Nest and homebridge
Hello guys
I have added my 2 nest thermostats and I can control them in the st app. Unfortunately I cannot see them in the homebridge app under thermostats. Is this normal?
F
Yes. The official nest integration doesn’t work with third party smartapps.
If you want to enjoy your Nest Tstat in all your preferred automation & smartapps, refer to this thread:
There are more commands & capabilities available, no throttling, and it’s feature-complete. It’s a groovy-based solution, so it’s compatible with all smartapps and automations under ST.
And, there is also a version for the Hubitat platform if you want to switch hub later.
Regards
Thanks for the answer
Will have a look
if you are looking to connect nest directly to homekit and avoid going through ST, there is starling home hub that offers a direct connection between nest cams, thermostats, protects, sensors to homekit. any feature in nest (nest account or google account) is available to homekit. i have this and enjoy it.
initial cost might be high to some ($89) but it is another option that is available for users to consider.
