Aqara Smart Lock U400 Deluxe Kit Launches on Samsung.com: An Aliro-Certified Lock with Samsung Digital Home Key
We’re happy to announce that the Aqara Smart Lock U400 Deluxe Kit is now available on Samsung.com as one of the first Aliro-certified locks hitting the market. This supports the launch of the Samsung Digital Home Key experience for your front door.
Samsung’s tap-to-unlock experience is powered by Aliro Home Key certification, an industry standard created to make digital access to your home more secure, reliable, and interoperable across devices.
What Makes the Aqara Smart Lock U400 Unique?
While many smart locks rely on Bluetooth or Wi-Fi apps, the Aqara Smart Lock utilizes the same secure NFC technology you use for mobile payments. It features 9 flexible unlocking methods and an IP65 waterproof rating designed to withstand the elements.
  • Matter-over-Thread Support: It communicates natively via Thread to your existing SmartThings Thread Border Router (built into the Aeotec Smart Home Hub 2, plus select Samsung TVs and Family Hub refrigerators). Explore all Samsung built-in hubs here.
  • Hands-Free UWB Unlocking: In addition to standard NFC tap-to-unlock via your digital home key in Samsung Wallet, the U400 supports Ultra-Wideband (UWB) proximity detection for hands-free access as you approach the door.
  • Biometrics & Physical Fail-Safes: Includes an integrated fingerprint scanner (storing up to 50 prints locally), an anti-peep keypad, and a mechanical key option.
  • Optimized Battery & Emergency Power : It uses a 4,880 mAh rechargeable Li-ion battery (lasting up to 6 months per charge) and features an external USB-C port for emergency power over-ride.
  • Samsung Wallet Integration: Your Digital Home Key lives securely in Samsung Wallet, protected by advanced encryption.
SmartThings Routines with Local Control
Because the U400 runs locally over your Thread mesh network, its state changes (Lock, Unlock, or specific user PIN entries) can trigger responsive SmartThings Routines without hitting the cloud:
  • Coming Home Routine: Unlocking the door via your Galaxy phone’s Samsung Wallet key can instantly disarm your SmartThings Home, turn on entryway lighting, adjust your thermostat, and control your Samsung TV.
  • Secure Guest Access: Need to let in a dog walker or contractor? You can issue secure digital keys directly through Samsung Wallet or manage unique, temporary PIN codes without handing out physical keys.
  • Gyroscope-Based Auto-Lock: Ensure your door latches. The lock utilizes an internal gyroscope to automatically and reliably throw the deadbolt once the door is completely closed.
Ready to upgrade?
Check out the full technical specs and pick up the Aqara U400 Deluxe Kit today on Samsung.com.
Want to know more? Read the Samsung Wallet Aliro Launch announcement and check out our blog to learn how to unlock your home’s potential.
What does the Deluxe Kit offer over and above the standard Aqara U400 that I can buy on Amazon for a lower price?
Great question! The base version has lighter materials and a plastic interior thumbturn. The Deluxe Kit has a heavier upgraded Zinc alloy exterior, metal thumbturn, and overall a more premium feel. Plus a 2nd battery is included vs. just 1 in the base version pack.
But core smart home features are identical in both so the Deluxe Kit is more of a hardware upgrade, plus the extra battery.
I’m curious as to how digital keys are shared directly through the Samsung Wallet app as well as when UWB will be released. It was said to be April 2026 in the footnotes for Samsung Digital Home Key.
Does this work with smart guest lock access? I have nurses for special needs child and everyone has a code. My other question can anyone who is given access be able to have the lock open similiar to how the new achlage with Uwb will work?
What I’ve seen from the Matter locks that have been introduced recently is that code management has moved from the SLGA smartapp to the device itself. Two new capabilities have been introduced to replace the old lockCodes capability, namely:
  - id: lockUsers
    version: 1
  - id: lockCredentials
    version: 1
So, per the Matter spec, a lock can have multiple users and multiple credential types. The entry of the values for those capabilities has moved to the device card (detail) tab of the device.
The Aqara does support UWB allowing for proximity unlocking/locking.
So then there would be no need for slga?
Not if the lock supports the new capabilities. This was mentioned last year in a topic on the Aqara U200 Lock with a reference to PR for the Matter lock driver:
|The SLGA will be sunset at the end of this year. New door lock devices to be added in the future, including Aqara products, do not support SLGA. Instead, you can use Manage users in the detail plugin view to manage your user’s credentials. FYI, Aqara Smart Lock U200 uses lock-user-pin profile.|
I didn’t know that the s l g a will be sunsetting at the end of this year. I have nursing for my child.So the most important thing is, by having was those lock codes, I can set time frames, and it makes it easy for me to track everybody when they come in, etc. I just hope that I have that ability with the matter to do the same thing. Also, my lock is z wave, and i’m trying to move away from all the z wave i have, and this is one that should be easy to do…i hope.
SLGA doesn’t support scheduled lock codes currently so I’m not sure what you mean by “time frames”. Matter does support access schedules for credentials so as long as a lock implements that capability, you could get date/time bounded credentials which is something not available in ST today.
SLGA is unlikely to be sunset for all devices since that would require reworking all the existing Z-Wave and Zigbee drivers. I suspect the comment in the PR is specific to Matter locks.
PR for Z-Wave, PR for Zigbee.
Interesting. That’s gonna affect a lot of folks who are using Phil’s custom driver for the Schlage locks.
Aqara does support UWB unlocking, but it currently isn’t supported on Samsung devices nor any other Android devices.
That seems strange since Samsung is selling the lock on their website.
https://news.samsung.com/global/samsung-wallet-launches-digital-home-key-for-smart-door-locks
As you’ll see here NFC unlocking is supported and UWB should be supported as well, but it has yet to be implemented. April 2026 was when it was meant to begin, based on the footnotes from Samsung, and Aqara’s own page states Q2 2026 for Samsung devices.
This is Q2 2026. In fact, we are just 8 days away from Q3.
Yeah, unfortunately I haven’t seen any beta firmware for the U400, so I don’t imagine we’ll get it within Q2.
When is Samsung going to enable UWB unlocking?
Hopefully soon, but what I’m not sure about is who’s responsibility it is. Anytime I’ve spoke to Samsung support they’ve stated Aqara has to enable it via a firmware update and anytime I’ve spoken to Aqara they’ve stated they’re already on Aliro 1.0 therefore it’s Samsung’s responsibility.
