New siren device recommended?
both of my Vision Z-Wave Plus Alarm Siren are out of services (cannot seem to power it up even with new battery) and I’m looking for a replacement. Do you guys have any recommendation of what I should get or any DIY project? Thank you for your help in advance!
What country are you in? The device selection does vary. :sunglasses:
thank you for the quick response. .I’m living in US
Zigbee and LOUD? Frient smoke detector.
Dedicated siren, but only loud? Woox siren with an additional feature:
Thank you for the recommendation. The device looks nice but I cannot find it available in US? Too bad :frowning:
The Neo Cool Cam from AliExpress is available in the US and works with SmartThings. Caution, they also sell a WiFi version which won’t work with SmartThings.
Does this work with @Mariano_Colmenarejo 's driver to allow it also to detect power outage? Or it uses the 000 cluster like many Tuya products?
I it has the EF00 cluster and uses the Personal Tuya Driver.
My NeoTuya Siren arrived and I paired it Smartthings with “Personal Tuya Devices” driver. I can choose different ring tone and manually trigger it on and off. However, when I set it as the siren for Smartthings security app, it won’t trigger… any idea?
Can you post some screenshots from the Home Monitor settings?
Yes… here some screenshots from my smartthings app… this is how i tested it
  1. Make sure all the doors are closed and sensors are normal
  2. Set alarm to “Armed (Stay)”
  3. Open the Kitchen door
  4. Got intruder alert notification but no siren.
thank you again!
@Kevinlam I think you can use the vEdge creator and create a sound sensor which will show up in the SHM. You can then create routines to call the virtual sound sensor when the NeoTuya siren triggers.
I’m using this method and its working for me.
Thank you for your response! Kind if new to this. vEdge creator? I will look into it once I got back home
It’s TA Austin’s driver. Refer this post to set it up and you should be fine.
[ST Edge] vEdge Creator: a virtual device generator for end users - Devices & Integrations / Community Created Device Types - SmartThings Community
perfect! thank you so much!
