[RELEASE] Zipato/Phileo Multisound Siren (PH-PSE02.US)
dth_siren
dth_security
dth_alerts
(Kevin) #1
This is a device handler for the Zipato Z-Wave Indoor Multi-Sound Siren (PH-PSE02.US). It’s been tested on the US version, but it should work with the EU version.
Features:
  • It plays 7 different sounds (Ambulance, Beep, Chirp, Door Chime, Emergency, Fire, Police)
  • Allows you to select a different sound for alarm.strobe, alarm.siren, alarm.both, tone.beep, switch.on.
  • Optional alarm duration settings with 10 options ranging from 30 seconds to 1 hour.
  • Has disable feature which is a hardware setting that prevents the device from making noise until it’s enabled.
  • Supports the music player capability so it can be used with SHM and/or Speaker Notify with Sound to play the different sounds by selecting the device as an Audio Device, choosing Custom Message and entering the sound name (beep, door, ambulance, emergency, fire, police) or the setting name (on, siren, strobe, both).
Sound effect before alarm goes off (20 seconds)
DLINK DCH-Z510 Siren Connection -- help needed
Smart Alarm Updates
(Whatwillb) #2
Thank you so much for creating this. For some reason all of my sound trigger the alarm. Any idea why this might be happening? I really just want to have a the door sound available for entry notification and the alarm for intrusion.
(Kevin) #3
Which sounds have you selected from the settings?
Are you trying to play them by pushing the tiles or using a SmartApp?
If you enable “Debug Logging” and then go into the IDE and open Live Logging, you may see some messages that provide more information.
(Jay) #4
Hi, I am very new to smartthings. Can you provide a step by step guide to installing this app? I am from the UK. I have managed to copy the code to the device handler fine, but i cannot see the app?
J
(Kevin) #5
This is a Device Handler, not a SmartApp.
You should install it in the “My Device Handlers” section of the IDE before you connect the device. Then when you connect the device it should automatically assign it this device handler.
If you’ve already connected the device, you can still install it, but you will need to go to open the device from the “My Devices” screen in the IDE, and change the “Type” field to “Zipato Multisound Siren”. The device handlers you install through the IDE will be located at the bottom of the drop down list. You will then need to open the device in the Mobile App and save the settings screen to ensure that all of the configuration values are sent to the device.
The following url has detailed information on using custom device handlers:
http://thingsthataresmart.wiki/index.php?title=Using_Custom_Code#Using_a_Custom_Device_Handler
(Jay) #6
Hi, thanks for the quick response.
I managed to get it installed, but i cannot get any other tone to work other than default? I have the PH-PSE02-EU do you think i need to change anything else?
J
(Kevin) #7
Open live logging in the IDE and the go in the device settings through the mobile app, enable debug logging if not already enabled and tap done. The try one of the sounds, and then post the live logging data.
(James) #8
I have created the device handler in my account, using your code and changed the device type in the IDE. The tile console appears in the mobile app. I have set different tones for each action, but only one sound is heard. Log shows, as an example…
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:32:33: debug Encliffe Siren turned off
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:32:32: debug Executing off()
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:32:30: debug Encliffe Siren turned on
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:32:29: info Encliffe Siren Playing Sound #2
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:32:29: debug Executing siren()
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:32:18: debug Encliffe Siren turned off
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:32:17: debug Executing off()
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:32:14: debug Encliffe Siren turned on
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:32:13: info Encliffe Siren Playing sound #6 0 time(s)
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:32:13: debug Executing beep()
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:32:07: debug Encliffe Siren turned off
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:32:07: debug Executing off()
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:31:48: debug Encliffe Siren turned off
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:31:47: debug Executing off()
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:31:45: debug Encliffe Siren turned on
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:31:45: info Encliffe Siren Playing Sound #4
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:31:45: debug Executing strobe()
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:30:55: debug Encliffe Siren turned off
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:30:54: debug Executing off()
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:30:54: debug Encliffe Siren turned on
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:30:53: info Encliffe Siren Playing sound #6 0 time(s)
d8763d00-5a1b-4da9-b8a5-69118a628aec 11:30:53: debug Executing beep()
Have I done something wrong? Also, there are two entries in the mobile app config screen, at the bottom, both set to 1, but no information as to what they are.
This is my first attempt at this kind of stuff and I would greatly value your help :slight_smile: TIA James
(James) #9
More info: I have created a Smartapp to trigger the siren, but only the default sound occurs, irrespective of Siren device settings.
Log:
Encliffe Siren (Device) Events — displayed | all | from device
Event Type Filter: NONE | SOLUTION_SUMMARY | SOLUTION_EVENT | SOLUTION_STATE | NOTIFICATION | LOCATION_MODE_CHANGE | IMAGE | VIDEO | ALERT | GRAPH | ENTITY_UPDATE
Date Source Type Name Value User Displayed Text
2017-02-17 1:38:04.727 PM GMT
moments ago DEVICE switch off Encliffe Siren switch is off
moments ago DEVICE status off Encliffe Siren status is off
2017-02-17 1:38:04.281 PM GMT
moments ago COMMAND off off command was sent to Encliffe Siren
2017-02-17 1:38:03.709 PM GMT
moments ago APP_COMMAND off
2017-02-17 1:38:03.134 PM GMT
moments ago DEVICE switch on Encliffe Siren switch is on
moments ago DEVICE status on Encliffe Siren status is on
2017-02-17 1:38:02.668 PM GMT
moments ago COMMAND on on command was sent to Encliffe Siren
2017-02-17 1:38:02.609 PM GMT
moments ago APP_COMMAND on
2017-02-17 1:37:58.615 PM GMT
2017-02-17 1:37:57.642 PM GMT
moments ago DEVICE ENTITY_UPDATE DeviceUpdated Device ‘{{ deviceName }}’ updated
2017-02-17 1:37:27.316 PM GMT
2017-02-17 1:37:26.838 PM GMT
2017-02-17 1:37:26.821 PM GMT
2017-02-17 1:37:26.616 PM GMT
2017-02-17 1:37:26.120 PM GMT
2017-02-17 1:37:26.099 PM GMT
2017-02-17 1:37:24.025 PM GMT
2017-02-17 1:37:23.463 PM GMT
2017-02-17 1:37:23.438 PM GMT
2017-02-17 1:37:22.229 PM GMT
2017-02-17 1:37:22.207 PM GMT
2017-02-17 1:37:17.418 PM GMT
2017-02-17 1:37:16.473 PM GMT
2017-02-17 1:36:44.120 PM GMT
6 minutes ago DEVICE switch off Encliffe Siren switch is off
6 minutes ago DEVICE status off Encliffe Siren status is off
2017-02-17 1:36:43.610 PM GMT
6 minutes ago COMMAND off off command was sent to Encliffe Siren
2017-02-17 1:36:43.594 PM GMT
6 minutes ago APP_COMMAND off
2017-02-17 1:36:43.298 PM GMT
6 minutes ago DEVICE switch on Encliffe Siren switch is on
6 minutes ago DEVICE status on Encliffe Siren status is on
2017-02-17 1:36:42.872 PM GMT
6 minutes ago COMMAND on on command was sent to Encliffe Siren
2017-02-17 1:36:42.855 PM GMT
6 minutes ago APP_COMMAND on
2017-02-17 1:36:37.921 PM GMT
2017-02-17 1:36:37.503 PM GMT
2017-02-17 1:36:37.481 PM GMT
2017-02-17 1:36:35.302 PM GMT
2017-02-17 1:36:34.911 PM GMT
2017-02-17 1:36:34.233 PM GMT
2017-02-17 1:36:26.657 PM GMT
6 minutes ago DEVICE ENTITY_UPDATE DeviceUpdated Device ‘{{ deviceName }}’ updated
2017-02-17 1:36:04.442 PM GMT
2017-02-17 1:36:03.834 PM GMT
2017-02-17 1:35:57.792 PM GMT
2017-02-17 1:35:57.240 PM GMT
2017-02-17 1:35:56.576 PM GMT
(Kevin) #10
Are you on version 1 or 2 of the hub? Do you have the US version of the device?
It sounds like you connected the device to SmartThings before creating the device handler so can you remove the device and then add it again. I’m not sure if that will make a difference, but it’s worth a shot.
Open live logging after removing the device, but before pairing it.
Once it’s paired, (assuming it paired as the correct device) open the device settings in the mobile app, make some changes, and then tap done.
If it didn’t pair as the correct device, switch it in the IDE, clear live logging, open the device settings in the mobile app, make some changes, and then tap done.
Wait until it stops writing messages to live logging and then post the live logging output.
(James) #11
Thanks Kevin for your reply :slight_smile: Removing and re-adding siren device made no difference. I am in the UK. Hub v2, EU siren version. Here are the logs reported from just before I re-added the device… Maybe a few ‘extras’ from other Smartthings devices working away in the house!
b967956a-8843-4f2a-9605-c146fd544352 16:35:14: debug Zipato Multisound Siren turned off
b967956a-8843-4f2a-9605-c146fd544352 16:35:13: debug Executing off()
b967956a-8843-4f2a-9605-c146fd544352 16:35:12: debug Zipato Multisound Siren turned on
b967956a-8843-4f2a-9605-c146fd544352 16:35:12: info Zipato Multisound Siren Playing Sound #2
b967956a-8843-4f2a-9605-c146fd544352 16:35:12: debug Executing siren()
b967956a-8843-4f2a-9605-c146fd544352 16:35:11: debug Zipato Multisound Siren turned off
b967956a-8843-4f2a-9605-c146fd544352 16:35:11: debug Zipato Multisound Siren turned on
b967956a-8843-4f2a-9605-c146fd544352 16:35:10: debug Executing off()
b967956a-8843-4f2a-9605-c146fd544352 16:35:08: info Zipato Multisound Siren Playing sound #6 0 time(s)
b967956a-8843-4f2a-9605-c146fd544352 16:35:08: debug Executing beep()
b967956a-8843-4f2a-9605-c146fd544352 16:35:07: debug Zipato Multisound Siren turned off
b967956a-8843-4f2a-9605-c146fd544352 16:35:06: debug Executing off()
b967956a-8843-4f2a-9605-c146fd544352 16:35:05: debug Zipato Multisound Siren turned on
b967956a-8843-4f2a-9605-c146fd544352 16:35:05: info Zipato Multisound Siren Playing Sound #1
b967956a-8843-4f2a-9605-c146fd544352 16:35:05: debug Executing both()
b967956a-8843-4f2a-9605-c146fd544352 16:35:04: debug Zipato Multisound Siren turned on
b967956a-8843-4f2a-9605-c146fd544352 16:35:04: info Zipato Multisound Siren Playing Sound #1
b967956a-8843-4f2a-9605-c146fd544352 16:35:04: debug Executing both()
b967956a-8843-4f2a-9605-c146fd544352 16:35:03: debug Zipato Multisound Siren turned off
b967956a-8843-4f2a-9605-c146fd544352 16:35:02: debug Executing off()
b967956a-8843-4f2a-9605-c146fd544352 16:35:01: debug Zipato Multisound Siren turned on
b967956a-8843-4f2a-9605-c146fd544352 16:35:00: info Zipato Multisound Siren Playing Sound #3
b967956a-8843-4f2a-9605-c146fd544352 16:35:00: debug Executing strobe()
b967956a-8843-4f2a-9605-c146fd544352 16:35:00: debug Zipato Multisound Siren turned off
b967956a-8843-4f2a-9605-c146fd544352 16:35:00: debug Notification Type: Notification Report
b967956a-8843-4f2a-9605-c146fd544352 16:35:00: debug Alarm State: enabled
b967956a-8843-4f2a-9605-c146fd544352 16:35:00: debug Alarm Duration: 120 Seconds
b967956a-8843-4f2a-9605-c146fd544352 16:34:58: debug
Strobe Sound: Ambulance
Siren Sound: Fire
Both Sound: Emergency
On Sound: Chirp
Beep Sound: Beep
b967956a-8843-4f2a-9605-c146fd544352 16:34:58: debug Executing refresh()
b967956a-8843-4f2a-9605-c146fd544352 16:34:58: debug Secure Commands Enabled
21d9520f-9450-4836-8d6e-e648f8283937 16:33:57: debug Parse returned [name:temperature, value:14, unit:C, descriptionText:Motion Sensor (porch) was 14°C]
21d9520f-9450-4836-8d6e-e648f8283937 16:33:57: debug description: temperature: 13.90
b967956a-8843-4f2a-9605-c146fd544352 16:33:55: debug Zipato Multisound Siren turned off
b967956a-8843-4f2a-9605-c146fd544352 16:33:55: debug Executing off()
b967956a-8843-4f2a-9605-c146fd544352 16:33:54: debug Zipato Multisound Siren turned on
b967956a-8843-4f2a-9605-c146fd544352 16:33:54: info Zipato Multisound Siren Playing Sound #1
b967956a-8843-4f2a-9605-c146fd544352 16:33:54: debug Executing strobe()
b967956a-8843-4f2a-9605-c146fd544352 16:33:52: debug Zipato Multisound Siren turned off
b967956a-8843-4f2a-9605-c146fd544352 16:33:52: debug Executing off()
b967956a-8843-4f2a-9605-c146fd544352 16:33:51: debug Zipato Multisound Siren turned on
b967956a-8843-4f2a-9605-c146fd544352 16:33:50: info Zipato Multisound Siren Playing Sound #1
b967956a-8843-4f2a-9605-c146fd544352 16:33:50: debug Executing siren()
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:33:41: debug Parse returned [name:motion, value:inactive, descriptionText:{{ device.displayName }} motion has stopped, translatable:true]
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:33:41: debug motion
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:33:41: debug description: zone status 0x0020 – extended status 0x00
2de1c5f3-b322-4500-b393-da568251edff 16:33:27: trace timeOk = false
2de1c5f3-b322-4500-b393-da568251edff 16:33:27: trace timeWindowStop = Fri Feb 17 15:55:00 UTC 2017
2de1c5f3-b322-4500-b393-da568251edff 16:33:27: trace timeWindowStart = Fri Feb 17 13:55:00 UTC 2017
2de1c5f3-b322-4500-b393-da568251edff 16:33:27: trace daysOk = true
2de1c5f3-b322-4500-b393-da568251edff 16:33:27: trace modeOk = true
2de1c5f3-b322-4500-b393-da568251edff 16:33:27: trace triggerHandler(motion: active)
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:33:27: debug Parse returned [name:motion, value:active, descriptionText:{{ device.displayName }} detected motion, translatable:true]
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:33:27: debug motion
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:33:27: debug description: zone status 0x0022 – extended status 0x00
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:32:40: debug Parse returned [name:motion, value:inactive, descriptionText:{{ device.displayName }} motion has stopped, translatable:true]
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:32:40: debug motion
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:32:40: debug description: zone status 0x0020 – extended status 0x00
28970a6c-9860-4866-a33c-f6bfe95dbfa0 16:32:31: debug Parse returned [name:temperature, value:19, unit:C, descriptionText:Motion Sensor (middle door) was 19°C]
28970a6c-9860-4866-a33c-f6bfe95dbfa0 16:32:31: debug description: temperature: 18.88
2de1c5f3-b322-4500-b393-da568251edff 16:32:28: trace timeOk = false
2de1c5f3-b322-4500-b393-da568251edff 16:32:28: trace timeWindowStop = Fri Feb 17 15:55:00 UTC 2017
2de1c5f3-b322-4500-b393-da568251edff 16:32:28: trace timeWindowStart = Fri Feb 17 13:55:00 UTC 2017
2de1c5f3-b322-4500-b393-da568251edff 16:32:28: trace daysOk = true
2de1c5f3-b322-4500-b393-da568251edff 16:32:28: trace modeOk = true
2de1c5f3-b322-4500-b393-da568251edff 16:32:28: trace triggerHandler(motion: active)
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:32:28: debug Parse returned [name:motion, value:active, descriptionText:{{ device.displayName }} detected motion, translatable:true]
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:32:28: debug motion
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:32:28: debug description: zone status 0x0022 – extended status 0x00
b967956a-8843-4f2a-9605-c146fd544352 16:32:15: debug Notification Type: Notification Report
b967956a-8843-4f2a-9605-c146fd544352 16:32:14: debug Zipato Multisound Siren turned off
b967956a-8843-4f2a-9605-c146fd544352 16:32:14: debug Alarm State: enabled
b967956a-8843-4f2a-9605-c146fd544352 16:32:14: debug Alarm Duration: 180 Seconds
b967956a-8843-4f2a-9605-c146fd544352 16:32:13: debug
Strobe Sound: null
Siren Sound: null
Both Sound: null
On Sound: null
Beep Sound: null
b967956a-8843-4f2a-9605-c146fd544352 16:32:13: debug Executing refresh()
b967956a-8843-4f2a-9605-c146fd544352 16:32:13: debug Secure Commands Enabled
28970a6c-9860-4866-a33c-f6bfe95dbfa0 16:31:58: debug Parse returned [name:motion, value:inactive, descriptionText:{{ device.displayName }} motion has stopped, translatable:true]
28970a6c-9860-4866-a33c-f6bfe95dbfa0 16:31:58: debug motion
28970a6c-9860-4866-a33c-f6bfe95dbfa0 16:31:58: debug description: zone status 0x0020 – extended status 0x00
b967956a-8843-4f2a-9605-c146fd544352 16:31:58: debug Zipato Multisound Siren turned off
b967956a-8843-4f2a-9605-c146fd544352 16:31:58: debug Notification Type: Notification Report
b967956a-8843-4f2a-9605-c146fd544352 16:31:57: debug Alarm State: enabled
b967956a-8843-4f2a-9605-c146fd544352 16:31:57: debug Alarm Duration: 180 Seconds
b967956a-8843-4f2a-9605-c146fd544352 16:31:57: debug Configuring Secure Device
b967956a-8843-4f2a-9605-c146fd544352 16:31:57: debug Secure Inclusion Detected
b967956a-8843-4f2a-9605-c146fd544352 16:31:55: debug Checking for Secure Command Support
b967956a-8843-4f2a-9605-c146fd544352 16:31:55: debug Configuring Non-Secure Device
28970a6c-9860-4866-a33c-f6bfe95dbfa0 16:31:24: debug Parse returned [name:motion, value:active, descriptionText:{{ device.displayName }} detected motion, translatable:true]
28970a6c-9860-4866-a33c-f6bfe95dbfa0 16:31:24: debug motion
28970a6c-9860-4866-a33c-f6bfe95dbfa0 16:31:24: debug description: zone status 0x0022 – extended status 0x00
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:31:19: debug Parse returned [name:temperature, value:20, unit:C, descriptionText:Motion Sensor (landing) was 20°C]
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:31:19: debug description: temperature: 19.73
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:29:15: debug Parse returned [name:motion, value:inactive, descriptionText:{{ device.displayName }} motion has stopped, translatable:true]
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:29:15: debug motion
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:29:15: debug description: zone status 0x0020 – extended status 0x00
2de1c5f3-b322-4500-b393-da568251edff 16:29:01: trace timeOk = false
2de1c5f3-b322-4500-b393-da568251edff 16:29:01: trace timeWindowStop = Fri Feb 17 15:55:00 UTC 2017
2de1c5f3-b322-4500-b393-da568251edff 16:29:01: trace timeWindowStart = Fri Feb 17 13:55:00 UTC 2017
2de1c5f3-b322-4500-b393-da568251edff 16:29:01: trace daysOk = true
2de1c5f3-b322-4500-b393-da568251edff 16:29:01: trace modeOk = true
2de1c5f3-b322-4500-b393-da568251edff 16:29:01: trace triggerHandler(motion: active)
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:29:01: debug Parse returned [name:motion, value:active, descriptionText:{{ device.displayName }} detected motion, translatable:true]
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:29:01: debug motion
857044d6-b0be-46ce-9f16-8db1c11a53ba 16:29:01: debug description: zone status 0x0022 – extended status 0x00
21d9520f-9450-4836-8d6e-e648f8283937 16:28:58: debug Parse returned [name:temperature, value:14, unit:C, descriptionText:Motion Sensor (porch) was 14°C]
21d9520f-9450-4836-8d6e-e648f8283937 16:28:58: debug description: temperature: 13.90
16:28:27: info Waiting on events…
16:28:27: info For past logs for individual things go to the My Devices section, find the device and click on the Events link on the device information page.
16:28:27: info This console provides live logging of your SmartThings.
(Kevin) #12
At 16:34, it confirms that the settings have been properly set and secure commands are enabled so the strobe, both, siren, and beep commands should have made different sounds.
It’s unlikely, but possible that the configuration settings are slightly different for the US and EU versions.
Can you post some pictures of the manual so I can verify the configuration?
Can you also open the device in the IDE and post the raw description?
(James) #13
The manual (which is identical to the paper copy included in the device packaging) is here https://www.zipato.com/wp-content/uploads/2015/10/ph-pse02-Zipato-Siren-User-Manual-v1.2.pdf
IDE info:
Zipato Multisound Siren Device Zipato Multisound Siren
Name Zipato Multisound Siren
Label Zipato Multisound Siren
Type Zipato Multisound Siren
Version Published
Device Network Id 09
Status ACTIVE
Hub Encliffe Hub
Last Activity At 2017-02-17 4:35 PM GMT
Date Created 2017-02-17 4:31 PM GMT
Last Updated 2017-02-17 4:34 PM GMT
Data No data found for device
Raw Description zw:Ls type:1005 mfr:013C prod:0004 model:000A ver:1.12 zwv:4.05 lib:03 cc:5E,72,86,59,73,5A,98,7A sec:71,20,25,85,70,30 role:05 ff:8F00 ui:8F00
Current States
switch: off
alarm: off
tamper: detected
status: off
alarmState: enabled
Preferences (edit)
Name Type Value
alarmDuration enum 2 Minutes
beepSound enum Beep
bothSound enum Emergency
debugOutput bool true
repeatBeepDelay number 2000
repeatBeepSound number 0
sirenSound enum Fire
strobeSound enum Ambulance
switchOnSound enum Chirp
Events List Events
In Use By
(James) #14
Tamper detected prob because I have the cover/mouting plate off while I re-added the device (need to press buttons inside).
(Kiranmk702) #15
Hi @krlaframboise, I have exactly same issue as @JamesEncliffe , I get only Alarm too
Regards,
Kiran
(Kevin) #16
I’ll look into it tonight. You’re also on the EU version, right?
(Kiranmk702) #17
Yes Kevin, Mine is also EU version.
Cheers.
(Kiranmk702) #18
@krlaframboise, Just curious to know if this device handler gives the flexibility to choose different sounds for different events in Smartthings ? for ex, for door /chirp for door open/close events and Alarm for Home away mode ?
Thanks,
Kiran
(Kevin) #19
Yes, it will allow you to do those things. .
I’m comparing the manuals and reviewing my code now to see if I can figure out why it’s not working with the EU model.
(Kevin) #20
I’m pretty sure I’ve figured out the problem and I’ll release a new version tonight or tomorrow morning.
@JamesEncliffe
