New Features
Continuing the discussion from [RELEASE] Qubino Flush 1D Relay, Flush 2 Relays, Flush 1 Relay, & Flush Dimmer:
In thermostat mode the highest cooling set point is 80F. My use case is for an attic exhaust fan. I need the set point to be ambient temperature. Since we live in Texas, the high cooling set point range must be at least 45C/113F, if not 50C/122F.
A great new feature would be to have the set point reference the value from an outdoor temperature sensor. There is no need to keep the fan running at night when the attic temperature reaches ambient temperature.
A nice option for this would be to have an adjustable offset from the temperature sensor reading, for example, have the set point be sensor reading plus 2 degrees.
