New Iris Zigbee Water sensor (3315-L)
Lowes has a new sensor, just hit my store. It’s a new version of a leak sensor. Small rectangular device unlike the Utilitech version. It’s ZigBee HA 1.2 compliant.
Can’t upload images from my my phone, but looks good.
I’m not seeing it. Do you have a product code? Price? Thx.
$34.99
Iris White Indoor Flood Sensor (Works with Iris) Item #: 782303 | Model #: 3315-L
Thanks for adding the link and image!
off topic but sort of the same. I picked up another contact sensor from lowes and noticed it was different. looks the same but it may have blue and green light where the old one did not and the model # 3320-L.
It paired up to ST and seems to be working
… maybe it was just new packaging i don’t know… the lowes person pointed it that they were different
scratch that after further inspection i see no difference the associate was correct the box is different but seems the product is the same…
I picked up one of these new water leak sensors yesterday. It is basically identical hardware to the official SmartThings device.
For anyone interested, I modified the ST water leak device handler to work with the Iris model. Works great for me.
Here is the code:
 *  Copyright 2016 SmartThings
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not
 *  use this file except in compliance with the License. You may obtain a copy
 *  of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software
 *  distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
 *  WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
 *  License for the specific language governing permissions and limitations
 *  under the License.
 *  --Summary of Changes from Source--
 *  This is a SmartSense Moisture Sensor code template that has been
 *  modified to function with the Iris-branded version of the sensor.
metadata {
	definition (name: "Iris Moisture Sensor",namespace: "jdhalbert", author: "SmartThings") {
		capability "Configuration"
		capability "Battery"
		capability "Refresh"
		capability "Temperature Measurement"
		capability "Water Sensor"
		capability "Health Check"
		command "enrollResponse"
		fingerprint inClusters: "0000,0001,0003,0402,0500,0020,0B05", outClusters: "0019", manufacturer: "CentraLite",  model: "3315-L", deviceJoinName: "Water Leak Sensor"
	simulator {
	preferences {
		section {
			image(name: 'educationalcontent', multiple: true, images: [
				"http://cdn.device-gse.smartthings.com/Moisture/Moisture1.png",
				"http://cdn.device-gse.smartthings.com/Moisture/Moisture2.png",
				"http://cdn.device-gse.smartthings.com/Moisture/Moisture3.png"
		section {
			input title: "Temperature Offset", description: "This feature allows you to correct any temperature variations by selecting an offset. Ex: If your sensor consistently reports a temp that's 5 degrees too warm, you'd enter '-5'. If 3 degrees too cold, enter '+3'.", displayDuringSetup: false, type: "paragraph", element: "paragraph"
			input "tempOffset", "number", title: "Degrees", description: "Adjust temperature by this many degrees", range: "*..*", displayDuringSetup: false
	tiles(scale: 2) {
		multiAttributeTile(name:"water", type: "generic", width: 6, height: 4){
			tileAttribute ("device.water", key: "PRIMARY_CONTROL") {
				attributeState "dry", label: "Dry", icon:"st.alarm.water.dry", backgroundColor:"#ffffff"
				attributeState "wet", label: "Wet", icon:"st.alarm.water.wet", backgroundColor:"#53a7c0"
		valueTile("temperature", "device.temperature", inactiveLabel: false, width: 2, height: 2) {
			state "temperature", label:'${currentValue}°',
				backgroundColors:[
					[value: 31, color: "#153591"],
					[value: 44, color: "#1e9cbb"],
					[value: 59, color: "#90d2a7"],
					[value: 74, color: "#44b621"],
					[value: 84, color: "#f1d801"],
					[value: 95, color: "#d04e00"],
					[value: 96, color: "#bc2323"]
		valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
			state "battery", label:'${currentValue}% battery', unit:""
		standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "default", action:"refresh.refresh", icon:"st.secondary.refresh"
		main (["water", "temperature"])
		details(["water", "temperature", "battery", "refresh"])
	log.debug "description: $description"
	Map map = [:]
	if (description?.startsWith('catchall:')) {
		map = parseCatchAllMessage(description)
	else if (description?.startsWith('read attr -')) {
		map = parseReportAttributeMessage(description)
	else if (description?.startsWith('temperature: ')) {
		map = parseCustomMessage(description)
	else if (description?.startsWith('zone status')) {
		map = parseIasMessage(description)
	log.debug "Parse returned $map"
	def result = map ? createEvent(map) : null
	if (description?.startsWith('enroll request')) {
		List cmds = enrollResponse()
		log.debug "enroll response: ${cmds}"
		result = cmds?.collect { new physicalgraph.device.HubAction(it) }
	return result
private Map parseCatchAllMessage(String description) {
	Map resultMap = [:]
	def cluster = zigbee.parse(description)
	if (shouldProcessMessage(cluster)) {
		switch(cluster.clusterId) {
			case 0x0001:
				resultMap = getBatteryResult(cluster.data.last())
				break
            case 0x0402:
                // temp is last 2 data values. reverse to swap endian
                String temp = cluster.data[-2..-1].reverse().collect { cluster.hex1(it) }.join()
                def value = getTemperature(temp)
                resultMap = getTemperatureResult(value)
                break
    return resultMap
private boolean shouldProcessMessage(cluster) {
	// 0x0B is default response indicating message got through
	// 0x07 is bind message
	boolean ignoredMessage = cluster.profileId != 0x0104 ||
		cluster.command == 0x0B ||
		cluster.command == 0x07 ||
		(cluster.data.size() > 0 && cluster.data.first() == 0x3e)
	return !ignoredMessage
private Map parseReportAttributeMessage(String description) {
	Map descMap = (description - "read attr - ").split(",").inject([:]) { map, param ->
		def nameAndValue = param.split(":")
		map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
	log.debug "Desc Map: $descMap"
	Map resultMap = [:]
	if (descMap.cluster == "0402" && descMap.attrId == "0000") {
		def value = getTemperature(descMap.value)
	else if (descMap.cluster == "0001" && descMap.attrId == "0020") {
		resultMap = getBatteryResult(Integer.parseInt(descMap.value, 16))
	return resultMap
private Map parseCustomMessage(String description) {
	Map resultMap = [:]
		def value = zigbee.parseHATemperatureValue(description, "temperature: ", getTemperatureScale())
	return resultMap
private Map parseIasMessage(String description) {
	List parsedMsg = description.split(' ')
	String msgCode = parsedMsg[2]
	Map resultMap = [:]
	switch(msgCode) {
		case '0x0020': // Closed/No Motion/Dry
			resultMap = getMoistureResult('dry')
			break
		case '0x0021': // Open/Motion/Wet
			resultMap = getMoistureResult('wet')
			break
		case '0x0022': // Tamper Alarm
			break
		case '0x0023': // Battery Alarm
			break
		case '0x0024': // Supervision Report
			 log.debug 'dry with tamper alarm'
			break
		case '0x0025': // Restore Report
			log.debug 'water with tamper alarm'
			break
		case '0x0026': // Trouble/Failure
			break
		case '0x0028': // Test Mode
			break
	return resultMap
def getTemperature(value) {
	def celsius = Integer.parseInt(value, 16).shortValue() / 100
	if(getTemperatureScale() == "C"){
		return celsius
	} else {
		return celsiusToFahrenheit(celsius) as Integer
private Map getBatteryResult(rawValue) {
	log.debug "Battery rawValue = ${rawValue}"
	def linkText = getLinkText(device)
	def result = [
		value: '--',
		translatable: true
	def volts = rawValue / 10
	if (rawValue == 0 || rawValue == 255) {}
	else {
		if (volts > 3.5) {
			result.descriptionText = "{{ device.displayName }} battery has too much power: (> 3.5) volts."
		else {
			if (device.getDataValue("manufacturer") == "SmartThings") {
				volts = rawValue // For the batteryMap to work the key needs to be an int
				def batteryMap = [28:100, 27:100, 26:100, 25:90, 24:90, 23:70,
								  22:70, 21:50, 20:50, 19:30, 18:30, 17:15, 16:1, 15:0]
				def minVolts = 15
				def maxVolts = 28
				if (volts < minVolts)
					volts = minVolts
				else if (volts > maxVolts)
					volts = maxVolts
				def pct = batteryMap[volts]
				if (pct != null) {
					result.value = pct
					result.descriptionText = "{{ device.displayName }} battery was {{ value }}%"
			else {
				def minVolts = 2.1
				def maxVolts = 3.0
				def pct = (volts - minVolts) / (maxVolts - minVolts)
				result.value = Math.min(100, (int) pct * 100)
	return result
private Map getTemperatureResult(value) {
	log.debug 'TEMP'
	if (tempOffset) {
		def offset = tempOffset as int
		def v = value as int
		value = v + offset
    def descriptionText
    if ( temperatureScale == 'C' )
    	descriptionText = '{{ device.displayName }} was {{ value }}°C'
    else
    	descriptionText = '{{ device.displayName }} was {{ value }}°F'
	return [
		value: value,
		descriptionText: descriptionText,
        translatable: true
private Map getMoistureResult(value) {
	log.debug "water"
    def descriptionText
    if ( value == "wet" )
    	descriptionText = '{{ device.displayName }} is wet'
    else
    	descriptionText = '{{ device.displayName }} is dry'
	return [
		value: value,
        translatable: true
def refresh() {
	log.debug "Refreshing Temperature and Battery"
	def refreshCmds = [
		"st rattr 0x${device.deviceNetworkId} 1 0x402 0", "delay 200",
		"st rattr 0x${device.deviceNetworkId} 1 1 0x20", "delay 200"
	return refreshCmds + enrollResponse()
def configure() {
	sendEvent(name: "checkInterval", value: 7200, displayed: false)
	String zigbeeEui = swapEndianHex(device.hub.zigbeeEui)
	log.debug "Configuring Reporting, IAS CIE, and Bindings."
	def configCmds = [
		"zcl global write 0x500 0x10 0xf0 {${zigbeeEui}}", "delay 200",
		"send 0x${device.deviceNetworkId} 1 1", "delay 500",
		"zdo bind 0x${device.deviceNetworkId} ${endpointId} 1 1 {${device.zigbeeId}} {}", "delay 500",
		"zcl global send-me-a-report 1 0x20 0x20 30 21600 {01}",		//checkin time 6 hrs
		"zdo bind 0x${device.deviceNetworkId} ${endpointId} 1 0x402 {${device.zigbeeId}} {}", "delay 500",
		"zcl global send-me-a-report 0x402 0 0x29 30 3600 {6400}",
	return configCmds + refresh() // send refresh cmds as part of config
def enrollResponse() {
	log.debug "Sending enroll response"
		//Resending the CIE in case the enroll request is sent before CIE is written
		"send 0x${device.deviceNetworkId} 1 ${endpointId}", "delay 500",
		//Enroll Response
		"raw 0x500 {01 23 00 00 00}",
		"send 0x${device.deviceNetworkId} 1 1", "delay 200"
private getEndpointId() {
	new BigInteger(device.endpointId, 16).toString()
private hex(value) {
	new BigInteger(Math.round(value).toString()).toString(16)
private String swapEndianHex(String hex) {
	reverseArray(hex.decodeHex()).encodeHex()
private byte[] reverseArray(byte[] array) {
	int i = 0;
	int j = array.length - 1;
	byte tmp;
	while (j > i) {
		tmp = array[j];
		array[j] = array[i];
		array[i] = tmp;
		j--;
		i++;
	return array
Thanks for this. It’s working well. But, for some reason my device isn’t updating temperature at regular intervals even though it detects moisture fine in the area it’s located. I have to do a manual refresh in the app for the temp update. Any ideas? Is this sensor Zigbee?
It’s ZigBee. It should report hourly at least, more frequent if the temperature changes more than 1 C.
Thanks. I had a hunch based on past experience with an iris contact sensor. I removed it from ST, reset it and then re-added it. It now seems to be updating temp.
Just got it at Lowes and was surprised to see that it is not waterproof!
So it the water are rising I expect to get one alarm before it dies forever, too bad going back to Lowes
Me too. I popped it open and soldered 2 wires to the contact points. Now I can have it up high and safe and set the other ends of the wires down low. I tested it and it works. I have it in my boat to warn me if my bilge pump stops working and the water level gets high. Nice range on this zigbee over the utilitech zwave version.
@jdhalbert Picked up the last 2 Iris sensors at my Lowe’s and your device handler works great. Thanks
Does anyone have an issue with the temperature reporting? I want to put this near my main water valve; it can get really cold in that area so temperature is important.
I just bought one of these this weekend and I am having the same issue with it reporting temperature. Did you get yours to report?? If you did what is the trick. Thanks
All of mine started reporting 0% battery life, even with new batteries. This started a few weeks ago.
Anyone else having this issue?
