Could use some help figuring this out. I’m trying to use Echosistant with my Harmony hub. I only have one hub currently, but plan on having more in the future, so I’m trying to get it working via profiles. I’ve created a profile for my game room and assigned the hub to it. When I put in a test command via the Amazon skill tester, I see this in my SmartThings live logs:
9:26:14 AM: warn starting activity id = null, command = startActivity, lastActivity TV [Harmony Activity]
9:26:14 AM: debug received a control command: startActivity, deviceType: tv
9:26:14 AM: debug sendNotificationEvent sent to CoRE from GameRoom
9:26:14 AM: debug Message received from Parent with: (tts) = 'turn on the gameroom tv', (intent) = 'GameRoom', (childName) = 'GameRoom', current app version: R.0.3.4
9:26:14 AM: warn Delete messages = null
And then this:
9:26:35 AM: error Harmony - response has error: Failed to complete. Message was: Read timeout to home.myharmony.com/34.226.251.214:443 of 20000 ms
9:26:16 AM: debug getChildDevices(false), children=2
It’s only when Echosistant tries to do something with the Harmony hub that it fails. If I make a test piston in WebCoRE and send commands, it works. And if I manually control the hub via the SmartThings app it also works. I removed the hub and any activities from all automations, then removed the hub from SmartThings, and then added it back. No change.
Any idea what’s going on here?
