@tgauchat @slagle @krlaframboise I was able to isolate when this problem first started to appear. When I wasn’t using multiple pages the IDE simulator did not produce that cryptic error. When I made the change to using dynamic pages the error presented itself in the IDE simulator so I can’t test it anymore. I am copying the last error free version and then the dynamic page version that produces the cryptic error. Can you guys see what I did wrong in making the dynamic pages?
ERROR in this version. Remember this error only shows up when I try to use the simulator. I can save the app OK and publish it but can no longer test it in the IDE simulator.
Virtual Thermostat for 3 Speed Ceiling Fan Control
Copyright 2016 Dale Coffing
This smartapp provides automatic control of Low, Medium, High speeds of a ceiling fan using
any temperature sensor with optional motion override.
It requires two hardware devices; any temperature sensor and a dimmer type smart fan controller
such as the GE 12730 or Leviton VRF01-1LX
Change Log
2016-5-30 added dynamicPages for instructions, icon at copyright
2016-5-19 code clean up only
2016-5-17 fanDiffTemp input changed to use enum with preselected values to overcome range:"0.1..5.0" bug
2016-5-16 fixed typo with motion to motionSensor in hasBeenRecentMotion()
fixed IDE integration with ST by making another change to file name specifics.
2016-5-15 fixed fan differenial decimal point error by removing range: "1..99", removed all fanDimmer.setLevel(0)
added iconX3Url, reworded preferences, rename evaluate to tempCheck for clarity,
best practices to utilize initialize() method & replace motion with motionSensor,
2016-5-14 Fan temperature differential variable added, best practices to change sensor to tempSensor,
2016-5-13 best practices to replace ELSE IF for SWITCH statements on fan speeds, removed emergency temp control
2016-5-12 added new icons for 3SFC, colored text in 3SFC125x125.png and 3sfc250x250.png
2016-5-6 (e)minor changes to text, labels, for clarity, (^^^e)default to NO-Manual for thermostat mode
2016-5-5c clean code, added current ver section header, allow for multiple fan controllers,
replace icons to ceiling fan, modify name from Control to Thermostat
2016-5-5b @krlaframboise change to bypasses the temperatureHandler method and calls the tempCheck method
with the current temperature and setpoint setting
2016-5-5 autoMode added for manual override of auto control/*
2016-5-4b cleaned debug logs, removed heat-cool selection, removed multiple stages
2016-5-3 fixed error on not shutting down, huge shout out to my bro Stephen Coffing in the logic formation
Known Behavior from original Virtual Thermostat code
-(fixed) when SP is updated, temp control isn't evaluated immediately, an event must trigger like change in temp, motion
- if load is previously running when smartapp is loaded, it isn't evaluated immediately to turn off when SP>CT
Thanks to @krlaframboise, @MikeMaxwell for help in solving issues for a first time coder. @MichaelS for icon background
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
in compliance with the License. You may obtain a copy of the License at: www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
for the specific language governing permissions and limitations under the License.
definition(
name: "3 Speed Ceiling Fan Thermostat",
namespace: "dcoffing",
author: "Dale Coffing",
description: "Automatic control for 3 Speed Ceiling Fan using Low, Medium, High speeds with any temperature sensor.",
category: "My Apps",
iconUrl: "https://raw.githubusercontent.com/dcoffing/SmartThingsPublic/master/smartapps/dcoffing/3-speed-ceiling-fan-thermostat.src/3scft125x125.png",
iconX2Url: "https://raw.githubusercontent.com/dcoffing/SmartThingsPublic/master/smartapps/dcoffing/3-speed-ceiling-fan-thermostat.src/3scft250x250.png",
iconX3Url: "https://raw.githubusercontent.com/dcoffing/SmartThingsPublic/master/smartapps/dcoffing/3-speed-ceiling-fan-thermostat.src/3scft250x250.png",
preferences {
page(name: "mainPage")
page(name: "aboutPage")
def mainPage() {
dynamicPage(name: "mainPage", title: "Select your devices and settings", uninstall: true) {
section("Select a temperature sensor to control the fan..."){
input "tempSensor", "capability.temperatureMeasurement",
multiple:false, title: "Temperature Sensor", required: true
section("Select the ceiling fan control hardware..."){
input "fanDimmer", "capability.switchLevel",
multiple:false, title: "Fan Control device", required: true
section("Enter the desired room temperature (ie 72.5)..."){
input "setpoint", "decimal", title: "Room Setpoint Temp", required: true
section("Enter the desired differential temp between fan speeds (default=1.0)..."){
input "fanDiffTempString", "enum", title: "Fan Differential Temp", options: ["0.5","1.0","1.5","2.0"], required: false
section("Enable ceiling fan thermostat only if motion is detected at (optional, leave blank to not require motion)..."){
input "motionSensor", "capability.motionSensor", title: "Select Motion device", required: false
section("Turn off ceiling fan when there's been no movement for..."){
input "minutes", "number", title: "Minutes?", required: false
section("Select ceiling fan operating mode desired (default to 'YES-Auto'..."){
input "autoMode", "enum", title: "Enable Ceiling Fan Thermostat?", options: ["NO-Manual","YES-Auto"], required: false
section ("Advanced Options") {
label title: "Assign a name", required: false
mode title: "Set for specific mode(s)", required: false
section("Version Info, Instructions") {
// VERSION
paragraph "3 Speed Ceiling Fan Thermostat \n"+"Version:1.0.160530 \n"+"Copyright © 2016 Dale Coffing", image: "https://raw.githubusercontent.com/dcoffing/SmartThingsPublic/master/smartapps/dcoffing/3-speed-ceiling-fan-thermostat.src/3scft125x125.png"
href (name: "aboutPage",
title: none,
description: "Tap to get application information and instructions.",
image: "https://raw.githubusercontent.com/dcoffing/SmartThingsPublic/master/smartapps/dcoffing/3-speed-ceiling-fan-thermostat.src/info.png",
required: false,
page: "aboutPage"
def aboutPage() {
dynamicPage(name: "aboutPage", title: none, install: true, uninstall: true) {
section("Instructions") {
paragraph textHelp()
def installed() {
log.debug "def INSTALLED with settings: ${settings}"
initialize()
def updated() {
log.debug "def UPDATED with settings: ${settings}"
unsubscribe()
initialize()
handleTemperature(tempSensor.currentTemperature) //call handleTemperature to bypass temperatureHandler method
def initialize() {
log.debug "def INITIALIZE with settings: ${settings}"
subscribe(tempSensor, "temperature", temperatureHandler) //call temperatureHandler method when any reported change to "temperature" attribute
if (motionSensor) {
subscribe(motionSensor, "motion", motionHandler) //call the motionHandler method when there is any reported change to the "motion" attribute
//Event Handler Methods
def temperatureHandler(evt) {
log.debug "temperatureHandler called: $evt"
handleTemperature(evt.doubleValue)
log.debug "temperatureHandler evt.doubleValue : $evt"
def handleTemperature(temp) { //
log.debug "handleTemperature called: $evt"
def isActive = hasBeenRecentMotion()
if (isActive) {
//motion detected recently
tempCheck(temp, setpoint)
log.debug "handleTemperature ISACTIVE($isActive)"
else {
fanDimmer.off()
def motionHandler(evt) {
if (evt.value == "active") {
//motion detected
def lastTemp = tempSensor.currentTemperature
log.debug "motionHandler ACTIVE($isActive)"
if (lastTemp != null) {
tempCheck(lastTemp, setpoint)
} else if (evt.value == "inactive") { //testing to see if evt.value is indeed equal to "inactive" (vs evt.value to "active")
//motion stopped
def isActive = hasBeenRecentMotion() //define isActive local variable to returned true or false
log.debug "motionHandler INACTIVE($isActive)"
if (isActive) {
if (lastTemp != null) { //lastTemp not equal to null (value never been set)
else {
fanDimmer.off()
private tempCheck(currentTemp, desiredTemp)
log.debug "TEMPCHECK#1(CT=$currentTemp,SP=$desiredTemp,FD=$fanDimmer.currentSwitch,FD_LVL=$fanDimmer.currentLevel, automode=$autoMode,FDTstring=$fanDiffTempString, FDTvalue=$fanDiffTempValue)"
//convert Fan Diff Temp input enum string to number value and if user doesn't select a Fan Diff Temp default to 1.0
def fanDiffTempValue = (settings.fanDiffTempString != null && settings.fanDiffTempString != "") ? Double.parseDouble(settings.fanDiffTempString): 1.0
//if user doesn't select autoMode then default to "YES-Auto"
def autoModeValue = (settings.autoMode != null && settings.autoMode != "") ? settings.autoMode : "YES-Auto"
def LowDiff = fanDiffTempValue*1
def MedDiff = fanDiffTempValue*2
def HighDiff = fanDiffTempValue*3
log.debug "TEMPCHECK#2(CT=$currentTemp,SP=$desiredTemp,FD=$fanDimmer.currentSwitch,FD_LVL=$fanDimmer.currentLevel, automode=$autoMode,FDTstring=$fanDiffTempString, FDTvalue=$fanDiffTempValue)"
if (autoModeValue == "YES-Auto") {
switch (currentTemp - desiredTemp) {
case { it >= HighDiff }:
// turn on fan high speed
fanDimmer.setLevel(90)
log.debug "HI speed(CT=$currentTemp, SP=$desiredTemp, FD-LVL=$fanDimmer.currentLevel, HighDiff=$HighDiff)"
break //exit switch statement
case { it >= MedDiff }:
// turn on fan medium speed
fanDimmer.setLevel(60)
log.debug "MED speed(CT=$currentTemp, SP=$desiredTemp, FD-LVL=$fanDimmer.currentLevel, MedDiff=$MedDiff)"
break
case { it >= LowDiff }:
// turn on fan low speed
if (fanDimmer.currentSwitch == "off") { // if fan is OFF to make it easier on motor by
fanDimmer.setLevel(90) // starting fan in High speed temporarily then
fanDimmer.setLevel(30, [delay: 3000]) // change to Low speed after 3 seconds
log.debug "LO speed after HI 3secs(CT=$currentTemp, SP=$desiredTemp, FD-LVL=$fanDimmer.currentLevel, LowDiff=$LowDiff)"
} else {
fanDimmer.setLevel(30) //fan is already running, not necessary to protect motor
} //set Low speed immediately
log.debug "LO speed immediately(CT=$currentTemp, SP=$desiredTemp, FD-LVL=$fanDimmer.currentLevel, LowDiff=$LowDiff)"
break
default:
// check to see if fan should be turned off
if (desiredTemp - currentTemp >= 0 ) { //below or equal to setpoint, turn off fan, zero level
fanDimmer.off()
log.debug "below SP+Diff=fan OFF (CT=$currentTemp, SP=$desiredTemp, FD-LVL=$fanDimmer.currentLevel, FD=$fanDimmer.currentSwitch,autoMode=$autoMode,)"
log.debug "autoMode YES-MANUAL? else OFF(CT=$currentTemp, SP=$desiredTemp, FD-LVL=$fanDimmer.currentLevel, FD=$fanDimmer.currentSwitch,autoMode=$autoMode,)"
private hasBeenRecentMotion()
def isActive = false
if (motionSensor && minutes) {
def deltaMinutes = minutes as Long
if (deltaMinutes) {
def motionEvents = motionSensor.eventsSince(new Date(now() - (60000 * deltaMinutes)))
log.trace "Found ${motionEvents?.size() ?: 0} events in the last $deltaMinutes minutes"
if (motionEvents.find { it.value == "active" }) {
isActive = true
else {
isActive = true
isActive
private def textHelp() {
def text =
"This smartapp provides automatic control of Low, Medium, High speeds of a"+
" ceiling fan using any temperature sensor based on its' temperature setpoint"+
" turning on each speed automatically in 1 degree differential increments (adjustable)."+
" For example, if the desired room temperature setpoint is 72, the low speed"+
" turns on first at 73, the medium speed turns on at 74, the high speed turns"+
" on at 75. And vice versa on decreasing temperature until at 72 the ceiling"+
" fan turns off. \n\n" +
"A notable feature is when low speed is initially requested from"+
" the off condition, high speed is turned on briefly to overcome the startup load"+
" then low speed is engaged. This mimics the pull chain switches that most"+
" manufacturers use by always starting in high speed. \n\n"+
"A motion option turns off automatic mode when no motion is detected. A thermostat"+
" mode option will disable the smartapp and pass control to manual control.\n\n"+
"@ChadCK's 'Z-Wave Smart Fan Control Custom Device Handler' along with hardware"+
" designed specifically for motor control such as the GE 12730 Z-Wave Smart Fan Control or"+
" Leviton VRF01-1LX works well together with this smartapp."
I thought it might help to show the version that worked in the IDE Simulator.
This version below does NOT produce the error. This was the version that doesn’t use multiple pages.
Change Log
Thanks to @krlaframboise, @MikeMaxwell for help and knowledge in solving issues for a first time coder.
definition(
preferences {
section ("3 Speed Ceiling Fan Thermostat; Version:1.0.160519") { } //ver format 1.0.YYMMDD
def installed() {
initialize()
def updated() {
unsubscribe()
initialize()
def initialize() {
if (motionSensor) {
if (isActive) {
else {
fanDimmer.off()
//motion detected
//motion stopped
if (isActive) {
else {
fanDimmer.off()
// log.debug "fanDiffTempValue BEFORE convert String (FDTstring=$fanDiffTempString, FDTvalue=$fanDiffTempValue)"
// log.debug "fanDiffTempValue AFTER convert String (FDTstring=$fanDiffTempString, FDTvalue=$fanDiffTempValue)"
break
} else {
break
default:
fanDimmer.off()
} //end of switch statement
} // end of IF (autoModeValue...
if (deltaMinutes) {
// log.debug "HASBEENRECENTMOTION ($deltaMinutes, $motionEvents, $motion.eventsSince, $deltaMinutes)"
isActive = true
else {
isActive = true
isActive
