yeah i put the IP of the controller in my web browser and i go to the control tab and i try moving the sliders from there and they do nothing
none of them do anything
i go to the update FW tab and it lets me update, it says successfully updated , rebooting
i go to status and i see this so can you confirm that this is the right FW
{“rgb”:“000000”, “r”:“00”, “g”:“00”, “b”:“00”, “w1”:“00”, “w2”:“00”, “power”:“off”, “running”:“false”, “program”:“0”, “uptime”:“0:0:48”, “version”:“2.0.6”, “date”:“Jun 20 2017 20:47:54”}
no static IP is not set my router is set to DHCP but the IP has not changed the whole time i been trying to make it work , here are the advanced settings in the controller
the controller is wired right i tested the controller with it’s original FW and the LEDDimer app and it worked fine and i also tested the strip with a cheap Chinese 40 button RF RGBW controller and it also worked fine and i tried to discover the controller without the strip connected at all and still does not discover it
at worst R and G are reversed but that would not explain why the W1 channel will not turn off or why the strip had solid W and the RGB goes through 7 colors blink cycle when i power it on
(edit :i tried reversing R and G and it make no difference)
the power supply is from an old PC , not sure what the amp ratings on the side mean but they seem ridiculously low and there are 2 of them for 12v to confuse things further but again it worked fine with the controller when it was on its factory FW and the app intended for it and also with the same strip and also with the same strip and the cheapo Chinese RF 40 button remote RGBW controller
also does not explain why the controller is not getting discovered in the smart app when no strip is connected to it , there surely is enough power for the controller alone to be discovered , the signal strength is good in my router client list
here is the power supply ,i can not imagine these amp ratings are right either one of them this was from an old 486 i think
probably is underpowered for the 300 led 5 meter strip but it is only for testing purposes for now and i have left it on for extended periods with no problem
yeah dalecs vid was good for flashing but i coould not see a thing happening on his phone , i would like to see the controller being controlled through the app device handler ,sliders and color picker to see how it should function normally
i do not see anything that is supposed to make the strip do color fades or blinks through the colors but that is what it does when i turn it on or hit those grey circle buttons to the left of the R G B W1 W2 sliders sometimes
i set the IGMP snooping to on and tried again and still the same thing , not detected again
so you have no idea what “error java.lang.NullPointerException: Cannot invoke method startsWith() on null object @ line 646” means in th elog during discovery?
do i have to keep the screen on on my android device while it is discovering? could it be a crapdroid issue? i see dalec saying he had problems with smart apps on android
but i have no IOS device on high enough FW (IOS9) to test it with IOS
i tried everything 100 times i deleted everything in IDE and re-added it ,i “factory” reset the controller and re-entered by wifi credentials i reset the hub and the controller 100 times i reset the router
i really do not know what else i can try
not plug N play , really you don’t say
i have only been up till like 4 am for months on end trying to make this POS work with no luck at all so far
