ok, I found some more interesting logs after checking some of the issues in github (I learned about logcat). I got an error:
2023-12-03T23:07:01.291969386+00:00 TRACE Personal Tuya Devices - main Received event with handler zigbee
2023-12-03T23:07:01.293572918+00:00 INFO Personal Tuya Devices - main <ZigbeeDevice: [redacted] [0xB82B] (Alarm)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB82B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TuyaEF00 >, lqi: 0x88, rssi: -74, body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x27, ZCLCommandId: 0x01 >, < DataResponseClient || transid: 0x005A (BE), < DatapointSegment || dpid: 0x05, DatapointSegmentType: Enum, length: 0x0001 (BE), value: 0x64 > > > >
2023-12-03T23:07:01.332083319+00:00 TRACE Personal Tuya Devices - main Found ZigbeeMessageDispatcher handler in personal-tuya-devices -> GenericEF00 -> Model
2023-12-03T23:07:01.350746317+00:00 INFO Personal Tuya Devices - main Executing ZclClusterCommandHandler: cluster: TuyaEF00, command: DataResponseServer
2023-12-03T23:07:01.352080649+00:00 ERROR Personal Tuya Devices - main Alarm thread encountered error: [string "st/dispatcher.lua"]:233: Error encountered while processing event for <ZigbeeDevice: [redacted] [0xB82B] (Alarm)>:
arg1: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB82B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TuyaEF00 >, lqi: 0x88, rssi: -74, body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x27, ZCLCommandId: 0x01 >, < DataResponseClient || transid: 0x005A (BE), < DatapointSegment || dpid: 0x05, DatapointSegmentType: Enum, length: 0x0001 (BE), value: 0x64 > > > >
[string "st/capabilities/init.lua"]:226: Invalid value for Audio Volume.volume value: {value={}} error: Given table for value. Required type is a number
