Nuki Home Set NFC (Deadbolt) Launches: The First Aliro-Certified Lock with Samsung Digital Home Key
We’re thrilled to announce that the Nuki Home Set NFC (Deadbolt) is now available on Samsung.com as the first Aliro-certified lock hitting the market. This marks the official launch of the Samsung Digital Home Key experience for your front door.
Samsung’s tap-to-unlock experience is powered by Aliro Home Key certification, an industry standard created to make digital access to your home more secure, reliable, and interoperable across devices.
We are excited to welcome Nuki as the first Aliro-certified lock on Samsung.com, with locks from other partners like Aqara, ULTRALOQ, and Schlage coming soon.
What makes the Nuki Home Set NFC (Deadbolt) unique?
While many smart locks rely on Bluetooth or Wi-Fi apps, the Nuki Smart Lock (5th generation) (paired with the Nuki Keypad 2 NFC) utilizes the same secure NFC technology you use for mobile payments.
  • Tap. Unlock. Walk In: Your Galaxy phone becomes your key. Just tap your device against the Nuki Keypad 2 NFC to unlock.
  • Samsung Wallet Integration: Your Digital Home Key lives securely in Samsung Wallet, protected by advanced encryption.
  • Matter-Ready: This set requires a compatible Matter hub. Explore all Samsung built-in hubs here.
Power Routines and Access Control
Because this integrates natively via Matter and SmartThings, the Unlock or Lock event can trigger your local routines.
  • Welcome Home: Instantly turn on lights and disarm the security system the moment you tap.
  • Departure: Switch your home to Away mode and adjust the thermostat as the deadbolt slides shut.
  • Granular Control: You decide exactly who has access and when, with the ability to share or revoke digital keys instantly via the SmartThings app.
Ready to upgrade?
You can check out the full technical specs, and pick up the Nuki Home Set NFC (Deadbolt) today on Samsung.com.
Want to know more? Read the Samsung Wallet Aliro launch announcement and check out our blog to learn how to unlock your home’s potential.
