gergtreble
(Gergtreble)
December 9, 2020, 6:17pm
300
So it should be possible:
OK, firstly bear in mind that you may find the process a bit arcane, complicated or think that it just sucks. Fair enough, but it is functionality designed for the ‘new’ environment being retrofitted into the legacy environment, it isn’t going to be pretty.
The following content is based on an actual example that appeared in another post. The object of the exercise was to have a device display the illuminance in the dashboard tile.
The tool that will be used is the CLI . Yes, that is CLI as in Command Line Interface. It is essentially being used to make it easier to use the SmartThings REST API.
Capabilities have their own ‘presentations’ that define how they look when they are used as the status on the dashboard tile, as the action on the dashboard tile, as tiles on the detail pages, an…
I think with the old app it was a lot easier than it is now though. Sadly I don’t trust myself to follow these instructions without breaking things. Perhaps someone more technical could take a look (or I might get brave at the weekend).
