is there a problem trying to pull from github ? i added the following setting and when i click on “hueMotionSensor (master)” under update from repo. nothing show up from New (onlyGithub)
Owner: bogdanalexe90
Branch: master
Branch: master
You can also just copy and paste the code if you’re having challenges using the repo.
Anyone know of plans for edge drivers for this?
I’ve just uploaded my Edge driver for Hue Motion Sensor.
Hi Jaewon! It would be great, if you could add another Edge driver for the Hue Outdoor motion sensor with the ID “SML002”, since it’s not recognized with your SML001 Hue Motion Sensor driver. Thank you very much! greetings from Austria, Lukas
SML002 is already included in this edge driver, and I’m actually using one in my home with this driver.
Amazing, it works! Maybe the reason it didn’t work before was that I had to restart the Hub. Thanks and greetings, Lukas
Ok only problem with my outdoor sensor is that it stopped working (freezing) after some time, so it sadly doesn’t work for me
(I’ve tried to delete/add it again but stopped working after some minutes) @iquix
+1 Having the same problem as well with the edge driver
Having also this problem with device handler en edge-driver. Type 002 works well but lost connection with ST after a while.
Hi @iquix - Thanks a ton for the new Edge Driver. I have been having many drop outs with the Hue Sensor recently. Your Edge Driver and someone else’s tip about turning off the secure mode has got it working reliably for a while.
Just a query - I see that every ~5 minutes the ST app is getting feed from the Sensor on illuminance and temperature. I am newish to using ST. Is this configurable time interval configurable anywhere ? For instance when there is no motion, I only want it to get readings every hour ? Hoping this might help battery life on the longer run. Happy to be proven wrong.
Any thoughts on this welcome. Thank you.
Does this no longer work or do I an issue with my setup?
For reference, followed your instructions, reconnected my hue motion sensor and it does not detect motion
