New to home automation, recommendations on devices/approach for monitoring vacation property
Hi, brand new to the home automation space, so please be easy on me. I am hoping to tap into the experts here on how to approach.
I want to remotely monitor a vacation property to understand if the temp falls below a specific range, upstairs and down, water leak sensor by water heater, possibly one other location.
From what I read I would require a hub, leak sensor or two and one or more multi purpose sensors. I am considering replacing the smoke alarms, is there any alarms that have the temp sensor in them to eliminate additional devices. Any other recommendations on how to approach? The heat is electric baseboard so no real option for wifi controlled.
Appreciate your help.
Gary
Welcome! I’ve moved this to ā€œprojectsā€ so you can get individualized responses based on your own needs and preferences.
First, we’ll need to know a little bit more about what the set up is like. Smartthings is a cloud-based system, which means if the Internet is down or even if the SmartThings cloud is not available, The system cannot send notifications. It doesn’t have a cellular option. So the first question is whether that’s going to meet your needs for a second home location. A cloud-based system is fine for some people, but it’s not a good match for a location where Internet connection is spotty. Or if you need to get alerts when the power is off.
As far as replacing the smoke alarms, you probably won’t need to do that. One popular option is to get a Wi-Fi connected acoustic sensor which can hear when the smoke alarms go off. (In the US, residential smoke alarms manufactured in the last 15 years or so all use the same beep pattern.) then it sends you a message that it heard the alarms. It can also distinguish between a water leak alarm and a smoke alarm so send you a different message depending on what is going on.
I have the Leeo acoustic sensor and like it a lot. It typically costs $50, but sometimes goes on sale for $35 or so. We only need one to cover our whole house, but it’s a single floor home. You might need one for each floor, you just have to test that. But basically it just has to be within hearing range of your alarms.
The Leeo itself can send you an alert when the temperature goes outside of your desired range, so that’s good. But it only works when your power is on because it’s a plug-in device, so it may not meet all of your use cases.
Integration with SmartThings is through the free IFTTT service. The Leeo does require Internet availability, but so does smartthings if you want to get notifications. Also know that you don’t need to have smartthings at all to use the Leeo, so if all you want is to get notifications when the temperature falls or your smoke alarms go off or a leak alarm goes off, you can get the $50 Leo, a couple of $4 leak detectors, and use your existing smoke detectors and you’ll be all set. Again, with the understanding that the Leeo can only send you messages if your Wi-Fi and power are working at the Leeo’s location.
There are lots of other options for the various other things you asked about, but I just wanted to mention that one upfront. :sunglasses:
In addition, you might take a look at the project reports on the quick browse list in the community created wiki. The ā€œget startedā€ list has a lot of introductory information, although you might not want to start going through that until you have more of an idea of what you’re going to try to do. There’s a lot of information there.
There’s also a ā€œsecond homesā€ list which might have some topics of interest, including discussions of remote management and handling alerts from multiple locations.
http://thingsthataresmart.wiki/index.php?title=How_to_Quick_Browse_the_Community-Created_SmartApps_Forum_Section#Quick_Browse_Links_for_Project_Reports.2FQuestions
Thanks for the warm welcome and moving the topic to the correct place.
I think my needs are pretty simple, not looking for anything too advanced.
having just internet will be suitable vs. cellular, so if internet/power
goes out for a bit, it won’t be a big deal, assuming it resynchs when it
recovers.
Condo rules require is to leave things at 50, so its really only a matter
if a heater breaks or thermostats goes down for a long enough period of
time and it gets super cold. It was 5 degrees F over the weekend.
For the smokes/co2, let me clarify, there is only one old, old smoke alarm
,not even CO2, so I would be replacing them anyway.thinking one in kitchen,
one in living room and one at top of stairs that ajoins the bedrooms
I’ll do some research on the Wi-Fi connected acoustic sensor and options,
and Leeo, I was more trying to see if I had to purchase a smoke alarm
anyway and I could get it to do temp sensing then that would be one less
device to buy.
let me know if these clarifications help to sort out the original request.
thanks again for the help.
Gary
If it’s a condo, and you share a wall with any neighbors, that’s good, because it means any really serious issues would probably be noticed by somebody. Some vacation homes are pretty isolated from neighbors.
On the other hand, if you did use a Leeo, it would likely trigger if any of your neighbors alarms went off. That might be OK with you, just depends on what you’re looking for. The Leeo can’t tell you which specific alarm is going off, just that it hears one.
You can always use a combination of temperature sensors (e.g. Monoprice or ZooZ which are cheap) and a Mini Plug Switch to control your electric baseboard and combine it with CoRE or a SmartApp like this to remotely manage it.
Halo Smoke/CO detectors are supported by SmartThings and have a temperature sensor built in.
https://www.lowes.com/pd/Halo-Weather-Alerts-Ac-Hardwired-Photoelectric-Sensor-Combination-Smoke-and-Carbon-Monoxide-Detector-Battery-Back-Up/1000116115
