I’ve bought 22 new 4 gang buttons (Zemismart) but the model and manufacturer are different from the version that worked.
The existing device handler is for model TS0044 and the new buttons that i have are model TS004F so i tried changing the code but this does nothing for the newer buttons.
My older ones (TS0044) work perfect. the device handler recognises the model and therefor wants to control it but it doenst respond.
Here the information of the button that works and the new one that doesnt, like you can see it hasnt connected and therefor has not created a metric.
What i see is that the Route does nothing for the new one and the older ones stand " This Device (146A) ↔ Control Center" and the new one doesnt have that.
if anyone can help, just what i do wrong or how i can change the device handler and update it so it works aswell.
Change the name to something else. There’s an error that can occur when you use the same name as one of the stock DTHs, I don’t know all the details, but it’s easy enough to avoid the problem.
Looking around, it seems that the TS004F might need further code changes. You could try removing the clusters from the fingerprint to see it if helps get it plumbed in but that seems unlikely to actually make it useful.
