I think it was one of my Blooms. I’ll test it again later this morning and find out for sure.
Ok, yeah, it’s one of my Blooms. Is there any data you need from me to help debug it?
tmleafs,
Any chance to look at my request above to rename flash to flash_on or something simliar?
This is so I could use the flash command in the DTH since WebCoRE also has an emulated flash command. I was able to fix it on my own and confirmed it works if it’s renamed in the DTH with WebCoRE.
I have the same issue. I tried the clean up with no avail.
I have a old bulb showing up with a mac of my hub when I’m on the discover section of the app. My hub adds to ST via the original app no issues but not this. I’m on the tmleaf branch too.
UPDATE: reset my hue hub to factory. Still happens. This has to be a ST issue. It’s really odd
HELP
@Staff_Members Can you assist?
I have a call logged but a fast response would be good as I can’t use any Lighting. I keep seeing Landing Hue in the live logging when searching for my Hue hub with this message
09?:?06?:?23: warn super_connect_warn parse() received in hue bulb description=index:18
The Base64 shows this device not as a bulb but as my Hue Hub.
Hey Tony,
I’ve followed the thread here all the way from your FLEXi app! Looks like you’ve put a lot of great work into this - so thank you!
I have a mix of hue, lightify, sengled, and GE dimmers - I’d like to be able to control scenes (just dimming levels really) in one app. Can this be done using your app? And if not, are there any recommended solutions for scene management with mixed technology?
Best,
Rob
Hi All ;
I have been following the above thread for the past few hours , reading through to try to get the Smart App to discover my 2 hub , tried each and every conversation :
added the IDE
Added the Smart code manually several time and deleted the smart app
deleted the device and all lights
re-added everything again
still having issues , code is from https://github.com/tmleafs/Hue_B_Smart/blob/master/smartapps/info-fiend/hue-b-smart.src/hue-b-smart.groovy
hub is static ip , and i have also renamed all hubs
hue B smart :
58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:34 AM: debug Sending verify request for 0017886CEDCA (192.168.1.6:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:34 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:31 AM: debug Bridge discovery sent 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:31 AM: debug Sending bridge discovery. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:27 AM: debug Sending verify request for 0017886CEDCA (192.168.1.6:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:27 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:23 AM: debug Sending verify request for 0017886CEDCA (192.168.1.6:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:23 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:20 AM: debug Sending verify request for 0017886CEDCA (192.168.1.6:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:20 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:17 AM: debug Previously found bridge discovered 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:17 AM: debug Discovered bridge 0017886CEDCA (192.168.1.6) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:17 AM: debug Discovery Response is [devicetype:04, mac:0017886CEDCA, networkAddress:C0A80106, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017886cedca, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:25740b45-6718-412a-9a30-36e04d066eaa]. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:16 AM: debug Sending verify request for 0017886CEDCA (192.168.1.6:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:16 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:16 AM: debug Found new bridge. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:16 AM: debug Discovered bridge 0017886CEDCA (192.168.1.6) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:16 AM: debug Discovery Response is [devicetype:04, mac:0017886CEDCA, networkAddress:C0A80106, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017886cedca, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:25740b45-6718-412a-9a30-36e04d066eaa]. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:13 AM: debug Bridge discovery sent 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:13 AM: debug Sending bridge discovery. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:09 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:06 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:29:02 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:58 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:55 AM: debug Bridge discovery sent 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:55 AM: debug Sending bridge discovery. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:51 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:48 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:44 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:41 AM: debug Previously found bridge discovered 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:41 AM: debug Discovered bridge 0017882E8762 (192.168.1.7) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:41 AM: debug Discovery Response is [devicetype:04, mac:0017882E8762, networkAddress:C0A80107, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017882e8762, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:25740b45-6718-412a-9a30-36e04d066eaa]. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:40 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:40 AM: debug Previously found bridge discovered 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:40 AM: debug Discovered bridge 0017882E8762 (192.168.1.7) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:40 AM: debug Discovery Response is [devicetype:04, mac:0017882E8762, networkAddress:C0A80107, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017882e8762, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:25740b45-6718-412a-9a30-36e04d066eaa]. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:36 AM: debug Bridge discovery sent 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:36 AM: debug Sending bridge discovery. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:33 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:29 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:26 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:22 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:19 AM: debug Bridge discovery sent 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:19 AM: debug Sending bridge discovery. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:15 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:12 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:08 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:05 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:03 AM: debug Previously found bridge discovered 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:03 AM: debug Discovered bridge 0017882E8762 (192.168.1.7) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:03 AM: debug Discovery Response is [devicetype:04, mac:0017882E8762, networkAddress:C0A80107, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017882e8762, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:25740b45-6718-412a-9a30-36e04d066eaa]. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:02 AM: debug Previously found bridge discovered 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:02 AM: debug Discovered bridge 0017882E8762 (192.168.1.7) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:02 AM: debug Discovery Response is [devicetype:04, mac:0017882E8762, networkAddress:C0A80107, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017882e8762, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:25740b45-6718-412a-9a30-36e04d066eaa]. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:01 AM: debug Bridge discovery sent 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:28:01 AM: debug Sending bridge discovery. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:57 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:49 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:45 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:41 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:38 AM: debug Bridge discovery sent 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:38 AM: debug Sending bridge discovery. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:34 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:31 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:27 AM: debug Sending verify request for 0017882E8762 (192.168.1.7:80) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:25 AM: debug Found new bridge. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:25 AM: debug Discovered bridge 0017882E8762 (192.168.1.7) 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:25 AM: debug Discovery Response is [devicetype:04, mac:0017882E8762, networkAddress:C0A80107, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017882e8762, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:25740b45-6718-412a-9a30-36e04d066eaa]. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:21 AM: debug Bridge discovery sent 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:21 AM: debug Sending bridge discovery. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:03 AM: debug Bridge discovery sent 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:27:03 AM: debug Sending bridge discovery. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:26:45 AM: debug Bridge discovery sent 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:26:45 AM: debug Sending bridge discovery. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:26:32 AM: debug Sending bridge discovery. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:26:32 AM: debug Doing Hue Device Sync! inItems = null 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:26:32 AM: debug Initialize 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:26:32 AM: debug Updated with settings: [:] 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:26:32 AM: debug Sending bridge discovery. 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:26:32 AM: debug Doing Hue Device Sync! inItems = null 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:26:32 AM: debug Initialize 58b02e7f-2307-4406-b3ca-8cca2c31a4df 12:26:32 AM: debug Installed with settings: [:]
Hub number one ff6d09af-b8ff-478f-94d5-f242686f950d 12:29:28 AM: debug parse() description=index:18, mac:0017886CEDCA, ip:C0A80106, port:0050, requestId:81085c4c-a37f-4d77-bcfd-01bc47213595, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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 ff6d09af-b8ff-478f-94d5-f242686f950d 12:29:24 AM: debug parse() description=index:1A, mac:0017886CEDCA, ip:C0A80106, port:0050, requestId:68191b17-80d2-489c-a8af-78bf4ee354a0, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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 ff6d09af-b8ff-478f-94d5-f242686f950d 12:29:21 AM: debug parse() description=index:18, mac:0017886CEDCA, ip:C0A80106, port:0050, requestId:b4232925-85b0-43a7-ade7-1371401ec2a7, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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 ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:35 AM: debug parse() description=index:19, mac:0017886CEDCA, ip:C0A80106, port:0050, headers: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, body:W3siZXJyb3IiOnsidHlwZSI6MSwiYWRkcmVzcyI6Ii9saWdodHMiLCJkZXNjcmlwdGlvbiI6InVuYXV0aG9yaXplZCB1c2VyIn19XQ== ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/12', [name:color, value:#F6FFFE, descriptionText:Color has changed, displayed:true]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/12', [name:level, value:100, descriptionText:Level has changed to 100%]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/11', [name:hue, value:63, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/11', [name:colorTemperature, value:6410, descriptionText:Color temperature has changed]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/14', [name:color, value:#F6FFFE, descriptionText:Color has changed, displayed:true]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/14', [name:saturation, value:30, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/11', [name:level, value:100, descriptionText:Level has changed to 100%]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/13', [name:color, value:#F6FFFE, descriptionText:Color has changed, displayed:true]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/14', [name:hue, value:63, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/12', [name:saturation, value:30, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/12', [name:hue, value:63, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/12', [name:colorTemperature, value:6410, descriptionText:Color temperature has changed]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/13', [name:level, value:100, descriptionText:Level has changed to 100%]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/11', [name:color, value:#F6FFFE, descriptionText:Color has changed, displayed:true]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/12', [name:switch, value:on]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/11', [name:saturation, value:30, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/8', [name:level, value:100, descriptionText:Level has changed to 100%]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/11', [name:switch, value:on]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/8', [name:switch, value:on]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/9', [name:color, value:#F6FFFE, descriptionText:Color has changed, displayed:true]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/9', [name:saturation, value:30, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/9', [name:hue, value:63, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/13', [name:switch, value:on]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/8', [name:saturation, value:30, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/8', [name:color, value:#F6FFFE, descriptionText:Color has changed, displayed:true]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/4', [name:colorTemperature, value:6410, descriptionText:Color temperature has changed]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/8', [name:colorTemperature, value:6410, descriptionText:Color temperature has changed]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/8', [name:hue, value:63, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/5', [name:color, value:#F6FFFE, descriptionText:Color has changed, displayed:true]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/9', [name:colorTemperature, value:6410, descriptionText:Color temperature has changed]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/5', [name:colorTemperature, value:6410, descriptionText:Color temperature has changed]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/9', [name:level, value:100, descriptionText:Level has changed to 100%]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/6', [name:color, value:#F6FFFE, descriptionText:Color has changed, displayed:true]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/9', [name:switch, value:on]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/4', [name:saturation, value:30, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/6', [name:hue, value:63, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/4', [name:hue, value:63, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/6', [name:colorTemperature, value:6410, descriptionText:Color temperature has changed]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/4', [name:level, value:100, descriptionText:Level has changed to 100%]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/4', [name:switch, value:on]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/6', [name:level, value:100, descriptionText:Level has changed to 100%]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/5', [name:hue, value:63, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/7', [name:color, value:#F6FFFE, descriptionText:Color has changed, displayed:true]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/7', [name:hue, value:63, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/5', [name:level, value:100, descriptionText:Level has changed to 100%]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/7', [name:colorTemperature, value:6410, descriptionText:Color temperature has changed]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/5', [name:switch, value:on]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/7', [name:level, value:100, descriptionText:Level has changed to 100%]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/7', [name:switch, value:on]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/1', [name:color, value:#F6FFFE, descriptionText:Color has changed, displayed:true]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/6', [name:switch, value:on]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/1', [name:saturation, value:30, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/1', [name:hue, value:63, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/10', [name:hue, value:63, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/1', [name:colorTemperature, value:6410, descriptionText:Color temperature has changed]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/1', [name:level, value:100, descriptionText:Level has changed to 100%]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/10', [name:colorTemperature, value:6410, descriptionText:Color temperature has changed]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/1', [name:switch, value:on]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/10', [name:level, value:100, descriptionText:Level has changed to 100%]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/10', [name:color, value:#F6FFFE, descriptionText:Color has changed, displayed:true]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/10', [name:switch, value:on]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/10', [name:saturation, value:30, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/2', [name:saturation, value:30, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/2', [name:color, value:#F6FFFE, descriptionText:Color has changed, displayed:true]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/2', [name:hue, value:63, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/2', [name:colorTemperature, value:6410, descriptionText:Color temperature has changed]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/2', [name:level, value:100, descriptionText:Level has changed to 100%]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/2', [name:switch, value:on]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/3', [name:saturation, value:29, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:34 AM: debug createChildDeviceEvent('0017886CEDCA/3', [name:color, value:#F6FBFF, descriptionText:Color has changed, displayed:true]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:33 AM: debug createChildDeviceEvent('0017886CEDCA/3', [name:hue, value:64, descriptionText:Color has changed, displayed:false]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:33 AM: debug createChildDeviceEvent('0017886CEDCA/3', [name:colorTemperature, value:6410, descriptionText:Color temperature has changed]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:33 AM: debug createChildDeviceEvent('0017886CEDCA/3', [name:level, value:100, descriptionText:Level has changed to 100%]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:33 AM: debug createChildDeviceEvent('0017886CEDCA/3', [name:switch, value:on]) ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:33 AM: info allHueDevices: [Hue color lamp 9, Hue lightstrip plus 1, Hue color lamp 2, Hue color lamp 4, Hue color lamp 6, Hue color lamp 3, Hue color lamp 7, Hue color lamp 1, Hue color lamp 8, Hue color lamp 5, Hue color lamp 10, Hue color lamp 13, Hue color lamp 12, Hue color lamp 11] ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:33 AM: debug pollResponseHandler() ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:33 AM: debug checkBridgeStatus() ff6d09af-b8ff-478f-94d5-f242686f950d 12:26:33 AM: debug poll()
hue bub 2 `a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:29:28 AM: debug parse() description=index:17, mac:0017882E8762, ip:C0A80107, port:0050, requestId:88ce47f9-5c48-416e-9b55-9fd7a71728fd, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body:PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+Cjxyb290IHhtbG5zPSJ1cm46c2NoZW1hcy11cG5wLW9yZzpkZXZpY2UtMS0wIj4KPHNwZWNWZXJzaW9uPgo8bWFqb3I+MTwvbWFqb3I+CjxtaW5vcj4wPC9taW5vcj4KPC9zcGVjVmVyc2lvbj4KPFVSTEJhc2U+aHR0cDovLzE5Mi4xNjguMS43OjgwLzwvVVJMQmFzZT4KPGRldmljZT4KPGRldmljZVR5cGU+dXJuOnNjaGVtYXMtdXBucC1vcmc6ZGV2aWNlOkJhc2ljOjE8L2RldmljZVR5cGU+CjxmcmllbmRseU5hbWU+UGhpbGlwcyBodWUgTUIgKDE5Mi4xNjguMS43KTwvZnJpZW5kbHlOYW1lPgo8bWFudWZhY3R1cmVyPlJveWFsIFBoaWxpcHMgRWxlY3Ryb25pY3M8L21hbnVmYWN0dXJlcj4KPG1hbnVmYWN0dXJlclVSTD5odHRwOi8vd3d3LnBoaWxpcHMuY29tPC9tYW51ZmFjdHVyZXJVUkw+Cjxtb2RlbERlc2NyaXB0aW9uPlBoaWxpcHMgaHVlIFBlcnNvbmFsIFdpcmVsZXNzIExpZ2h0aW5nPC9tb2RlbERlc2NyaXB0aW9uPgo8bW9kZWxOYW1lPlBoaWxpcHMgaHVlIGJyaWRnZSAyMDE1PC9tb2RlbE5hbWU+Cjxtb2RlbE51bWJlcj5CU0IwMDI8L21vZGVsTnVtYmVyPgo8bW9kZWxVUkw+aHR0cDovL3d3dy5tZWV0aHVlLmNvbTwvbW9kZWxVUkw+CjxzZXJpYWxOdW1iZXI+MDAxNzg4MmU4NzYyPC9zZXJpYWxOdW1iZXI+CjxVRE4+dXVpZDoyZjQwMmY4MC1kYTUwLTExZTEtOWIyMy0wMDE3ODgyZTg3NjI8L1VETj4KPHByZXNlbnRhdGlvblVSTD5pbmRleC5odG1sPC9wcmVzZW50YXRpb25VUkw+CjxpY29uTGlzdD4KPGljb24+CjxtaW1ldHlwZT5pbWFnZS9wbmc8L21pbWV0eXBlPgo8aGVpZ2h0PjQ4PC9oZWlnaHQ+Cjx3aWR0aD40ODwvd2lkdGg+CjxkZXB0aD4yNDwvZGVwdGg+Cjx1cmw+aHVlX2xvZ29fMC5wbmc8L3VybD4KPC9pY29uPgo8L2ljb25MaXN0Pgo8L2RldmljZT4KPC9yb290Pgo=
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:29:24 AM: debug parse() description=index:19, mac:0017882E8762, ip:C0A80107, port:0050, requestId:88f23e4b-9db4-452f-9fe4-0cb51c29e5d1, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body:PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+Cjxyb290IHhtbG5zPSJ1cm46c2NoZW1hcy11cG5wLW9yZzpkZXZpY2UtMS0wIj4KPHNwZWNWZXJzaW9uPgo8bWFqb3I+MTwvbWFqb3I+CjxtaW5vcj4wPC9taW5vcj4KPC9zcGVjVmVyc2lvbj4KPFVSTEJhc2U+aHR0cDovLzE5Mi4xNjguMS43OjgwLzwvVVJMQmFzZT4KPGRldmljZT4KPGRldmljZVR5cGU+dXJuOnNjaGVtYXMtdXBucC1vcmc6ZGV2aWNlOkJhc2ljOjE8L2RldmljZVR5cGU+CjxmcmllbmRseU5hbWU+UGhpbGlwcyBodWUgTUIgKDE5Mi4xNjguMS43KTwvZnJpZW5kbHlOYW1lPgo8bWFudWZhY3R1cmVyPlJveWFsIFBoaWxpcHMgRWxlY3Ryb25pY3M8L21hbnVmYWN0dXJlcj4KPG1hbnVmYWN0dXJlclVSTD5odHRwOi8vd3d3LnBoaWxpcHMuY29tPC9tYW51ZmFjdHVyZXJVUkw+Cjxtb2RlbERlc2NyaXB0aW9uPlBoaWxpcHMgaHVlIFBlcnNvbmFsIFdpcmVsZXNzIExpZ2h0aW5nPC9tb2RlbERlc2NyaXB0aW9uPgo8bW9kZWxOYW1lPlBoaWxpcHMgaHVlIGJyaWRnZSAyMDE1PC9tb2RlbE5hbWU+Cjxtb2RlbE51bWJlcj5CU0IwMDI8L21vZGVsTnVtYmVyPgo8bW9kZWxVUkw+aHR0cDovL3d3dy5tZWV0aHVlLmNvbTwvbW9kZWxVUkw+CjxzZXJpYWxOdW1iZXI+MDAxNzg4MmU4NzYyPC9zZXJpYWxOdW1iZXI+CjxVRE4+dXVpZDoyZjQwMmY4MC1kYTUwLTExZTEtOWIyMy0wMDE3ODgyZTg3NjI8L1VETj4KPHByZXNlbnRhdGlvblVSTD5pbmRleC5odG1sPC9wcmVzZW50YXRpb25VUkw+CjxpY29uTGlzdD4KPGljb24+CjxtaW1ldHlwZT5pbWFnZS9wbmc8L21pbWV0eXBlPgo8aGVpZ2h0PjQ4PC9oZWlnaHQ+Cjx3aWR0aD40ODwvd2lkdGg+CjxkZXB0aD4yNDwvZGVwdGg+Cjx1cmw+aHVlX2xvZ29fMC5wbmc8L3VybD4KPC9pY29uPgo8L2ljb25MaXN0Pgo8L2RldmljZT4KPC9yb290Pgo=
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:29:21 AM: debug parse() description=index:17, mac:0017882E8762, ip:C0A80107, port:0050, requestId:f782109c-2a5d-4549-a0f3-5c467fa09973, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:29:10 AM: debug parse() description=index:17, mac:0017882E8762, ip:C0A80107, port:0050, requestId:854db5b2-02ba-4ce4-b779-c15be2614a89, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:29:06 AM: debug parse() description=index:19, mac:0017882E8762, ip:C0A80107, port:0050, requestId:4d43f767-5c25-4e34-a423-38f26f210519, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:29:03 AM: debug parse() description=index:17, mac:0017882E8762, ip:C0A80107, port:0050, requestId:384a714e-1d25-4e25-88b5-d72f38b422fa, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:28:59 AM: debug parse() description=index:18, mac:0017882E8762, ip:C0A80107, port:0050, requestId:14a9022a-9453-4e48-899a-5c0bd9636cb4, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:28:52 AM: debug parse() description=index:17, mac:0017882E8762, ip:C0A80107, port:0050, requestId:8206aa4f-8337-4aa9-a58b-8ea5c6fe79c2, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:28:49 AM: debug parse() description=index:18, mac:0017882E8762, ip:C0A80107, port:0050, requestId:5843eacf-5705-49ff-9e01-0a916062ea2a, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:28:45 AM: debug parse() description=index:19, mac:0017882E8762, ip:C0A80107, port:0050, requestId:fdd95ad7-1013-41d5-9b64-aae930a392a8, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:28:40 AM: debug parse() description=index:1B, mac:0017882E8762, ip:C0A80107, port:0050, requestId:c1b4e47a-6e64-40a3-83ab-55c194e96000, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:28:33 AM: debug parse() description=index:17, mac:0017882E8762, ip:C0A80107, port:0050, requestId:621cc2a8-1bce-455e-b6d5-118760a20a9b, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:28:30 AM: debug parse() description=index:1A, mac:0017882E8762, ip:C0A80107, port:0050, requestId:28fed11a-018e-4561-a888-6072351d19eb, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:28:26 AM: debug parse() description=index:17, mac:0017882E8762, ip:C0A80107, port:0050, requestId:63ffbde3-c7d1-4086-8a91-134ca0eba391, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:28:23 AM: debug parse() description=index:18, mac:0017882E8762, ip:C0A80107, port:0050, requestId:afbcb627-e692-41d3-87bf-7626ecb8e5b8, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:28:16 AM: debug parse() description=index:19, mac:0017882E8762, ip:C0A80107, port:0050, requestId:7d61261f-a7f1-4897-bb0b-606ad2c54f19, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:28:12 AM: debug parse() description=index:17, mac:0017882E8762, ip:C0A80107, port:0050, requestId:9b33fb9a-6349-4cd4-8b84-5b3703ab797d, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:28:09 AM: debug parse() description=index:17, mac:0017882E8762, ip:C0A80107, port:0050, requestId:596af467-012d-4cc6-9c6d-9f5e042f13f5, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:28:05 AM: debug parse() description=index:18, mac:0017882E8762, ip:C0A80107, port:0050, requestId:d77a96cd-93b2-466a-a19f-5b14bcbd2244, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl, body: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
a8d1f347-d4e1-4071-823b-c5207e97bcd3 12:27:58 AM: debug parse() description=index:19, mac:0017882E8762, ip:C0A80107, port:0050, requestId:8e0cba6f-b664-49d3-9333-c00b15a27ee6, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LXR5cGU6IHRleHQveG1sDQpDb25uZWN0aW9uOiBLZWVwLUFsaXZl,
You are pulling the antiquated code. Need to pull @tmleafs code from his GitHub. It’s somewhere in the middle of the thread.
@slagle can we get some mod support to edit the OP? The code in @infofiend 's github no longer works and it would be great for any newcomer to see @tmleafs instructions instead.
Hello. Just tried to install all of @tmleafs’ code and I’ve got the smart app installed no problem, but I am running into some problems when trying to get all the device handlers set up. I’ve created the custom device handler for the bridge, but when I edit the device type and click update, nothing changes. The device type for the bridge is still listed as LAN Hue Bridge. Hue B Smart app will not detect the bridge. Any help is greatly appreciated.
Delete your existing bridge and everything else associated. Wipe everything Hue from your ST ecosystem and then reinstall smart app and DTHs. Use the tmleafs Connect SA to set everything up.
I won’t edit someone else’s post without their permission, but, if the code doesn’t work I could close this one, and you all could create a new thread and link to it.
I have created a new thread here [UPDATED DECEMBER 2017] Hue B Smart (Groups & Scenes)
Please close this thread
Sorry, was away for a while. Yes, I am using your version of the code, was still having issues until I made the modifications in my latest post. Attached logs.
Sorry to ask this as have already posted a similar post but with no response. I’m having a lot of problems with my Hue bulbs I was using Hue B Smart sometime ago and found suddenly my bulbs were intermittently unresponsive. I deleted my Hue devices and reset my Hue bridge to factory setting and have now reinstalled my devices (with default dh) but still have the same problems. I have contacted ST support but so far very little response. Any help would be appreciated I want to go bach to Hue B but cant get it to reinstall. I attach the logs of a device using default installation
this normally happens if theres a ghost device. If you PM me your IDE login I can take a look see if I notice anything wrong
After being on the screen that asks to press the button, I do so and then click next, however the screen is completely blank and just says “Hue B Smart” at the top.
If I click done it says “Error saving unnamed page. Please contact SmartApp Developer”
Also if I try again and press the button it sometimes pops up and says “You are not authorized to perform the requested operation”.
I’m using the newest Hue Bridge, have properly uploaded and published both the SmartApp and the Device Handlers, never had any issues like this with previous app installations.
Please seen the latest code here
https://community.smartthings.com/t/updated-november-2017-hue-b-smart-groups-scenes?source_topic_id=60672Smartthings should have this integrated natively. This app/dth along with the one posted by tmleafs can be problematic.
So in an effort to get ST on it you can email (make sure you put “Feature Request” in Subject line) suppprt@smartthings.com and tell the them you want to add groups/scenes/rooms from hue.
The more people that email this the more likely this can become a native feature
