Okay I have a question/ need some help.
After the last update I have one Aeotec Dimmer that works but doesn’t update status properly. Here is what the issue is.
If I manually turn on the light from the switch in the app it still shows it as being on but registers it as still being off. To actually turn it off from the app I have to turn it on (which it is already on) which then makes it show in the app that it is on and then press it again to turn it off. It then turns off and registers as off then. If i do everything via the app all statuses are correct.
Is there a way to reset this through the app ?
