That’s correct. You will have control of both switch and ST. Wiring as follow.
Remove both wires from the wall switch.
Connect that two wires to the normally open set of contacts on the relay. (I use this set so that when the fireplace is off. The Aeon micro and relay are also off)
Connect the load of the Aeon to the relay coil terminal
Connect the wall switch to the switch terminals on the Aeon micro.
Connect line hot and neutral on your Aeon micro.
One more thing I would do just in case there is no 110v and you still want the fireplace on. Add another switch in parallel to the 2 low voltage wires. This will allow you to turn the fireplace on and also as an ST bypass. You can have a micro on/off switch hidden.
Edit : do this at your own risk of course. That said, there should be no problem but there is a very very low risk involve. Placing all this “beside” the gas valve… well high risk
If you put the relay in the line between the ignition module and the wall switch you are all set.
You can also put the relay in line with the switch if you are concerned about safety.
bamarayne
23
No, the 110 vac out put of the microcontroller will go to the high voltage side of the relay (source) the load side of the relay will go to the fireplace where the wall switch is currently installed.
The wall switch will be wired to the microcontroller on the wall switch circuit.
This allows the controller to run the fireplace via the relay. The controller is able to be controlled via ST and via the wall switch.
If I want to I can put in place a total kill switch, but I think that is overkill.
bamarayne
24
I appreciate all of your help… I finally was able to wrap my head around this thing. I’ll post updates once I get it installed.
Does that mean if there is no update in about 5 days. Watch the news for “don’t try this at home!” ?
Just kidding. Have fun and hope your other half will like it. I know my wife give up on me about HA since the X10 days
bamarayne
26
bamarayne
28
Yeah! Sorry I forgot to post an update. I got the aeon Microsoft to do this so I could still have use of the manual switch. I got everything ready to get the job figure and then the wife figured out what I was about to do…
So, long story short… There will be no locks and no fire controlled items in my house…
Soooo…my electrician simply installed a GE Z-Wave switch that I could use for lights (GE Z-Wave) and this worked just fine. Is there any safety concerns or anything like that? Ultimately, this seems so easy, but the significantly more complicated responses I have seen when looking at all this has scared me that the way I am doing it is wrong in some way.
That was going to be my suggestion. Everyone in this thread is trying to make it way too complicated. You just need to replace the low volt wall switch, with a smart switch. It doesn’t care what voltage is passing thru it. It simply opens and closes the circuit.
bamarayne
33
From what I understand from the reading is that for the vast majority of people with a wall switch there is no 120 vac in that box. There is only the low voltage line coming from the fireplace.
I know this is the issue that I have, thus making the conversion more complicated.
Forgot I got a voltage detector for xmas. Ok looks like one of the switches kills total power to the outlets below, while the second switch triggers the fireplace.
I am assuming the first switch is 120, and the second is low voltage.
This is a handy tool:
bamarayne
39
I have only one switch. It supplies a low voltage to a box below the fire place. Wires coming from that go to a gas on/off solenoid, the flameless igniter and other stuff.
