Older (and newer) devices all progressively going offline?
Got set up with Smartthings hub v3 in 2018 and set up a bunch of sensors without too much issue. In the last year or so i’ve been losing sensors left and right to “offline” status and of course many of these are now defunct so no customer support. Is there an edge driver that can fix these issues, or do i just need to keep researching and buying new sensors?
  1. Iris door sensor offline as of Jun 2024, revived briefly with a battery change, removing it from the door, re-pairing it when sitting directly next to the hub, but then it went offline again 6 hours later and no amount of battery changes or resets will help.
  2. Schlage Z-Wave keypad lock installed Apr 2022, has been offline about 12 hours of each day randomly for the past year. When i need to do anything i basically just keep checking the app until it randomly comes back online again.
    Replacing batteries has not changed anything, and there are several other functioning sensors further away from the hub than the door lock so connectivity isn’t the issue.
  3. Sengled door sensor installed Jun 2023 and went offline in Oct 2024. Bought a pack of 2 and installed on the same day, first one works no problem, 2nd one is offline and battery change doesn’t help and it seemingly won’t reset (no flashing red light upon hitting the reset button). Might just be a bad sensor that died after only a year and a half, even though the other sensor in the 2-pack is fine?
  4. Dome leak sensor offline as of Nov 2024 (Dome shut-off valve still works). Might be dead since new battery and hitting the reset button doesn’t produce a flashing red light?
Any help would be greatly appreciated. Definitely feels like since we lost IDE access a lot more issues have been cropping up, but not sure what the issue is.
Do these devices have anything in common (all Z-Wave, or all Zigbee)? Or are they a mix?
His lock is Z-Wave and the Sengled sensors are Zigbee. I had a couple of my Sengled sensors just flat die, too, @mh330. I think they’re just kind of fragile.
