matt
((Possibly not the Matt you're looking for))
January 5, 2017, 3:29am
1
NVIDIA’s CEO just announced integration with SmartThings in the new version of their gaming console/set-top box, Shield, due out later this spring.
I didn’t get a picture, but some guy on Twitter did.
Will this be one of the first uses of the bluetooth antenna in STV2 hmmmm maybe
Crussell
(Chris )
January 5, 2017, 3:57am
3
I know that its alpha and beta info (the open source parts anyway) are available if you are a registered developer of a certain standing. Using Jetson to do it so the end result should be impressive!
matt
January 5, 2017, 4:12am
4
So I might actually have to migrate to a V2 hub? That might be a bigger hurdle than the price tag on the Shield.
mrmrmrmr
(ilker Aktuna)
June 5, 2019, 4:11pm
5
see here :
Hi,
I could not find any decent integration between Smartthings and Shield TV/ Fire TV, so I worked my way on it.
I’ve just published it on Github , here:
Just now, I don’t have much time to write here, but all required description is available on Github.
Copying from there:
There are 2 components:
a modified Android TV keyboard with a REST API which can receive certain commands from network
Device handler for Samsung Smartthings platform
Keyboard application is ready (precompiled) in the release-apk folder. You can also download it directly from Google Play Store at: https://play.google.com/store/apps/details?id=com.aktuna.tv.keyboard Device handler is available as groovy source code in the device-handler folder.
The keyboard application can be used also for other platforms o…
maybe it is what you are looking for…
