Need ideas for multi-zone heat pump thermostats
I have a multi-zone heat pump HVAC system. One heat pump, three thermostats. Each thermostat controls dampers for different parts of the house.
Thermostats are Honeywell Vision Pro 8000 Wi-Fi. Honeywell TCC connects to SmartThings. All good. Except…
The thermostats act like they’re controlling 3 independent units. So they can be changed to conflicting settings, like heat in one zone and cool in another.
I need some ideas how I could build something in SmartThings that would let me change heat/cool/off mode on all three thermostats with a single tap.
I’m total noob to SmartThings programming but I’m a retired software developer. Just need a jump start to get going in the right direction.
US or U.K.?
And in either case, The following FAQ should give you a jumpstart (this is a clickable link) :sunglasses:
Hi, there is already a smartapp for that… It’s called ScheduleTstatZones and it’s designed to manage multiple thermostats with the concepts of rooms/zones/schedules…
You elect one thermostat as the master and you can specify all the slave thermostats in your rooms/zones to be controlled…, And you can control each of your zones with virtual zone devices (using a single tap).
I’ve just released a new version:
Refer to the ST community wiki for more details about the features and use cases supported (under the supported features and configuration sections):
http://thingsthataresmart.wiki/index.php?title=ScheduleTstatZones#Supported_Features
http://thingsthataresmart.wiki/index.php?title=ScheduleTstatZones#Configuration
P.S. The smartapp has many features and to do something similar with webcore would be impossible (more than 4500 lines of code).
Regards.
U.S.
