The specs on the fan and switch are nothing special. A standard Zwave on/off switch should work. The only variable with switching motors is the initial load to start the fan and if the switch can handle. But again this fan is not that big. I say it’s worth a try.
I have the 10" version of this iLiving fan in my garage and it’s a great fan. Very quiet, great cfm, and uses only about 75W. I wired in standard power supply cord for use on a local garage outlet and used a Zooz Z-Wave Plus Power Switch ZEN15 which is rated at 15A.
I set up a simple webCore rule to turn the fan on when the garage temperature exceeds the outside local area temperature. It’s been working well and I never need to touch it or think about it.
