Gaining on it. Found a diff device handler, see below. Switch is now connected to ST.
The problem I have now is both buttons work the same. MY old system I could program each button to control diff items.
Handler that is working for me:
metadata {
definition (name: “OSRAM Lightify Dimming Switch”, namespace: “motley74”, author: “Michael Hudson”) {
capability “Actuator”
capability “Battery”
capability “Button”
capability “Configuration”
capability “Refresh”
capability “Sensor”
attribute "zMessage", "String"
fingerprint profileId: "0104", deviceId: "0001", inClusters: "0000, 0001, 0003, 0020, 0402, 0B05", outClusters: "0003, 0006, 0008, 0019", /*manufacturer: "OSRAM", model: "Lightify 2.4GHZZB/SWITCH/LFY", */deviceJoinName: "OSRAM Lightify Dimming Switch"
// simulator metadata
simulator {
// status messages
// UI tile definitions
tiles(scale: 2) {
standardTile(“button”, “device.button”, width: 6, height: 4) {
state “default”, label: “”, icon: “st.unknown.zwave.remote-controller”, backgroundColor: “#ffffff”
valueTile(“battery”, “device.battery”, decoration: “flat”, inactiveLabel: false, width: 2, height: 2) {
state “battery”, label:’${currentValue}% battery’
standardTile(“refresh”, “device.button”, decoration: “flat”, width: 2, height: 2) {
state “default”, label:"", action:“refresh.refresh”, icon:“st.secondary.refresh”
main “button”
details([“button”, “battery”, “refresh”])
// Parse incoming device messages to generate events
Map map = [:]
log.debug “parse description: $description”
if (description?.startsWith(‘catchall:’)) {
// call parseCatchAllMessage to parse the catchall message received
map = parseCatchAllMessage(description)
} else if (description?.startsWith(‘read’)) {
// call parseReadMessage to parse the read message received
map = parseReadMessage(description)
} else {
log.debug “Unknown message received: $description”
//return event unless map is not set
return map ? createEvent(map) : null
def configure() {
log.debug “Confuguring Reporting and Bindings.”
def configCmds = [
// Bind the outgoing on/off cluster from remote to hub, so the hub receives messages when On/Off buttons pushed
“zdo bind 0x${device.deviceNetworkId} 0x01 0x01 0x0006 {${device.zigbeeId}} {}”,
// Bind the outgoing level cluster from remote to hub, so the hub receives messages when Dim Up/Down buttons pushed
"zdo bind 0x${device.deviceNetworkId} 0x01 0x01 0x0008 {${device.zigbeeId}} {}",
// Bind the incoming battery info cluster from remote to hub, so the hub receives battery updates
"zdo bind 0x${device.deviceNetworkId} 0x01 0x01 0x0001 {${device.zigbeeId}} {}",
return configCmds
def refresh() {
def refreshCmds = [
zigbee.readAttribute(0x0001, 0x0020)
//when refresh button is pushed, read updated status
return refreshCmds
private Map parseReadMessage(String description) {
// Create a map from the message description to make parsing more intuitive
def msg = zigbee.parseDescriptionAsMap(description)
//def msg = zigbee.parse(description)
if (msg.clusterInt==1 && msg.attrInt==32) {
// call getBatteryResult method to parse battery message into event map
def result = getBatteryResult(Integer.parseInt(msg.value, 16))
} else {
log.debug “Unknown read message received, parsed message: $msg”
// return map used to create event
return result
private Map parseCatchAllMessage(String description) {
// Create a map from the raw zigbee message to make parsing more intuitive
log.debug msg
switch(msg.clusterId) {
case 1:
log.debug ‘BATTERY MESSAGE’
break
case 6:
def button = (msg.command == 1 ? 1 : 2)
Map result = [:]
result = [
value: ‘pushed’,
data: [buttonNumber: button],
descriptionText: “$device.displayName button $button was pushed”,
isStateChange: true
log.debug “Parse returned ${result?.descriptionText}”
return result
break
case 8:
switch(msg.command) {
case 1: // brightness decrease command
Map result = [:]
result = [
value: ‘held’,
data: [buttonNumber: 2],
descriptionText: “$device.displayName button 2 was held”,
isStateChange: true
return result
break
case 3: /* brightness change stop command
def result = [
value: ‘released’,
data: [buttonNumber: [1,2]],
descriptionText: “$device.displayName button was released”,
isStateChange: true
log.debug “Recieved stop command, not currently implemented!”
//return result
break
case 5: // brightness increase command
Map result = [:]
result = [
value: ‘held’,
data: [buttonNumber: 1],
descriptionText: “$device.displayName button 1 was held”,
isStateChange: true
return result
break
//obtained from other examples, converts battery message into event map
private Map getBatteryResult(rawValue) {
def linkText = getLinkText(device)
def result = [
value: ‘–’
def volts = rawValue / 10
def descriptionText
if (rawValue == 0) {
} else {
if (volts > 3.5) {
result.descriptionText = “${linkText} battery has too much power (${volts} volts).”
} else if (volts > 0){
def minVolts = 2.1
def maxVolts = 3.0
def pct = (volts - minVolts) / (maxVolts - minVolts)
result.value = Math.min(100, (int) pct * 100)
result.descriptionText = “${linkText} battery was ${result.value}%”
return result
