One stubborn Zooz zen24 switch will not recognize edge driver
I have enrolled and installed the Zen24 edge driver. The remaining 20 or so Zen24 switches in the house are fine- when I re-added them they were recognized with the edge driver.
Not this one. Why??
It always recognizes as “Z-wave device” and doesn’t show “driver” under the menu.
Isn’t there some easy hacky way I can just force this thing to use the edge driver of my choosing??
  • exclude the device
  • get the hub within a few inches of the device
  • Add device > by device type > z-wave
Yes, so I have heard this. I’m wondering why proximity to the hub would make a difference with how it detects the device. I can see if it doesn’t detect it AT ALL but if it does sense the signal, shouldn’t it just always detect it the same either way??
It can make a difference in three different ways.
  1. if there is some occasional local interference, putting the device and hub closer together can help ensure the clean signal that is needed to add a new device to the network
  2. it can improve the chances of successfully exchanging the encryption key, and so add the device at the highest security level it supports
  3. it takes any repeating devices out of the equation, which again just gets you a cleaner signal when adding a new device to the network.
Basically, being added to the network as a new device is probably the most complicated process Any Z wave device will ever do, particularly those using higher levels of security. Multiple messages have to be exchanged in a set period of time.
So moving the hub and the device close together, or using a QR code to add if that’s supported by the device, both just simplify the onboarding process.
However, if you do do it this way (which is called “bench pairing”) then, after you successfully add a zwave device you should move it to its permanent physical location and then run a zwave repair to make sure that it will route through its correct neighbors.
Once the device is a part of the network, then messages can be routed through repeaters and if necessary retransmitted to ensure they get through. So that’s just a less fragile process than the initial adding of the device. :sunglasses:
