Here is the Device Type I am using:
* Nest
* Author: github@pickering.net
* Date: 2014-03-09
* Code: https://gist.github.com/pickerin/9446532
* Modifications:
* * Updated device preferences to ask for ZIP Code
* * Used user provided ZIP Code in the weather fetch (was previously hard coded)
* Nest Direct
* Author: dianoga7@3dgo.net
* Date: 2013-07-18
* Code: https://gist.github.com/Dianoga/6055918
* INSTALLATION
* 1) Create a new device type (https://graph.api.smartthings.com/ide/devices)
* Name: Nest
* Capabilities:
* Polling
* Relative Humidity Measurement
* Thermostat
* Custom Attributes:
* presence
* Custom Commands:
* away
* present
* setPresence
* 2) Create a new device (https://graph.api.smartthings.com/device/list)
* Name: Your Choice
* Device Network Id: Your Choice
* Type: Nest (should be the last option)
* Hub/Group: Leave blank
* 3) Update device preferences
* Click on the new device to see the details.
* Click the edit button next to Preferences
* Fill in your information.
* To find your serial number, login to http://home.nest.com. Click on the thermostat
* you want to control. Under settings, go to Technical Info. Your serial number is
* the second item.
* 4) That's it, you're done.
* Copyright (C) 2013 Brian Steere <dianoga7@3dgo.net>
* Permission is hereby granted, free of charge, to any person obtaining a copy of this
* software and associated documentation files (the "Software"), to deal in the Software
* without restriction, including without limitation the rights to use, copy, modify,
* merge, publish, distribute, sublicense, and/or sell copies of the Software, and to
* permit persons to whom the Software is furnished to do so, subject to the following
* conditions: The above copyright notice and this permission notice shall be included
* in all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
* INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
* PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
* HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
* CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
* OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
preferences {
input("username", "text", title: "Username", description: "Your Nest username (usually an email address)")
input("password", "password", title: "Password", description: "Your Nest password")
input("serial", "text", title: "Serial #", description: "The serial number of your thermostat")
input("zip", "text", title: "ZIP Code", description:"Your home ZIP Code")
// for the UI
metadata {
// Automatically generated. Make future change here.
definition (name: "Nest", author: "smartthings@tbml.org") {
capability "Thermostat"
capability "Polling"
capability "Relative Humidity Measurement"
simulator {
// TODO: define status and reply messages here
tiles {
valueTile("temperature", "device.temperature", width: 2, height: 2, canChangeIcon: true) {
state("temperature", label: '${currentValue}°', unit:"F", backgroundColors: [
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
standardTile("thermostatMode", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
state "heat", label:'${name}', action:"thermostat.off", icon: "st.Weather.weather14", backgroundColor: '#E14902'
state "off", label:'${name}', action:"thermostat.cool", icon: "st.Outdoor.outdoor19"
state "cool", label:'${name}', action:"thermostat.heat", icon: "st.Weather.weather7", backgroundColor: '#003CEC'
standardTile("thermostatFanMode", "device.thermostatFanMode", inactiveLabel: false, decoration: "flat") {
state "auto", label:'${name}', action:"thermostat.fanOn", icon: "st.Appliances.appliances11"
state "on", label:'${name}', action:"thermostat.fanCirculate", icon: "st.Appliances.appliances11"
state "circulate", label:'${name}', action:"thermostat.fanAuto", icon: "st.Appliances.appliances11"
controlTile("coolSliderControl", "device.coolingSetpoint", "slider", height: 1, width: 3, inactiveLabel: false) {
state "setCoolingSetpoint", label:'Set temperarure to', action:"thermostat.setCoolingSetpoint",
backgroundColors:[
valueTile("coolingSetpoint", "device.coolingSetpoint", inactiveLabel: false, decoration: "flat") {
state "default", label:'${currentValue}°', unit:"F", backgroundColor:"#ffffff", icon:"st.appliances.appliances8"
valueTile("humidity", "device.humidity", inactiveLabel: false, decoration: "flat") {
state "default", label:'${currentValue}%', unit:"Humidity"
standardTile("presence", "device.presence", inactiveLabel: false, decoration: "flat") {
state "present", label:'${name}', action:"away", icon: "st.Home.home2"
state "away", label:'${name}', action:"present", icon: "st.Transportation.transportation5"
standardTile("refresh", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
state "default", action:"polling.poll", icon:"st.secondary.refresh"
main "temperature"
details(["temperature", "thermostatMode", "thermostatFanMode", "coolSliderControl", "coolingSetpoint", "humidity", "presence", "refresh"])
// handle commands
def setHeatingSetpoint(temp) {
setTargetTemp(temp);
def setCoolingSetpoint(temp) {
def setTargetTemp(temp) {
api('temperature', ['target_change_pending': true, 'target_temperature': fToC(temp)]) {
sendEvent(name: 'heatingSetpoint', value: temp)
sendEvent(name: 'coolingSetpoint', value: temp)
def off() {
setThermostatMode('off')
def heat() {
setThermostatMode('heat')
def emergencyHeat() {
def cool() {
setThermostatMode('cool')
def setThermostatMode(mode) {
mode = mode == 'emergency heat'? 'heat' : mode
api('thermostat_mode', ['target_change_pending': true, 'target_temperature_type': mode]) {
sendEvent(name: 'thermostatMode', value: mode)
def fanOn() {
setThermostatFanMode('on')
def fanAuto() {
setThermostatFanMode('auto')
def fanCirculate() {
setThermostatFanMode('circulate')
def setThermostatFanMode(mode) {
def modes = [
on: ['fan_mode': 'on'],
auto: ['fan_mode': 'auto'],
circulate: ['fan_mode': 'duty-cycle', 'fan_duty_cycle': 900]
api('fan_mode', modes.getAt(mode)) {
sendEvent(name: 'thermostatFanMode', value: mode)
def away() {
setPresence('away')
def present() {
setPresence('present')
def setPresence(status) {
log.debug "Status: $status"
api('presence', ['away': status == 'away', 'away_timestamp': new Date().getTime(), 'away_setter': 0]) {
sendEvent(name: 'presence', value: status)
def auto() {
log.debug "Executing 'auto'"
def poll() {
log.debug "Executing 'poll'"
api('status', []) {
data.device = it.data.device.getAt(settings.serial)
data.shared = it.data.shared.getAt(settings.serial)
data.structureId = it.data.link.getAt(settings.serial).structure.tokenize('.')[1]
data.structure = it.data.structure.getAt(data.structureId)
data.device.fan_mode = data.device.fan_mode == 'duty-cycle'? 'circulate' : data.device.fan_mode
data.structure.away = data.structure.away? 'away' : 'present'
sendEvent(name: 'humidity', value: data.device.current_humidity)
sendEvent(name: 'temperature', value: cToF(data.shared.current_temperature) as Integer, state: data.device.target_temperature_type)
sendEvent(name: 'thermostatFanMode', value: data.device.fan_mode)
sendEvent(name: 'thermostatMode', value: data.shared.target_temperature_type)
sendEvent(name: 'coolingSetpoint', value: cToF(data.shared.target_temperature) as Integer)
sendEvent(name: 'heatingSetpoint', value: cToF(data.shared.target_temperature) as Integer)
sendEvent(name: 'presence', value: data.structure.away)
def api(method, args = [], success = {}) {
if(!isLoggedIn()) {
log.debug "Need to login"
login(method, args, success)
return
def methods = [
'status': [uri: "/v2/mobile/${data.auth.user}", type: 'get'],
'fan_mode': [uri: "/v2/put/device.${settings.serial}", type: 'post'],
'thermostat_mode': [uri: "/v2/put/shared.${settings.serial}", type: 'post'],
'temperature': [uri: "/v2/put/shared.${settings.serial}", type: 'post'],
'presence': [uri: "/v2/put/structure.${data.structureId}", type: 'post'],
'weather': [uri: "https://home.nest.com/api/0.1/weather/forecast/${settings.zip}", type: 'get']
def request = methods.getAt(method)
log.debug "Logged in"
doRequest(request.uri, args, request.type, success)
// Need to be logged in before this is called. So don't call this. Call api.
def doRequest(uri, args, type, success) {
log.debug "Calling $type : $uri : $args"
if(uri.charAt(0) == '/') {
uri = "${data.auth.urls.transport_url}${uri}"
def params = [
uri: uri,
headers: [
'X-nl-protocol-version': 1,
'X-nl-user-id': data.auth.userid,
'Authorization': "Basic ${data.auth.access_token}"
body: args
if(type == 'post') {
httpPostJson(params, success)
} else if (type == 'get') {
httpGet(params, success)
def login(method = null, args = [], success = {}) {
def params = [
uri: 'https://home.nest.com/user/login',
body: [username: settings.username, password: settings.password]
httpPost(params) {response ->
data.auth = response.data
data.auth.expires_in = Date.parse('EEE, dd-MMM-yyyy HH:mm:ss z', response.data.expires_in).getTime()
log.debug data.auth
api(method, args, success)
def isLoggedIn() {
if(!data.auth) {
log.debug "No data.auth"
return false
def now = new Date().getTime();
return data.auth.expires_in > now
def cToF(temp) {
return temp * 1.8 + 32
def fToC(temp) {
return (temp - 32) / 1.8
