Not able to install SmartApp on Smartthings App
  1. The lock was reset before the app was installed (required if you’re programming the same codes through LUM that were previously programmed on the lock) - No, I didn’t reset the lock before the app was installed. I erased the factory programmed access codes before the app was installed though
  2. Give it about a minute complete the programming after pressing Save/Done on the main page and exiting the app. You can see the programming status on the Manage Users page (reload the page to get the latest status)
  3. (Very important) Make sure your lock is within 15ft of a buffering device (not the hub). See this topic for details: FAQ: why would I need another beaming repeater if my zwave lock is already close to my hub?
    Question on this, does this mean that if I want to reset or create an access code for a renter, that the lock has to be within 15 feet of a buffering device? Is the smart things smart hub not a buffering device? What is considered a buffering device?
