I have experimented with several platforms, including Vera Edge, Staples, Wink and a few open-source software packages, particularly HomeGenie and HomeAssistant. All of them do certain things better than SmartThings and other things worse. At the end of the day, I stuck with ST as the “lesser of all evils”. I just scaled back my expectations and ambitions. Don’t really have time to do development anymore.
I have two zones with delay in stay mode and the SA arms from my IRIS keypad with a 30 second delay. But that also means that if I open a door that has the delay it takes 30 seconds for the alarm to sound. It is operating the same way my regular home alarm worked. But tha alarm arms in stay mode all exterior openings and disables motion detectors.
but are you using my custom version… I changed the way alarms happen with the delay… prior it would delay after entry and if a zone was still tripped after the delay sound the alrarm. Now I do a post delay check and if the system has been disarmed it doesn’t alert. prior even if disarmed if after the delay the zone was still tripped it would alert…
Basically is there an advantage of using the feature built into the Smart Alarm in regards to remote arming or would it be more beneficial to have a seperate app associated with the remote that would change the mode of the home to “away”, thus arming Smart Alarm?
As of now we use a DTH to handle the input code for the IRIS but if it was part of the SA it would be much less complicated. The same thing would work for the Lock Manager for door locks if it was part of SA.
I just found another post that says the siren you have is a “re-badged” Philio PSE02 Siren.
I recently created a DTH for that device and it supports playing the different built in sounds like door chime, beep, police, ambulance, fire, emergency and I also added a chirp feature that basically just turns it on and off really fast.
I checked the manual for your device and the commands are similar to the ones in my DTH so it might work, but you’ll have to try it to know for sure.
If it does work, please let me know and post the raw description so I can add it to the list of model numbers it is compatible with and the DTH fingerprint.
The buttons in the mobile app respond properly with Android devices, but I’ve heard you may have to press the buttons more than once to reset them with iOS.
Edit: I forgot to mention that if you open Live Logging before switch DTHs you should be able to see if it was able to configure the device properly when you change it.
You should also open the device’s setting through the mobile app and tap done before trying to use the device. If it doesn’t play post the live logging output.
