Hi there, 100% brand new in here - but have used Smartthings for the last 5 years. But havent had the need to move stuff around or add devices, for a hvile. Actually, last time was on the “Groovy ide”
for the last years i have had som “Aqara door/Windows magnets T1” but they have been online/offline (well more off than online)
But now we bought the new “Parasoll” from ikea and when connecting them was easy, but getting them to stay online is not possible (Just like the aqara units)
And im not able to thange the driver (they are a “Zigbee Thing” right now, and no possibility to change it to “Zigbee switch”) The Aqara T1 has both “Zigbee thing” and Zigbee Switch" as driver to choose from
In the new architecture, a device can only use an edge driver if the “fingerprint“ of that device is in a driver which has been downloaded to your hub.
When you can add a device to your Account but it only shows up as a “thing“ that means no drivers on your hub have that fingerprint.
IF you can find a custom driver that does have that fingerprint, you can download that to your hub, and then you will be able to change to that driver in the SmartThings app.
How do you find a custom driver with that fingerprint? You can try the quick browse lists:
If you can’t find one, then you can request that a community developer create one. There’s a thread for that. Make sure you read the first post carefully, because there is some information that you need to post with your request. No guarantees, but if it’s A popular device or uses commands similar to another device, you may get a response.
So once you have a matching edge driver on your hub, it’s pretty easy to switch. The hard part is the research you have to do to find one or get someone to create one.
As far as frequently going off-line, that’s a defect of the SmartThings platform, and happens with all kinds of devices for multiple reasons. In most cases, the device isn’t actually off-line: SmartThings is incorrectly marking it as being “off-line”.
Sometimes a different edge driver will fix that, sometimes there are other things you can do to fix it, and sometimes it’s just an annoyance caused by smartthings.
Usually, if you can find an edge driver with your Devices fingerprint, there will be discussion in the thread about that edge driver as to whether it fixes the off-line issue or not.
Separately, it sounds like you might also find the first part of the following FAQ helpful:
BTW: Aqara does offer a new option which might help the off-line issue.
Get their M2 hub or another one of their hubs that also works as a “matter bridge“, add the sensors to that hub, then add the hub to your SmartThings account as a “matter bridge“ and it will bring in many devices with it, although not all models are all features.
(The aqara e1 stick is an even less expensive option, but I haven’t tried that one myself.)
Since that doesn’t let SmartThings do its usual “off-line” calculations for the individual sensors, they are much less likely to get incorrectly marked off-line
I use this method myself with an Aqara Button, and it’s way more reliable. So just another possibility
The matter connection is still local, which is good.
Here’s aqara’s list of which of their devices can get to another platform (like smart things) through their matter bridge
If you do go that way, of course, you would need to re-create any automations using the device you switch over to the aqara hub so that might be too much effort. But I did just want to mention the option.
And IKEA does not yet have any matter bridges, so this option would only help with your aqara devices.
Actually i do have the E1 stick, but when i tried to connect the T1 switches, they dissapeared after a while - so it was pur back in its box… maybe i should try once again.
Thanks to yo too… i did DL that driver, and gave the T1 switch that driver, then it immediately looked different on the ST app… but it says it are waiting to update the status" - and is gone offline again…
Open the link
Acept the smartthings use conditions
Enroll your hub in the channel
search the zigbee Contact Mc driver and click in install.
Put your device in pairing mode
With App, add new device and use search nearby option.
New device will appears after some seconds or 1 minute
All custom edge drivers are installed in the same way.
follow the invitation link that you will get from the forum thread about the edge driver or maybe from the authors GitHub
subscribe to the channel
select the specific edge driver that you want downloaded to your hub. It will usually download in a few minutes, but there have been some reports that it’s taken up to a few hours
once it is on your hub, if you add a new device that matches that fingerprint, it will use it. Or you may be able to switch from one edge driver to another using the device details page in the SmartThings app, but that doesn’t always set the configuration correctly. so sometimes you just have to try it to see if it works.
Again, see the community FAQ for more details on the process.
This morning the Ikea Parasoll stays online, and the function shows On/Off - and works in a scene. The Batt status isnt there yet - but… i dont care… as long as the work
I have been soooo frustrated about this, and tried so many things. So on top of this, i didnt think of rebooting the hub after installing the driver.
I did that in the morning, and repaired (Reset, then connect) and bingo… they worked…
