issue would the bulb in between act as a repeater?
Thank you so much, in advance, for any assistance you can provide.
Is this something that could be mitigated if I had the Osram Hub/Gateway?
Hi, did you solve this problem? I have the issue.
Regards Jon
I also have the issue. Perhaps they need to be upgraded to the latest firmware, but I don’t have access to an Osram hub to be able to do this yet.
@Brandon_Griffin @sherb003
I haven’t been using the Osram bulbs long (about a fortnight) and the first couple days I couldn’t get them to function in a consistent manner. However, my issues have been abated by getting the Osram Hub, upgrading to the latest F/M in the Osram app (this will take maybe 5-10 minutes for the Hub to upgrade itself and about 5 minutes per bulb, which happens in a linear order so be prepared for a long wait if you have numerous bulbs), next in the Osram app perform a System Reset in the Settings. After the System Reset is done unplug the Osram hub and the bulbs will be in pairing mode when you toggle your light switch. Add the bulbs to ST and that should get rid of most issues. If you are still not happy after that then some other suggestions to try would be tinker around with some DTHs for the bulbs, and try rebuilding the ZigBee mesh.
Summary: Get Osram hub, update F/M, perform System Reset in Osram app, add bulbs to ST
The hubs are on clearance ($21) and lights are “on sale” at Menards. I got a starter kit ($36) to get another bulb and then after I upgraded the F/M on all my bulbs I set the hub up at my parent’s house because my Mom wanted the garden lights and they don’t have a ST yet.
I ended up getting the starter kit (Lightify Gateway and bulb for $29.99 at Lowes). I updated the firmware, and now they work perfectly! Thanks for the help. I too now recommend updating the firmware. Huge difference.
Anyone know how to update the firmware without the gateway. Supposedly this was supposed to be a feature of the new St firare that we just got.
My bulbs work fine but the preset colors leave a lot to be desired. However if you select the colors yourself in the ST app you ARE able to get rich colors. Dare I say, the colors are pretty close to my Philips hue v3 bulbs. But only by selecting the color from the pallet manually.
My OSRAMs all got the new firmware. I also do not have a hub, direct connect to ST. I just had to enable FW updates on my hub, which I’d done a while ago. Then in each OSRAM device in My Devices in IDE I just clicked Check Now in the Firmware section. Shortly, they displayed a new target. One updated right away, one took it’s sweet time. But they got there.
Do you enable FW updates in the ide or in the ST app?
How do you control the colors? Found any apps that can control them better?
If only there was a way to control them alongside my hue lights in the many different apps that it has available.
In IDE, My Hubs, View Utilities. I control anything in my system using CoRE, so I’m not really familiar with what other smartapps are out there!
Thanks I just did that. However when I clicked the option to “Allow OTA” it says “selecting this option will allow the hub to provide ZigBee OTA firmware updates (excluding lights).” What’s that all about? Nonetheless I still checked the Firmware version in each device and my Tunable whites were already up to date and after clicking the “Check Now” the RGBW’s updated as well.
Not trying to hijack this thread but instead of making a new one I figured everyone already involved in this one could benefit from this. I am in no way a developer of any sort but find myself tinkering with things often. On my quest to find the best color settings with these bulbs I was hoping someone with code writing knowledge could help out. So as stated before I think that the preset colors in the “ZigBee RGBW Bulb” device type could be much better for these bulbs. So as I switched through the different colors I watched The Live Logging from my hub to see what the setting were. This is what I found for each
Preset colors
Yellow setColor([red:255, hex:#FFEE1C, saturation:89.01961, blue:28, hue:15.418503, green:238, alpha:1.0])
Orange setColor([red:255, hex:#FFAD24, saturation:85.882355, blue:36, hue:10.42618, green:173, alpha:1.0])
Purple setColor([red:145, hex:#9113FF, saturation:92.54902, blue:255, hue:75.56497, green:19, alpha:1.0])
Red setColor([red:255, hex:#FF0222, saturation:99.21568, blue:34, hue:97.89196, green:2, alpha:1.0])
Green setColor([red:154, hex:#9AFF28, saturation:84.31373, blue:40, hue:24.496124, green:255, alpha:1.0])
Blue setColor([red:83, hex:#53A3FF, saturation:67.45098, blue:255, hue:58.914726, green:163, alpha:1.0])
Violet/Pink setColor([red:216, hex:#D812FF, saturation:92.94118, blue:255, hue:80.59072, green:18, alpha:1.0])
Then, I found what I thought was the best setting for each color and noted them as well.
My colors
Yellow- NO big difference
Orange setColor([red:255, hex:#FF9B08, saturation:96.86275, blue:8, hue:9.919028, green:155, alpha:1.0])
Purple- no big difference, Preset isn’t that bad.
Red setColor([red:255, hex:#FF0D01, saturation:99.60784, blue:1, hue:0.78740156, green:13, alpha:1.0])
Green setColor([red:4, hex:#04FF15, saturation:98.43137, blue:21, hue:34.462147, green:255, alpha:1.0])Blue setColor([red:1, hex:#0107FF, saturation:99.60784, blue:255, hue:66.272964, green:7, alpha:1.0])
Violet/Pink setColor([red:255, hex:#FF0457, saturation:98.43137, blue:87, hue:94.48871, green:4, alpha:1.0])
Next I scanned the “ZigBee RGBW Bulb” device type template for where these presets were coming from but don’t see anything. Granted I’ll admit I don’t know what I’m looking for.
I also did this same thing with my Philips Hue bulbs (which use the “Hue Bulb” device type) and the presets were the same but they had additional dialog’s of setting after the same ones that I noted above. This leads me to believe that their device types have additional setting in it.
Anyways, anyone with the know how mind helping us out with this in order to get the best colors from our bulbs? I’ll keep tinkering with it in the meantime but appreciate all the help I can get.
Surely these presets are configured in the Color Control Tile definition. However, I don’t know how to extend the core tile definitions (or if this even possible). Anyone know?
As an update to these bulbs, I eventually did have some success.
I now know that the dimmer switches these lights were connected to were causing issues in the fact that the dimming action seemed to confuse the bulbs, sometimes resetting them when the dimmers were turned on and off. With my setup now which works fine, I swapped the dimmer switches with z-wave on / off switches, and renamed these to switch instead of light, and name the bulbs to light; I also removed the switch from all routines so the switch side is left on all the time, and the light is controlled directly by the bulb. Now when the alarm goes off they change to red, when my mail arrives they change to green and so on. The only issues I have now is Zigbee still seems less reliable than Z-wave, and Smartthings still does not have a Local Handler for any RGBW light type weather Zigbee or Z-wave which is now the weak link in my local control setup.
Ive had nothing but problems… 13 bulbs, all outdoor in my soffits. Hard to update firmware, got the gateway… that made that easier.
But getting them to turn off/on / colors regularly sucks. Its like the hub has a very limited range… just super depressing.
With these bulbs directly to ST, its better, but still not reliable.
For instance, if i turned 13 bulbs blue, 11 would change, next time, 12, next time 10, etc. I just cant seem to get any consistency out of them
I have several OSRAM Lightify bulbs, a mixture of RGBW and tunable white. All have worked fine except for one. The one problem is an RGBW bulb. I’ve tried several solutions: on/off reset has never worked; removed it from all smartapps and then removed the device from ST; left it powered off for several days, removed it from all smartapps and from ST, the powered it back on and added it. I’ve tried each of these several times over the past three months and none of them work. The bulb will work for a few hours then stops working.
No matter what state the bulb is in, when it does work for a few hours, it will switch itself on and set its color to white. It will then show “unavailable” in ST and will not respond to any commands from the app. Also, the firmware is up to date along with the rest of my bulbs.
I’ve contacted Sylvania support a few days ago and there has not been any response. I’m sure the bulb is defective but it would be nice to get a response from the company.
I have a Lightify that just dies to and cannot get it to work again. On a plus note, Smartthingss recently pushed out a new handler so all Lightify (Zigbee RGBW) bulbs are now local control. However I still have some bulbs that do not want to update or for some reason go offline for no reason.
I just purchased two RGBW A19 bulbs, and after getting them connected to SmartThings hub they seemed to work with my motion routines during the first day. Then they started acting up. Í watch the SmartThings log which reports that the motion routine turned the bulb on, and even the SmartThings app is showing the bulb on, BUT IT’S NOT! Very bad behavior between these two manufactures. Funny thing is that when I tap the bulb in the SmartThings app as it thinks it’s on, the bulb goes on, and then turns off since it thought it was already on.
Update: It seems that the motion routine will turn the color A19 bulb on when a second motion activation happens right after the first motion has stopped. Strange.
It’s a very pricy mistake to even purchase these bulbs because of the lack of compatibility support from both Samsung and Sylvania out of the box!
From what I’m gathering from this thread, it seems the bulbs apparently need a firmware update to make them more reliant and compatible with SmartThings. But, the SmartThings hub won’t update them which is very sad. Why would Samsung even list these as compatible or even sale them on their website without any mention of needing to have the Sylvania hub to update firmware.
Samsung should remove these bulbs from there website until they actually support them out of the box since this is a very bad experience for customers.
Seriously Samsung, I’m sitting here on Christmas day posting this on your website, so ba’ humbug to Samsung this year!
You can update the Lightify bulbs through the ST IDE. They should update automatically.
I have been using Lightify bulbs for a year or so and have had very few problems.
