I think the errors might be giving us trouble. I didn’t give you very good directions about the parseDescriptionAsMap() part, so here’s the code adjusted a little.
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
/* OSRAM Lightify RGBW Bulb
Capabilities:
Actuator
Color Control
Configuration
Polling
Refresh
Sensor
Switch
Switch Level
Custom Commands:
setAdjustedColor
metadata {
definition (name: "OSRAM Lightify Zigbee RGBW Bulb", namespace: "guy_mayhew", author: "Guy Mayhew") {
capability "Switch Level"
capability "Actuator"
capability "Color Control"
capability "Switch"
capability "Configuration"
capability "Polling"
capability "Refresh"
capability "Sensor"
command "setAdjustedColor"
fingerprint profileId: "C05E", inClusters: "0000,0003,0004,0005,0006,0008,0300,1000", outClusters: "0019"
// simulator metadata
simulator {
// status messages
status "on": "on/off: 1"
status "off": "on/off: 0"
// reply messages
reply "zcl on-off on": "on/off: 1"
reply "zcl on-off off": "on/off: 0"
// UI tile definitions
tiles {
standardTile("switch", "device.switch", width: 1, height: 1, canChangeIcon: true) {
state "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#79b821", nextState:"turningOff"
state "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
state "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#79b821", nextState:"turningOff"
state "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
controlTile("rgbSelector", "device.color", "color", height: 3, width: 3, inactiveLabel: false) {
state "color", action:"setAdjustedColor"
controlTile("levelSliderControl", "device.level", "slider", height: 1, width: 2, inactiveLabel: false) {
state "level", action:"switch level.setLevel"
valueTile("level", "device.level", inactiveLabel: false, decoration: "flat") {
state "level", label: 'Level ${currentValue}%'
controlTile("saturationSliderControl", "device.saturation", "slider", height: 1, width: 2, inactiveLabel: false) {
state "saturation", action:"color control.setSaturation"
valueTile("saturation", "device.saturation", inactiveLabel: false, decoration: "flat") {
state "saturation", label: 'Sat ${currentValue} '
controlTile("hueSliderControl", "device.hue", "slider", height: 1, width: 2, inactiveLabel: false) {
state "hue", action:"color control.setHue"
main(["switch"])
details(["switch", "levelSliderControl", "rgbSelector", "refresh"])
// Parse incoming device messages to generate events
log.trace description
if (description?.startsWith("catchall:")) {
if(description?.endsWith("0100") ||description?.endsWith("1001") || description?.matches("on/off\\s*:\\s*1"))
def result = createEvent(name: "switch", value: "on")
log.debug "Parse returned ${result?.descriptionText}"
return result
else if(description?.endsWith("0000") || description?.endsWith("1000") || description?.matches("on/off\\s*:\\s*0"))
if(!(description?.startsWith("catchall: 0104 0300"))){
def result = createEvent(name: "switch", value: "off")
return result
else if (description?.startsWith("read attr -")) {
def descMap = parseDescriptionAsMap(description)
log.trace "descMap : $descMap"
if (descMap.cluster == "0300") {
if(descMap.attrId == "0000"){ //Hue Attribute
def hueValue = Math.round(convertHexToInt(descMap.value) / 255 * 360)
log.debug "Hue value returned is $hueValue"
sendEvent(name: "hue", value: hueValue, displayed:false)
else if(descMap.attrId == "0001"){ //Saturation Attribute
def saturationValue = Math.round(convertHexToInt(descMap.value) / 255 * 100)
log.debug "Saturation from refresh is $saturationValue"
sendEvent(name: "saturation", value: saturationValue, displayed:false)
else if(descMap.cluster == "0008"){
def dimmerValue = Math.round(convertHexToInt(descMap.value) * 100 / 255)
log.debug "dimmer value is $dimmerValue"
sendEvent(name: "level", value: dimmerValue)
else {
def name = description?.startsWith("on/off: ") ? "switch" : null
def value = name == "switch" ? (description?.endsWith(" 1") ? "on" : "off") : null
def result = createEvent(name: name, value: value)
return result
def parseDescriptionAsMap(description) {
(description - "read attr - ").split(",").inject([:]) { map, param ->
def nameAndValue = param.split(":")
map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
def on() {
// just assume it works for now
log.debug "on()"
sendEvent(name: "switch", value: "on")
"st cmd 0x${device.deviceNetworkId} ${endpointId} 6 1 {}"
sendEvent(name: "level", value: 10)
def off() {
log.debug "off()"
sendEvent(name: "switch", value: "off")
"st cmd 0x${device.deviceNetworkId} ${endpointId} 6 0 {}"
def setHue(value) {
def max = 0xfe
log.trace "setHue($value)"
sendEvent(name: "hue", value: value)
def scaledValue = Math.round(value * max / 100.0)
def cmd = "st cmd 0x${device.deviceNetworkId} ${endpointId} 0x300 0x00 {${hex(scaledValue)} 00 2000}"
//log.info cmd
cmd
def setAdjustedColor(value) {
log.debug "setAdjustedColor: ${value}"
def adjusted = value + [:]
adjusted.hue = adjustOutgoingHue(value.hue)
adjusted.level = null // needed because color picker always sends 100
setColor(adjusted)
def setColor(value){
log.trace "setColor($value)"
def max = 0xfe
sendEvent(name: "hue", value: value.hue)
sendEvent(name: "saturation", value: value.saturation)
def scaledHueValue = Math.round(value.hue * max / 100.0)
def scaledSatValue = Math.round(value.saturation * max / 100.0)
def cmd = []
if (value.switch != "off" && device.latestValue("switch") == "off") {
cmd << "st cmd 0x${device.deviceNetworkId} ${endpointId} 6 1 {}"
cmd << "delay 150"
cmd << "st cmd 0x${device.deviceNetworkId} ${endpointId} 0x300 0x00 {${hex(scaledHueValue)} 00 1500}"
cmd << "delay 150"
cmd << "st cmd 0x${device.deviceNetworkId} ${endpointId} 0x300 0x03 {${hex(scaledSatValue)} 1500}"
if (value.level != null) {
cmd << "delay 150"
cmd.addAll(setLevel(value.level))
if (value.switch == "off") {
cmd << "delay 150"
cmd << off()
log.info cmd
cmd
def setSaturation(value) {
def max = 0xfe
log.trace "setSaturation($value)"
sendEvent(name: "saturation", value: value)
def cmd = "st cmd 0x${device.deviceNetworkId} ${endpointId} 0x300 0x03 {${hex(scaledValue)} 1500 }"
//log.info cmd
cmd
def configure() {
state.levelValue = 100
log.debug "Configuring Reporting and Bindings."
def configCmds = [
//Switch Reporting
"zcl global send-me-a-report 6 0 0x10 0 3600 {01}", "delay 500",
"send 0x${device.deviceNetworkId} ${endpointId} 1", "delay 1000",
//Level Control Reporting
"zcl global send-me-a-report 8 0 0x20 5 3600 {0010}", "delay 200",
"send 0x${device.deviceNetworkId} ${endpointId} 1", "delay 1500",
"zdo bind 0x${device.deviceNetworkId} ${endpointId} 1 6 {${device.zigbeeId}} {}", "delay 1000",
"zdo bind 0x${device.deviceNetworkId} ${endpointId} 1 8 {${device.zigbeeId}} {}", "delay 500",
"zdo bind 0x${device.deviceNetworkId} ${endpointId} 1 0x0300 {${device.zigbeeId}} {}", "delay 500"
return configCmds + refresh() // send refresh cmds as part of config
def refresh() {
"st rattr 0x${device.deviceNetworkId} ${endpointId} 6 0", "delay 500",
"st rattr 0x${device.deviceNetworkId} ${endpointId} 8 0", "delay 500",
"st rattr 0x${device.deviceNetworkId} ${endpointId} 0x0300 0", "delay 500",
"st rattr 0x${device.deviceNetworkId} ${endpointId} 0x0300 1", "delay 500",
"st wattr 0x${device.deviceNetworkId} 1 8 0x10 0x21 {0015}"
def poll(){
log.debug "Poll is calling refresh"
refresh()
def zigbeeSetLevel(level) {
"st cmd 0x${device.deviceNetworkId} ${endpointId} 8 4 {${level} 1500}"
def setLevel(value) {
state.levelValue = (value==null) ? 100 : value
log.trace "setLevel($value)"
def cmds = []
if (value == 0) {
cmds << zigbeeOff()
else if (device.latestValue("switch") == "off") {
sendEvent(name: "level", value: state.levelValue)
def level = hex(state.levelValue * 255 / 100)
cmds << zigbeeSetLevel(level)
//log.debug cmds
cmds
private getEndpointId() {
new BigInteger(device.endpointId, 16).toString()
private hex(value, width=2) {
def s = new BigInteger(Math.round(value).toString()).toString(16)
while (s.size() < width) {
s = "0" + s
s
private adjustOutgoingHue(percent) {
def adjusted = percent
if (percent > 31) {
if (percent < 63.0) {
adjusted = percent + (7 * (percent -30 ) / 32)
else if (percent < 73.0) {
adjusted = 69 + (5 * (percent - 62) / 10)
else {
adjusted = percent + (2 * (100 - percent) / 28)
log.info "percent: $percent, adjusted: $adjusted"
adjusted
