Pole mounted LED light with stake, runs on what appears to be 15v. Looks like: Garden Pole Image
Works with SmartThings straight out of the box, seen as another ZLL RGBW Bulb much like the rest of the gear. Not played around with any custom DTH or Apps yet but imagine they work similar to the mini spots.
Each pole is about 36cm high. The factory bought run is about 8.5m plus a long power cable, you can extend as per mini spots. Shipping in EU with a Schuko\Euro style sealed power supply, use an adaptor inside weather sealed box if you need to convert.
It gives decent light, I’ll be trying out the Garden Hue app with it later on.
