Purchased this Zemismart switch which the page described as " Zemismart New Design Zigbee 3.0 Wall Push Light Switch SmartThings Control US AU Physical Switches" But unable to make SmartThings see it. Does anyone have tried this and success? I have a feeling that it is WiFi switch not Zigbee.
They make a separate Wi-Fi model using the same outer case, so maybe you were just shipped the wrong one.
WiFi
Hope it is the case you said. Waiting for their reply mail…
Thanks.
Not even as a Thing?
Have you tried the official DH?
And what if you try to search for wifi with your phone or use the SmartLife app, as that should be a Tuya switch, if I remember correctly.
What it says on the back does it has b/g/n marking there?
That must be a wifi one. That 802.11 b/g/n is definitely wifi. Try the SmartLife app an it will pair. But not with SmartThings…
I have two of these installed - the zigbee version and they work fine in smartthings
@romant did you have trouble getting switch 2 and 3 to work? switch 1 works fine but the child devices won’t work.
I have those switches and they work seamlessly in my house. 1 gang, 2 gang and 3 gang.
I can get 1 gang out of the two to work. How did U get the other gangs to work?
I used a Device Handler then moved to an Edge Driver by @Mariano_Colmenarejo
Link: [Beta] Zigbee Edge Driver compatible with Lidl, Ecosmart, Osram, SmartThings & Others
