I was trying to modify the code written by @Dianoga to add the ability to set home and away modes for the nest. My initial idea (which you can see below) was to add a simple switch capability where:
“on” -> “present” and “off” -> “away”
This implementation functions as expected through the simulator and device page on the SmartThings app, but when added to the smart app (Smart Lighting to be specific), it proceeds to turn of the thermostat instead, after which it does not respond until physically turned back on. You can see my attempt at coding this below. Any help would be greatly appreciated.
* Nest Direct
* Author: dianoga7@3dgo.net
* Code: https://github.com/smartthings-users/device-type.nest
* INSTALLATION
* 1) Create a new device type (https://graph.api.smartthings.com/ide/devices)
* Name: Nest
* Capabilities:
* Polling
* Relative Humidity Measurement
* Thermostat
* Temperature Measurement
* Presence Sensor
* Sensor
* Custom Attributes:
* temperatureUnit
* Custom Commands:
* away
* present
* setPresence
* heatingSetpointUp
* heatingSetpointDown
* coolingSetpointUp
* coolingSetpointDown
* setFahrenheit
* setCelsius
* 2) If you want to switch from slider controls to buttons, comment out the slider details line and uncomment the button details line.
* 3) Create a new device (https://graph.api.smartthings.com/device/list)
* Name: Your Choice
* Device Network Id: Your Choice
* Type: Nest (should be the last option)
* Hub/Group: Leave blank
* 4) Update device preferences
* Click on the new device to see the details.
* Click the edit button next to Preferences
* Fill in your information.
* To find your serial number, login to http://home.nest.com. Click on the thermostat
* you want to control. Under settings, go to Technical Info. Your serial number is
* the second item.
* 5) That's it, you're done.
* Copyright (C) 2013 Brian Steere <dianoga7@3dgo.net>
* Permission is hereby granted, free of charge, to any person obtaining a copy of this
* software and associated documentation files (the "Software"), to deal in the Software
* without restriction, including without limitation the rights to use, copy, modify,
* merge, publish, distribute, sublicense, and/or sell copies of the Software, and to
* permit persons to whom the Software is furnished to do so, subject to the following
* conditions: The above copyright notice and this permission notice shall be included
* in all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
* INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
* PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
* HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
* CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
* OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
preferences {
input("username", "text", title: "Username", description: "Your Nest username (usually an email address)")
input("password", "password", title: "Password", description: "Your Nest password")
input("serial", "text", title: "Serial #", description: "The serial number of your thermostat")
// for the UI
metadata {
definition (name: "Nest_test", namespace: "smartthings-users", author: "dianoga7@3dgo.net") {
capability "Polling"
capability "Relative Humidity Measurement"
capability "Thermostat"
capability "Temperature Measurement"
capability "Presence Sensor"
capability "Sensor"
capability "Switch"
command "away"
command "present"
command "setPresence"
command "heatingSetpointUp"
command "heatingSetpointDown"
command "coolingSetpointUp"
command "coolingSetpointDown"
command "setFahrenheit"
command "setCelsius"
attribute "temperatureUnit", "string"
simulator {
// TODO: define status and reply messages here
tiles {
standardTile("switch", "device.switch", width: 1, height: 1, canChangeIcon: true) {
state "off", label: '${name}', action: "present", icon: "st.switches.light.off", backgroundColor: "#ffffff", nextState: "on"
state "on", label: '${name}', action: "away", icon: "st.switches.light.on", backgroundColor: "#79b821", nextState: "off"
valueTile("temperature", "device.temperature", canChangeIcon: true, canChangeBackground:true) {
state("temperature", label: '${currentValue}°', backgroundColors: [
// Celsius Color Range
[value: 0, color: "#153591"],
[value: 7, color: "#1e9cbb"],
[value: 15, color: "#90d2a7"],
[value: 23, color: "#44b621"],
[value: 29, color: "#f1d801"],
[value: 33, color: "#d04e00"],
[value: 36, color: "#bc2323"],
// Fahrenheit Color Range
[value: 40, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 92, color: "#d04e00"],
[value: 96, color: "#bc2323"]
standardTile("thermostatMode", "device.thermostatMode", inactiveLabel: true, decoration: "flat") {
state("auto", action:"thermostat.off", icon: "st.thermostat.auto")
state("off", action:"thermostat.cool", icon: "st.thermostat.heating-cooling-off")
state("cool", action:"thermostat.heat", icon: "st.thermostat.cool")
state("heat", action:"thermostat.auto", icon: "st.thermostat.heat")
standardTile("thermostatFanMode", "device.thermostatFanMode", inactiveLabel: true, decoration: "flat") {
state "auto", action:"thermostat.fanOn", icon: "st.thermostat.fan-auto"
state "on", action:"thermostat.fanCirculate", icon: "st.thermostat.fan-on"
state "circulate", action:"thermostat.fanAuto", icon: "st.thermostat.fan-circulate"
valueTile("heatingSetpoint", "device.heatingSetpoint") {
state "default", label:'${currentValue}°', unit:"Heat", backgroundColor:"#bc2323"
valueTile("coolingSetpoint", "device.coolingSetpoint") {
state "default", label:'${currentValue}°', unit:"Cool", backgroundColor:"#1e9cbb"
standardTile("thermostatOperatingState", "device.thermostatOperatingState", inactiveLabel: false, decoration: "flat") {
state "idle", action:"polling.poll", label:'${name}', icon: "st.sonos.pause-icon"
state "cooling", action:"polling.poll", label:' ', icon: "st.thermostat.cooling", backgroundColor:"#1e9cbb"
state "heating", action:"polling.poll", label:' ', icon: "st.thermostat.heating", backgroundColor:"#bc2323"
state "fan only", action:"polling.poll", label:'${name}', icon: "st.Appliances.appliances11"
valueTile("humidity", "device.humidity", inactiveLabel: false) {
state "default", label:'${currentValue}%', unit:"Humidity"
standardTile("presence", "device.presence", inactiveLabel: false, decoration: "flat") {
state "present", label:'${name}', action:"away", icon: "st.Home.home2"
state "not present", label:'away', action:"present", icon: "st.Transportation.transportation5"
standardTile("refresh", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
state "default", action:"polling.poll", icon:"st.secondary.refresh"
standardTile("temperatureUnit", "device.temperatureUnit", canChangeIcon: false) {
state "fahrenheit", label: "°F", icon: "st.alarm.temperature.normal", action:"setCelsius"
state "celsius", label: "°C", icon: "st.alarm.temperature.normal", action:"setFahrenheit"
controlTile("heatSliderControl", "device.heatingSetpoint", "slider", height: 1, width: 2, inactiveLabel: false) {
state "setHeatingSetpoint", label:'Set temperature to', action:"thermostat.setHeatingSetpoint"
controlTile("coolSliderControl", "device.coolingSetpoint", "slider", height: 1, width: 2, inactiveLabel: false) {
state "setCoolingSetpoint", label:'Set temperature to', action:"thermostat.setCoolingSetpoint"
standardTile("heatingSetpointUp", "device.heatingSetpoint", canChangeIcon: false, inactiveLabel: false, decoration: "flat") {
state "heatingSetpointUp", label:' ', action:"heatingSetpointUp", icon:"st.thermostat.thermostat-up", backgroundColor:"#bc2323"
standardTile("heatingSetpointDown", "device.heatingSetpoint", canChangeIcon: false, inactiveLabel: false, decoration: "flat") {
state "heatingSetpointDown", label:' ', action:"heatingSetpointDown", icon:"st.thermostat.thermostat-down", backgroundColor:"#bc2323"
standardTile("coolingSetpointUp", "device.coolingSetpoint", canChangeIcon: false, inactiveLabel: false, decoration: "flat") {
state "coolingSetpointUp", label:' ', action:"coolingSetpointUp", icon:"st.thermostat.thermostat-up", backgroundColor:"#1e9cbb"
standardTile("coolingSetpointDown", "device.coolingSetpoint", canChangeIcon: false, inactiveLabel: false, decoration: "flat") {
state "coolingSetpointDown", label:' ', action:"coolingSetpointDown", icon:"st.thermostat.thermostat-down", backgroundColor:"#1e9cbb"
main(["switch", "temperature", "thermostatOperatingState", "humidity"])
// Slider or Buttons...
// To expose buttons, comment out the first detials line below and uncomment the second details line below.
// To expose sliders, uncomment the first details line below and comment out the second details line below.
details(["switch", "temperature", "thermostatOperatingState", "humidity", "thermostatMode", "thermostatFanMode", "presence", "heatingSetpoint", "heatSliderControl", "coolingSetpoint", "coolSliderControl", "temperatureUnit", "refresh"])
// details(["temperature", "thermostatOperatingState", "humidity", "thermostatMode", "thermostatFanMode", "presence", "heatingSetpointDown", "heatingSetpoint", "heatingSetpointUp", "coolingSetpointDown", "coolingSetpoint", "coolingSetpointUp", "temperatureUnit", "refresh"])
// handle commands
def setHeatingSetpoint(temp) {
def latestThermostatMode = device.latestState('thermostatMode')
def temperatureUnit = device.latestValue('temperatureUnit')
switch (temperatureUnit) {
case "celsius":
if (temp) {
if (temp < 9) {
temp = 9
if (temp > 32) {
temp = 32
if (latestThermostatMode.stringValue == 'auto') {
api('temperature', ['target_change_pending': true, 'target_temperature_low': temp]) {
sendEvent(name: 'heatingSetpoint', value: heatingSetpoint, unit: temperatureUnit, state: "heat")
} else if (latestThermostatMode.stringValue == 'heat') {
api('temperature', ['target_change_pending': true, 'target_temperature': temp]) {
break;
default:
if (temp) {
if (temp < 51) {
temp = 51
if (temp > 89) {
temp = 89
api('temperature', ['target_change_pending': true, 'target_temperature_low': fToC(temp)]) {
api('temperature', ['target_change_pending': true, 'target_temperature': fToC(temp)]) {
break;
poll()
def coolingSetpointUp(){
int newSetpoint = device.currentValue("coolingSetpoint") + 1
log.debug "Setting cool set point up to: ${newSetpoint}"
setCoolingSetpoint(newSetpoint)
def coolingSetpointDown(){
int newSetpoint = device.currentValue("coolingSetpoint") - 1
log.debug "Setting cool set point down to: ${newSetpoint}"
def setCoolingSetpoint(temp) {
case "celsius":
if (temp) {
if (temp < 9) {
temp = 9
if (temp > 32) {
temp = 32
api('temperature', ['target_change_pending': true, 'target_temperature_high': temp]) {
sendEvent(name: 'coolingSetpoint', value: coolingSetpoint, unit: temperatureUnit, state: "cool")
} else if (latestThermostatMode.stringValue == 'cool') {
break;
default:
if (temp) {
if (temp < 51) {
temp = 51
if (temp > 89) {
temp = 89
api('temperature', ['target_change_pending': true, 'target_temperature_high': fToC(temp)]) {
break;
poll()
def heatingSetpointUp(){
int newSetpoint = device.currentValue("heatingSetpoint") + 1
log.debug "Setting heat set point up to: ${newSetpoint}"
setHeatingSetpoint(newSetpoint)
def heatingSetpointDown(){
int newSetpoint = device.currentValue("heatingSetpoint") - 1
log.debug "Setting heat set point down to: ${newSetpoint}"
def setFahrenheit() {
def temperatureUnit = "fahrenheit"
log.debug "Setting temperatureUnit to: ${temperatureUnit}"
sendEvent(name: "temperatureUnit", value: temperatureUnit)
poll()
def setCelsius() {
def temperatureUnit = "celsius"
poll()
def off() {
setThermostatMode('off')
def heat() {
setThermostatMode('heat')
def emergencyHeat() {
def cool() {
setThermostatMode('cool')
def auto() {
setThermostatMode('range')
def setThermostatMode(mode) {
mode = mode == 'emergency heat'? 'heat' : mode
api('thermostat_mode', ['target_change_pending': true, 'target_temperature_type': mode]) {
mode = mode == 'range' ? 'auto' : mode
sendEvent(name: 'thermostatMode', value: mode)
poll()
def fanOn() {
setThermostatFanMode('on')
def fanAuto() {
setThermostatFanMode('auto')
def fanCirculate() {
setThermostatFanMode('circulate')
def setThermostatFanMode(mode) {
def modes = [
on: ['fan_mode': 'on'],
auto: ['fan_mode': 'auto'],
circulate: ['fan_mode': 'duty-cycle', 'fan_duty_cycle': 900]
api('fan_mode', modes.getAt(mode)) {
sendEvent(name: 'thermostatFanMode', value: mode)
poll()
def away() {
setPresence('away')
sendEvent(name: 'presence', value: 'not present')
def present() {
setPresence('present')
sendEvent(name: 'presence', value: 'present')
def setPresence(status) {
log.debug "Status: $status"
api('presence', ['away': status == 'away', 'away_timestamp': new Date().getTime(), 'away_setter': 0]) {
poll()
def poll() {
log.debug "Executing 'poll'"
api('status', []) {
data.device = it.data.device.getAt(settings.serial)
data.shared = it.data.shared.getAt(settings.serial)
data.structureId = it.data.link.getAt(settings.serial).structure.tokenize('.')[1]
data.structure = it.data.structure.getAt(data.structureId)
data.device.fan_mode = data.device.fan_mode == 'duty-cycle'? 'circulate' : data.device.fan_mode
data.structure.away = data.structure.away ? 'away' : 'present'
log.debug(data.shared)
def humidity = data.device.current_humidity
def temperatureType = data.shared.target_temperature_type
def fanMode = data.device.fan_mode
def heatingSetpoint = '--'
def coolingSetpoint = '--'
temperatureType = temperatureType == 'range' ? 'auto' : temperatureType
sendEvent(name: 'humidity', value: humidity)
sendEvent(name: 'thermostatFanMode', value: fanMode)
sendEvent(name: 'thermostatMode', value: temperatureType)
case "celsius":
def temperature = Math.round(data.shared.current_temperature)
def targetTemperature = Math.round(data.shared.target_temperature)
if (temperatureType == "cool") {
coolingSetpoint = targetTemperature
} else if (temperatureType == "heat") {
heatingSetpoint = targetTemperature
} else if (temperatureType == "auto") {
coolingSetpoint = Math.round(data.shared.target_temperature_high)
heatingSetpoint = Math.round(data.shared.target_temperature_low)
sendEvent(name: 'temperature', value: temperature, unit: temperatureUnit, state: temperatureType)
break;
default:
def temperature = Math.round(cToF(data.shared.current_temperature))
def targetTemperature = Math.round(cToF(data.shared.target_temperature))
coolingSetpoint = Math.round(cToF(data.shared.target_temperature_high))
heatingSetpoint = Math.round(cToF(data.shared.target_temperature_low))
break;
switch (device.latestValue('presence')) {
case "present":
if (data.structure.away == 'away') {
break;
case "not present":
if (data.structure.away == 'present') {
break;
if (data.shared.hvac_ac_state) {
sendEvent(name: 'thermostatOperatingState', value: "cooling")
} else if (data.shared.hvac_heater_state) {
sendEvent(name: 'thermostatOperatingState', value: "heating")
} else if (data.shared.hvac_fan_state) {
sendEvent(name: 'thermostatOperatingState', value: "fan only")
} else {
sendEvent(name: 'thermostatOperatingState', value: "idle")
def api(method, args = [], success = {}) {
if(!isLoggedIn()) {
log.debug "Need to login"
login(method, args, success)
return
def methods = [
'status': [uri: "/v2/mobile/${data.auth.user}", type: 'get'],
'fan_mode': [uri: "/v2/put/device.${settings.serial}", type: 'post'],
'thermostat_mode': [uri: "/v2/put/shared.${settings.serial}", type: 'post'],
'temperature': [uri: "/v2/put/shared.${settings.serial}", type: 'post'],
'presence': [uri: "/v2/put/structure.${data.structureId}", type: 'post']
def request = methods.getAt(method)
log.debug "Logged in"
doRequest(request.uri, args, request.type, success)
// Need to be logged in before this is called. So don't call this. Call api.
def doRequest(uri, args, type, success) {
log.debug "Calling $type : $uri : $args"
if(uri.charAt(0) == '/') {
uri = "${data.auth.urls.transport_url}${uri}"
def params = [
uri: uri,
headers: [
'X-nl-protocol-version': 1,
'X-nl-user-id': data.auth.userid,
'Authorization': "Basic ${data.auth.access_token}"
body: args
def postRequest = { response ->
if (response.getStatus() == 302) {
def locations = response.getHeaders("Location")
def location = locations[0].getValue()
log.debug "redirecting to ${location}"
doRequest(location, args, type, success)
} else {
success.call(response)
try {
if (type == 'post') {
httpPostJson(params, postRequest)
} else if (type == 'get') {
httpGet(params, postRequest)
} catch (Throwable e) {
login()
def login(method = null, args = [], success = {}) {
def params = [
uri: 'https://home.nest.com/user/login',
body: [username: settings.username, password: settings.password]
httpPost(params) {response ->
data.auth = response.data
data.auth.expires_in = Date.parse('EEE, dd-MMM-yyyy HH:mm:ss z', response.data.expires_in).getTime()
log.debug data.auth
api(method, args, success)
def isLoggedIn() {
if(!data.auth) {
log.debug "No data.auth"
return false
def now = new Date().getTime();
return data.auth.expires_in > now
def cToF(temp) {
return (temp * 1.8 + 32).toDouble()
def fToC(temp) {
return ((temp - 32) / 1.8).toDouble()
