Dale,
Thanks for putting in the time to get this cool app up and running. I am new to all this. I have a GE 12730 switch and was using it with the device handler jscgs350 : My GE Fan Control Switch and that works well. ( it was only a week ago and my first customer handler). I came across you post and have a Aeon Labs MultiSensor 6 and the 12730 fan switch to changed my device handler to your recommended ChadCK : Z-Wave Smart Fan Control. I have added your code to My SmartApp seciont
configured as follows for Version:1.0.160603
Temperature Sensor: Physical Device :Aeon Labs MultiSensor 6
Fan Control Device: Physical Device : GE12730
Room Setpoint Temp: 75
Fan Differential Temp: "default"
Motion Device: "blank"
Enable Ceiling Fan Thermostat?: "default"
Assign a Name: FamilyRoomFan
Mode: “blank”
The error I get is as follows
grails.validation.ValidationException: Validation Error(s) occurred during save():
Field error in object ‘physicalgraph.app.InstalledSmartAppData’ on
field ‘name’: rejected value []; codes
[physicalgraph.app.InstalledSmartAppData.name.blank.error.physicalgraph.app.InstalledSmartAppData.name,physicalgraph.app.InstalledSmartAppData.name.blank.error.name,physicalgraph.app.InstalledSmartAppData.name.blank.error.java.lang.String,physicalgraph.app.InstalledSmartAppData.name.blank.error,installedSmartAppData.name.blank.error.physicalgraph.app.InstalledSmartAppData.name,installedSmartAppData.name.blank.error.name,installedSmartAppData.name.blank.error.java.lang.String,installedSmartAppData.name.blank.error,physicalgraph.app.InstalledSmartAppData.name.blank.physicalgraph.app.InstalledSmartAppData.name,physicalgraph.app.InstalledSmartAppData.name.blank.name,physicalgraph.app.InstalledSmartAppData.name.blank.java.lang.String,physicalgraph.app.InstalledSmartAppData.name.blank,installedSmartAppData.name.blank.physicalgraph.app.InstalledSmartAppData.name,installedSmartAppData.name.blank.name,installedSmartAppData.name.blank.java.lang.String,installedSmartAppData.name.blank,blank.physicalgraph.app.InstalledSmartAppData.name,blank.name,blank.java.lang.String,blank];
arguments [name,class physicalgraph.app.InstalledSmartAppData]; default
message [{0} cannot be blank]
Any guidance on what I am doing wrong or where to look.
And again Thanks for creating the app.
Regards
-j
