New User Light Switch Query (UK)
Evening all,
Firstly, sorry of this has been asked a hundred times, but trying to get my head around everything as i am new to ST.
Been reading a lot but kinda have an info overload …
So… i want to change my lounge light switch. I have a standard UK double switch, each one controlling one ceiling light. Am i right in thinking i need something like the TKB TZ37 , so that i have a switch that will control 2 separate loads ?
Thinking about it… each ceiling light fixture has 7 led bulbs in, will this affect the type of switch needed ?
Thanks in advance…
I’m right assuming you’re in the uk from your post.
Personally I have a thing for LightwaveRF but thats not suitable for your query.
The man that springs to mind because I think a Fibaro will do the trick and @anon36505037 is your man. Hope you don’t mind Mr Fibaro guru. :wink:
Thank you, yup am in the UK… only just got the ST 2 days ago, and picked up 2 Fibaro motion sensors to go with it. Got these working and have the general idea about how it all works, but knowing the right components to buy seems a little trickier when it comes to electrical connections… thanks again…
Great stuff, thank you.
No stud wall in this case, and happy with a straight on/off, so will choose accordingly and look to place in the ceiling as i know i have plenty of room there.
Thanks again, is appreciated.
Gentleman… thank you, is appreciated
The TKB TZ37 should work as long as you have a neutral wire at the switchbox. The Fibaro micros that @anon36505037 mentioned will give you more options for both wiring and switch selection so I would agree those are generally a better choice for the UK. :sunglasses:
Happy UK Fibaro user here.
Just wish the price was a bit lower - dimmers hovering around £39 on Amazon at the mo.
Double relay switch granted is better value as it’ll do two lights.
Hi Robin, I have an Aeotec Nano Dimmer I’ve been trying to get to work to do exactly this. But it doesn’t in any incarnation!
More than happy to get a Fibaro Dimmer 2 instead. Could you provide more details on how you configured the scene ID control, please? As I have a Swiid cord switch crying out for it! :slight_smile:
Excellent, thank you, I’ll let you know how I get on soon!
