You’ve got more than one “definition”, plus a few other things. I recommend getting a clean copy of the code. Once you do that, replace this: (should be line 40 in the clean copy of the code)
I have one of the Greenwave 6 outlet strips and I got it to work a while back, but then didn’t use it for a while. I unplugged it and then today decided to use it and it no longer seems to work. I can’t get it to reset or do much of anything. Has anyone else seen this behavior or have any ideas how to fix it? I want to add it to my SmartThings setup, but can’t seem to figure out what to do.
As a side rant, I am so annoyed how hard it is to add Zwave devices to SmartThings. I have several that don’t seem to work at all. I can’t reset them or add them. When they work, it is great, but about 25% of the time I can’t figure out what to do and I just end up tossing them. The Greenwave looks like it will be tossed. It doesn’t even work with the switch on the strip.
Sorry to resurrect this old thread.
Im using @marcosb DTH successfully, with one minor issue.
Power reporting - Im seeing what looks to be the correct power being reported (in the app) for each of the channels.
But Im trying to log the power used for those channels, and Im only seeing it generated in the parent.
And the readings seem to rotate between the channels (if more than one plugged in) - is that how its designed?
