Hi All Using Sylvania LEDs with Philips Hue. Everything was working fine, until today, when trying to edit the scenes I have setup in the Smartthings App, it give me a “Network Error” message and does not allow me to save. Obviously I have tested the network, works fine. I’ve also tried downloading the app to my ipad and it gives me the same errors.
Yes, this happens with the new IOS SmartThings app. The classic one won’t let me edit scenes because it says they were created with a more recent version of the app.
If I edit any scene and make any change (even changing the name of it) and hit Save, it says “Network error”. This used to work… the last time I recall using it was a few months ago.
Same problem on new App. Just migrated from Classic ST and regretting it already. Having similar problems with Automation saving errors as well. For me I have to delete and recreate as workaround. I started using scenes given I was encountering save errors on Automations. Both don’t work.
I have a similar issue. I get the Network Error when I try to edit scene icons and particular scenes. I realize it only occurs on scenes that contain device types other than On/off light switches. If I try to edit a scene with a dimmer it will throw the Network Error.
Yep, I hit the wall today with ST when my iPhone presence state has been getting worse and constant auto logoff issues from both my and wife phones, so pending next release I am tearing down all my ST (new) automations (which TBH are inferior) and going back to ST Classic until reliability improves
I’m also having this issue. I have mostly Hue lights but some other things mixed in. I tried basically everything that’s been mentioned here to no affect. Contact with Smartthings support received a response of they will have to have a “team” look in to this.
Everytime I get a network error when trying to update a scene it’s because I have a device included in the scene that I’ve moved/renamed/deleted and the error is resolved by removing or updating the device.
This is so frustrating! I am having the same issue. What is the point of having a smart home that can’t run or save automations? Googling this issue shows that people have had this issue for years now. So hopefully a fix has been found. I would love to know it if someone knows it. Thanks!
This issue has been ongoing for a very long time now. I gave up on smartthings a few months back because of not being able to add automation or scenes. Randomly opened up the (new) app today to see if it had been fixed. To my surprise it worked… once, and then I got the network error haha. Back in the bin it goes.
How can the one main thing they do, automation, be the one thing that consistently isn’t working for a large amount of users?
