Everyone was requesting it during the last Beta firmware testing they said its in the works but bloody hell its the same as single bulb DH but in the commands instead of bulb its group should take someone at ST a days tops with testing mad its not done yet
Same thing with bluetooth. Went the way of the dodo
Canāt hurt to try
What would be the best way to remove Hue B Smart? Everything was working fine untill i bought a few new bulbs and could not add them to ST.
Ive deleted the Hue B Hub and now cannot seem to get it to work again by reinstalling. My next try would be to completely remove Hue B (smartapp+device handlers) and reinstall them and hopefully find my new bulbs aswell. But now it wont let me remove Hue B because i get the message that it is in use by 1 or more users. When i try to remove the app firstly from my smartphone it gives another error message.
You need to remove the bulbs from all your smart apps that control the bulbs examples webCoRE, Alexa, Google home, ActionTiles etc
That worked, thanks!
I realize this post is extremely old, but Iām having the same issue and am hoping you were able to figure it out. I imagine itās something super simple and assume itās due to the scene being attached to a specific room (8) vs (3) where I am trying to push the scene to. Iāve gone through these threads again and again with no luck.
Any help you can provide would be appreciated.
Did you manage to get round this? Iām experiencing the same problem!
If you have trouble deleting a HBS device (whether it is a bulb, group, or scene), the problem is almost certainly caused by the device still being used by another smartapp, a ST routine or scene, or by a SHM function.
To determine whatās going on, click the device in question in the ST mobile app, then go to the deviceās SmartApps tab, and remove the device from all of the smartapps listed. Also check your routines and SHM. Once you have disassociated it from every thing, you should be able to remove the HBS device.
Butā¦ if you still cannot, then try this - open the IDE and go to the Devices Tab. Click on the device in question, and scroll down the device page to the āIn Use Byā section. Remove the HBS device from anything listed there. Again, that should do it.
Also - try deleting the device directly from the IDE if you canāt uninstall from the HBS smartapp in the ST mobile app. The IDE should provide you with the some info as to whatās going on.
Im having a problem finding my devices. Ive uninstalled all of the native hue applications and the Hue B smart finds the bridge and has searched for devices for over an hour now
When you say youāve uninstalled the SmartApps - have you also uninstalled the devices themselves?
Post a log of what happens when HBS searches for your bulbs.
Need help - all of a sudden I canāt access my bridges. When I select a bridge the spinning icon appears for a while but doesnāt go through to the next screen. I have 4 bridges installed that were working fine for the last 6 months that I now canāt access.
Can you post or pm the log of one of your bridges?
Hi Tony, this is all I got just now waiting 5 mins in the live logs -
5a26cea9-19df-4145-b724-0466631a5e5d 12:22:40 PM: debug *********** JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2 ********
5a26cea9-19df-4145-b724-0466631a5e5d 12:22:40 PM: debug *********** 192.168.0.18:80 ********
5a26cea9-19df-4145-b724-0466631a5e5d 12:22:40 PM: debug Initialize Bridge [ip:192.168.0.18, username:JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2, deviceId:001788205D5A]
5a26cea9-19df-4145-b724-0466631a5e5d 12:22:40 PM: trace Bridge discovering all items on Hue hub.
Hi Tony, this is from the events list -
Date Source Type Name Value User Displayed Text
2018-06-25 12:27:42.642 PM AEST
moments ago DEVICE itemDiscovery 737585b8-b45c-430c-91c8-81453ā¦ Hue Bridge Garage (192.168.0.18) item discovery is 737585b8-b45c-430c-91c8-81453da89866
2018-06-25 12:27:40.509 PM AEST
moments ago COMMAND discoverItems discoverItems command was sent to Hue Bridge Garage (192.168.0.18)
2018-06-25 12:27:40.494 PM AEST
moments ago DEVICE username JmIYWCMHsZirHCZ3tJeNhI7mSkuXKā¦ Hue Bridge Garage (192.168.0.18) username is JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2
2018-06-25 12:27:40.486 PM AEST
moments ago DEVICE networkAddress 192.168.0.18 Hue Bridge Garage (192.168.0.18) network address is 192.168.0.18
2018-06-25 12:27:40.478 PM AEST
moments ago DEVICE idNumber 001788205D5A Hue Bridge Garage (192.168.0.18) id number is 001788205D5A
2018-06-25 12:27:40.412 PM AEST
moments ago APP_COMMAND discoverItems Hue B Smart sent discoverItems command to Hue Bridge Garage (192.168.0.18)
2018-06-25 12:22:45.905 PM AEST
6 minutes ago DEVICE itemDiscovery 737585b8-b45c-430c-91c8-81453ā¦ Hue Bridge Garage (192.168.0.18) item discovery is 737585b8-b45c-430c-91c8-81453da89866
2018-06-25 12:22:40.512 PM AEST
6 minutes ago COMMAND discoverItems discoverItems command was sent to Hue Bridge Garage (192.168.0.18)
2018-06-25 12:22:40.497 PM AEST
6 minutes ago DEVICE username JmIYWCMHsZirHCZ3tJeNhI7mSkuXKā¦ Hue Bridge Garage (192.168.0.18) username is JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2
2018-06-25 12:22:40.490 PM AEST
6 minutes ago DEVICE networkAddress 192.168.0.18 Hue Bridge Garage (192.168.0.18) network address is 192.168.0.18
2018-06-25 12:22:40.482 PM AEST
6 minutes ago DEVICE idNumber 001788205D5A Hue Bridge Garage (192.168.0.18) id number is 001788205D5A
2018-06-25 12:22:40.415 PM AEST
6 minutes ago APP_COMMAND discoverItems Hue B Smart sent discoverItems command to Hue Bridge Garage (192.168.0.18)
2018-06-25 12:17:42.438 PM AEST
11 minutes ago DEVICE itemDiscovery 737585b8-b45c-430c-91c8-81453ā¦ Hue Bridge Garage (192.168.0.18) item discovery is 737585b8-b45c-430c-91c8-81453da89866
2018-06-25 12:17:40.536 PM AEST
11 minutes ago COMMAND discoverItems discoverItems command was sent to Hue Bridge Garage (192.168.0.18)
2018-06-25 12:17:40.520 PM AEST
11 minutes ago DEVICE username JmIYWCMHsZirHCZ3tJeNhI7mSkuXKā¦ Hue Bridge Garage (192.168.0.18) username is JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2
2018-06-25 12:17:40.512 PM AEST
11 minutes ago DEVICE networkAddress 192.168.0.18 Hue Bridge Garage (192.168.0.18) network address is 192.168.0.18
2018-06-25 12:17:40.503 PM AEST
11 minutes ago DEVICE idNumber 001788205D5A Hue Bridge Garage (192.168.0.18) id number is 001788205D5A
2018-06-25 12:17:40.416 PM AEST
11 minutes ago APP_COMMAND discoverItems Hue B Smart sent discoverItems command to Hue Bridge Garage (192.168.0.18)
2018-06-25 12:12:42.594 PM AEST
16 minutes ago DEVICE itemDiscovery 737585b8-b45c-430c-91c8-81453ā¦ Hue Bridge Garage (192.168.0.18) item discovery is 737585b8-b45c-430c-91c8-81453da89866
2018-06-25 12:12:40.462 PM AEST
16 minutes ago COMMAND discoverItems discoverItems command was sent to Hue Bridge Garage (192.168.0.18)
2018-06-25 12:12:40.447 PM AEST
16 minutes ago DEVICE username JmIYWCMHsZirHCZ3tJeNhI7mSkuXKā¦ Hue Bridge Garage (192.168.0.18) username is JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2
2018-06-25 12:12:40.439 PM AEST
16 minutes ago DEVICE networkAddress 192.168.0.18 Hue Bridge Garage (192.168.0.18) network address is 192.168.0.18
2018-06-25 12:12:40.431 PM AEST
16 minutes ago DEVICE idNumber 001788205D5A Hue Bridge Garage (192.168.0.18) id number is 001788205D5A
2018-06-25 12:12:40.367 PM AEST
16 minutes ago APP_COMMAND discoverItems Hue B Smart sent discoverItems command to Hue Bridge Garage (192.168.0.18)
2018-06-25 12:07:46.183 PM AEST
21 minutes ago DEVICE itemDiscovery 737585b8-b45c-430c-91c8-81453ā¦ Hue Bridge Garage (192.168.0.18) item discovery is 737585b8-b45c-430c-91c8-81453da89866
2018-06-25 12:07:40.783 PM AEST
21 minutes ago COMMAND discoverItems discoverItems command was sent to Hue Bridge Garage (192.168.0.18)
2018-06-25 12:07:40.765 PM AEST
21 minutes ago DEVICE username JmIYWCMHsZirHCZ3tJeNhI7mSkuXKā¦ Hue Bridge Garage (192.168.0.18) username is JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2
2018-06-25 12:07:40.758 PM AEST
21 minutes ago DEVICE networkAddress 192.168.0.18 Hue Bridge Garage (192.168.0.18) network address is 192.168.0.18
2018-06-25 12:07:40.749 PM AEST
21 minutes ago DEVICE idNumber 001788205D5A Hue Bridge Garage (192.168.0.18) id number is 001788205D5A
2018-06-25 12:07:40.677 PM AEST
21 minutes ago APP_COMMAND discoverItems Hue B Smart sent discoverItems command to Hue Bridge Garage (192.168.0.18)
2018-06-25 12:02:42.467 PM AEST
26 minutes ago DEVICE itemDiscovery 737585b8-b45c-430c-91c8-81453ā¦ Hue Bridge Garage (192.168.0.18) item discovery is 737585b8-b45c-430c-91c8-81453da89866
2018-06-25 12:02:40.573 PM AEST
26 minutes ago COMMAND discoverItems discoverItems command was sent to Hue Bridge Garage (192.168.0.18)
2018-06-25 12:02:40.559 PM AEST
26 minutes ago DEVICE username JmIYWCMHsZirHCZ3tJeNhI7mSkuXKā¦ Hue Bridge Garage (192.168.0.18) username is JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2
2018-06-25 12:02:40.553 PM AEST
26 minutes ago DEVICE networkAddress 192.168.0.18 Hue Bridge Garage (192.168.0.18) network address is 192.168.0.18
2018-06-25 12:02:40.546 PM AEST
26 minutes ago DEVICE idNumber 001788205D5A Hue Bridge Garage (192.168.0.18) id number is 001788205D5A
2018-06-25 12:02:40.484 PM AEST
26 minutes ago APP_COMMAND discoverItems Hue B Smart sent discoverItems command to Hue Bridge Garage (192.168.0.18)
2018-06-25 11:57:42.714 AM AEST
31 minutes ago DEVICE itemDiscovery 737585b8-b45c-430c-91c8-81453ā¦ Hue Bridge Garage (192.168.0.18) item discovery is 737585b8-b45c-430c-91c8-81453da89866
2018-06-25 11:57:40.614 AM AEST
31 minutes ago COMMAND discoverItems discoverItems command was sent to Hue Bridge Garage (192.168.0.18)
2018-06-25 11:57:40.597 AM AEST
31 minutes ago DEVICE username JmIYWCMHsZirHCZ3tJeNhI7mSkuXKā¦ Hue Bridge Garage (192.168.0.18) username is JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2
2018-06-25 11:57:40.589 AM AEST
31 minutes ago DEVICE networkAddress 192.168.0.18 Hue Bridge Garage (192.168.0.18) network address is 192.168.0.18
2018-06-25 11:57:40.581 AM AEST
31 minutes ago DEVICE idNumber 001788205D5A Hue Bridge Garage (192.168.0.18) id number is 001788205D5A
2018-06-25 11:57:40.500 AM AEST
31 minutes ago APP_COMMAND discoverItems Hue B Smart sent discoverItems command to Hue Bridge Garage (192.168.0.18)
2018-06-25 11:52:45.997 AM AEST
36 minutes ago DEVICE itemDiscovery 737585b8-b45c-430c-91c8-81453ā¦ Hue Bridge Garage (192.168.0.18) item discovery is 737585b8-b45c-430c-91c8-81453da89866
2018-06-25 11:52:40.402 AM AEST
36 minutes ago COMMAND discoverItems discoverItems command was sent to Hue Bridge Garage (192.168.0.18)
2018-06-25 11:52:40.389 AM AEST
36 minutes ago DEVICE username JmIYWCMHsZirHCZ3tJeNhI7mSkuXKā¦ Hue Bridge Garage (192.168.0.18) username is JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2
2018-06-25 11:52:40.384 AM AEST
36 minutes ago DEVICE networkAddress 192.168.0.18 Hue Bridge Garage (192.168.0.18) network address is 192.168.0.18
2018-06-25 11:52:40.378 AM AEST
36 minutes ago DEVICE idNumber 001788205D5A Hue Bridge Garage (192.168.0.18) id number is 001788205D5A
2018-06-25 11:52:40.310 AM AEST
36 minutes ago APP_COMMAND discoverItems Hue B Smart sent discoverItems command to Hue Bridge Garage (192.168.0.18)
2018-06-25 11:47:43.295 AM AEST
41 minutes ago DEVICE itemDiscovery 737585b8-b45c-430c-91c8-81453ā¦ Hue Bridge Garage (192.168.0.18) item discovery is 737585b8-b45c-430c-91c8-81453da89866
2018-06-25 11:47:41.396 AM AEST
41 minutes ago COMMAND discoverItems discoverItems command was sent to Hue Bridge Garage (192.168.0.18)
2018-06-25 11:47:41.381 AM AEST
41 minutes ago DEVICE username JmIYWCMHsZirHCZ3tJeNhI7mSkuXKā¦ Hue Bridge Garage (192.168.0.18) username is JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2
2018-06-25 11:47:41.375 AM AEST
41 minutes ago DEVICE networkAddress 192.168.0.18 Hue Bridge Garage (192.168.0.18) network address is 192.168.0.18
2018-06-25 11:47:41.369 AM AEST
41 minutes ago DEVICE idNumber 001788205D5A Hue Bridge Garage (192.168.0.18) id number is 001788205D5A
2018-06-25 11:47:41.307 AM AEST
41 minutes ago APP_COMMAND discoverItems Hue B Smart sent discoverItems command to Hue Bridge Garage (192.168.0.18)
2018-06-25 11:42:42.325 AM AEST
46 minutes ago DEVICE itemDiscovery 737585b8-b45c-430c-91c8-81453ā¦ Hue Bridge Garage (192.168.0.18) item discovery is 737585b8-b45c-430c-91c8-81453da89866
2018-06-25 11:42:40.677 AM AEST
46 minutes ago COMMAND discoverItems discoverItems command was sent to Hue Bridge Garage (192.168.0.18)
2018-06-25 11:42:40.660 AM AEST
46 minutes ago DEVICE username JmIYWCMHsZirHCZ3tJeNhI7mSkuXKā¦ Hue Bridge Garage (192.168.0.18) username is JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2
2018-06-25 11:42:40.653 AM AEST
46 minutes ago DEVICE networkAddress 192.168.0.18 Hue Bridge Garage (192.168.0.18) network address is 192.168.0.18
2018-06-25 11:42:40.643 AM AEST
46 minutes ago DEVICE idNumber 001788205D5A Hue Bridge Garage (192.168.0.18) id number is 001788205D5A
2018-06-25 11:42:40.575 AM AEST
46 minutes ago APP_COMMAND discoverItems Hue B Smart sent discoverItems command to Hue Bridge Garage (192.168.0.18)
2018-06-25 11:37:42.568 AM AEST
51 minutes ago DEVICE itemDiscovery 737585b8-b45c-430c-91c8-81453ā¦ Hue Bridge Garage (192.168.0.18) item discovery is 737585b8-b45c-430c-91c8-81453da89866
2018-06-25 11:37:40.734 AM AEST
51 minutes ago COMMAND discoverItems discoverItems command was sent to Hue Bridge Garage (192.168.0.18)
2018-06-25 11:37:40.716 AM AEST
51 minutes ago DEVICE username JmIYWCMHsZirHCZ3tJeNhI7mSkuXKā¦ Hue Bridge Garage (192.168.0.18) username is JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2
2018-06-25 11:37:40.708 AM AEST
51 minutes ago DEVICE networkAddress 192.168.0.18 Hue Bridge Garage (192.168.0.18) network address is 192.168.0.18
2018-06-25 11:37:40.699 AM AEST
51 minutes ago DEVICE idNumber 001788205D5A Hue Bridge Garage (192.168.0.18) id number is 001788205D5A
2018-06-25 11:37:40.630 AM AEST
51 minutes ago APP_COMMAND discoverItems Hue B Smart sent discoverItems command to Hue Bridge Garage (192.168.0.18)
2018-06-25 11:32:42.234 AM AEST
56 minutes ago DEVICE itemDiscovery 737585b8-b45c-430c-91c8-81453ā¦ Hue Bridge Garage (192.168.0.18) item discovery is 737585b8-b45c-430c-91c8-81453da89866
2018-06-25 11:32:40.434 AM AEST
56 minutes ago COMMAND discoverItems discoverItems command was sent to Hue Bridge Garage (192.168.0.18)
2018-06-25 11:32:40.420 AM AEST
56 minutes ago DEVICE username JmIYWCMHsZirHCZ3tJeNhI7mSkuXKā¦ Hue Bridge Garage (192.168.0.18) username is JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2
2018-06-25 11:32:40.414 AM AEST
56 minutes ago DEVICE networkAddress 192.168.0.18 Hue Bridge Garage (192.168.0.18) network address is 192.168.0.18
2018-06-25 11:32:40.409 AM AEST
56 minutes ago DEVICE idNumber 001788205D5A Hue Bridge Garage (192.168.0.18) id number is 001788205D5A
2018-06-25 11:32:40.351 AM AEST
56 minutes ago APP_COMMAND discoverItems Hue B Smart sent discoverItems command to Hue Bridge Garage (192.168.0.18)
2018-06-25 11:27:42.454 AM AEST
1 hour ago DEVICE itemDiscovery 737585b8-b45c-430c-91c8-81453ā¦ Hue Bridge Garage (192.168.0.18) item discovery is 737585b8-b45c-430c-91c8-81453da89866
2018-06-25 11:27:40.642 AM AEST
1 hour ago COMMAND discoverItems discoverItems command was sent to Hue Bridge Garage (192.168.0.18)
2018-06-25 11:27:40.623 AM AEST
1 hour ago DEVICE username JmIYWCMHsZirHCZ3tJeNhI7mSkuXKā¦ Hue Bridge Garage (192.168.0.18) username is JmIYWCMHsZirHCZ3tJeNhI7mSkuXKLfzJRPX3Ij2
Hi Everyone. Could someone please help me set this up? I added all code to my ST account successfully however I am unable to link the bridge to the smart app. It attempts to locate it but it times out after about a minute when it doesnāt find it. Is there anything special that a need to do?
Iāve been able to access my bridges again, except for one - I can get into the next menu after selecting the bridge, but there is nothing in it except the option āDelete bridge [IP] and devicesā. The usual options to select bulbs, scenes, groups are missing. Help!
So I assume if I add this to SmartThings it will no longer work directly in the Hue App.
The Hue app will always work - this only connects SmartThings to the hue bridge. However, if you change the state of any light using the Hue app, those changes will not be synced with SmartThings.
Lost communication with my hub and the Hue hub.
11:25:06 AM: error java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Integer @line 239 (parse)
Itās not refreshing devices and it wonāt find new devices
I am trying to add two new blooms. It adds in the hue app but not Hue B smart app.
This was in the logs
9:21:51 PM: errorjava.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Integer @line 239 (parse
