I’m trying to install 2 zooz22 for my stairs light been trying for 2days yo no prevail. Bottom switch has a white, red, black(no volts) and a ground. Top light switch it has 2 white wires capped together. A red and a black capped together. Then a white, black(has volts), black(no volts) and a ground.
do you have a picture of the other box?
Take pictures before disconnecting anything.
Then map it out. Draw a picture, all switches, all lights. Circuit breaker number.
I don’t think (2) two Zooz dimmers are going to work together in 3way. One end must be a dumb mechanical toggle switch.
yeah, if those boxes are the same circuit you only need one Zooz switch and one dumb switch.
So it’s not possible to use 2 zooz switches?
no, but why would you want to?
To be clear, the GE Smart Switches and many other brands use a “Slave” switch that is compatible with their brand for 3-Way operation. So, in a 3-Way circuit, you would have one (1) Smart Switch and one (1) “Slave”.
With Zooz, you have one (1) Smart Switch and one regular old dumb switch (or dumb 3-way) that works with the Smart Switch.
I like GE method better because it avoids confusion but boy is the Zooz solution cheaper!
I really just didn’t want 2 different switches but I guess that clears up why I couldn’t get it to work I literally tried everything smh thanks for the info everyone!
once the face plate is on, the Zooz switch looks like a regular paddle switch with an LED light. Not too noticeable IMO.
Ik they look similar I split my fan and light and put it in a 2gang box 1 zooz one regular switch just wanted all the same I guess maybe one day
If it’s two separate circuits, then you will need two Zooz switches.
If any one else is searching for help on this topic this video should help out:
