Below is my updated code which needed quite a bit of changing up. This might help some folks who have my types of motors/shades as I do believe there are a lot of combinations and preferences out there. My blinds have 3 states:
Open (Where the slats are open)
Up (Where the blinds are lifted up)
Closed (Where the slats are closed (also MyStop setting).
Also, in my case, when the blinds are in the Up state, the setlevel is 100, when they are open, they are 0, and when they are closed, they are 50. I am not sure why they are like this, but this is how it was setup. I modified all of the status messages, icons, etc. as well. As a result, I modified all of the code that works for me and renamed tiles to make more sense. Another cool thing I did was use @bravenel’s Rule Machine to sync the status of my blinds. I typically use a routine to perform an action on “All Blinds” such as Close all Blinds. Well, previously, all of my blinds channels wouldn’t reflect what they actually were because I would only be making changes to All blinds. Now when I do that, Rule Machine waits a minute and sends the identical commands so they all have their status synced up. See screenshots below to see Blinds - Channel’s 1-4 all match “All Blinds” in the UP State.
This all works perfect now, and the only drawback is if someone changes the blinds with the Somfy remote, the status wouldn’t update in ST, but since I integrated this with Smartthings, there has been no need to ever use that remote between widgets and Alexa ![:slightly_smiling: :slightly_smiling:](https://emoji.discourse-cdn.com/google/slightly_smiling.png?v=9)
The code is below (sorry, never setup a Github repo before and didn’t have the time for it now).
* https://community.smartthings.com/t/my-somfy-smartthings-integration/13492
* Modified ERS 2/12/2016
* Changes:
* Shows if shades are in a my/stop state
* Multi-tile control
* Disable dual setLevel operations
metadata {
definition (name: "Somfy Z-Wave Shades Multi tile", namespace: "ash", author: "Ash Raj") {
capability "Switch Level"
capability "Switch"
capability "Window Shade"
//capability "Polling"
capability "Refresh"
capability "Actuator"
command "levelOpenClose"
fingerprint deviceId: "0x1105", inClusters: "0x2C, 0x72, 0x26, 0x20, 0x25, 0x2B, 0x86"
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
status "09%": "command: 2003, payload: 09"
status "10%": "command: 2003, payload: 0A"
status "33%": "command: 2003, payload: 21"
status "66%": "command: 2003, payload: 42"
status "99%": "command: 2003, payload: 63"
// reply messages
reply "2001FF,delay 5000,2602": "command: 2603, payload: FF"
reply "200100,delay 5000,2602": "command: 2603, payload: 00"
reply "200119,delay 5000,2602": "command: 2603, payload: 19"
reply "200132,delay 5000,2602": "command: 2603, payload: 32"
reply "20014B,delay 5000,2602": "command: 2603, payload: 4B"
reply "200163,delay 5000,2602": "command: 2603, payload: 63"
tiles(scale: 2) {
multiAttributeTile(name:"shade", type: "lighting", width: 6, height: 4) {
tileAttribute("device.windowShade", key: "PRIMARY_CONTROL") {
attributeState("unknown", label:'${name}', action:"refresh.refresh", icon:"st.doors.garage.garage-open", backgroundColor:"#ffa81e")
attributeState("up", label:'Up', action:"open", icon:"st.doors.garage.garage-open", backgroundColor:"#ffffff", nextState: "opening")
attributeState("open", label:'Open', action:"close", icon:"st.doors.garage.garage-open", backgroundColor:"#ffcc33", nextState: "closing")
attributeState("closed", label:'Closed', action:"presetPosition", icon:"st.doors.garage.garage-closed", backgroundColor:"#bbbbdd")
attributeState("closing", label:'${name}', action:"presetPosition", icon:"st.doors.garage.garage-closing", backgroundColor:"#bbbbdd")
attributeState("opening", label:'${name}', action:"presetPosition", icon:"st.doors.garage.garage-opening", backgroundColor:"#ffcc33")
tileAttribute ("device.level", key: "SLIDER_CONTROL") {
attributeState("level", action:"switch level.setLevel")
tileAttribute ("device.speedLevel", key: "VALUE_CONTROL") {
attributeState("level", action: "levelOpenClose")
standardTile("switchmain", "device.switch", width: 2, height: 2) {
state "on", label:'Up', action:"switch.off", icon:"st.doors.garage.garage-open", backgroundColor:"#ffffff"
state "off", label:'Open', action:"switch.on", icon:"st.doors.garage.garage-closed", backgroundColor:"#ffcc33"
state "default", label:'closed', action:"presetPosition", icon:"st.doors.garage.garage-open", backgroundColor:"#bbbbdd"
standardTile("on", "device.switch", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state("on", label:'Lift Up', action:"switch.on", icon:"st.doors.garage.garage-opening")
standardTile("off", "device.switch", width: 3, height: 2, inactiveLabel: false, decoration: "flat") {
state("off", label:'Tilt Open or Bring Down ', action:"switch.off", icon:"st.doors.garage.garage-closing")
standardTile("stop", "device.level", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state("default", label:'Close or Stop', action:"switch level.setLevel", icon:"st.Transportation.transportation14")
controlTile("levelSliderControl", "device.level", "slider", height: 1, width: 3, inactiveLabel: false) {
state("level", action:"switch level.setLevel")
standardTile("refresh", "command.refresh", width:2, height:2, inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
// Poll provides data, but the ZRTSII does not provide accurate status
// standardTile("poll", "command.poll", width:2, height:2, inactiveLabel: false, decoration: "flat") {
// state "default", label:'poll', action:"poll", icon:"st.secondary.poll"
main(["switchmain"])
details(["shade", "on", "off", "stop"])
description
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x26: 1, 0x70: 1])
log.debug "Parsed ${description} to ${cmd}"
if (cmd) {
result = zwaveEvent(cmd)
log.debug "zwaveEvent( ${cmd} ) returned ${result.inspect()}"
} else {
log.debug "Non-parsed event: ${description}"
return result
def levelOpenClose(value) {
log.trace "levelOpenClose called with value $value"
if (value) {
on()
} else {
off()
// Somfy ZRTSII does not report accurate status for the device.
// This device handler maintains an internal view of device status based on last command
// reissuing a command to the shade (up, down, my (when stopped)) does not move the shade if it is already in that position
// My/stop command does different actions depending if the shade is idle (go to MY position) or moving (stop)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd)
def result = []
log.trace "Basic report cmd.value: ${cmd.value}"
if (cmd.value == 0) {
//result << createEvent(name: "switch", value: "off")
log.debug "Reported state is closed; device is ${device.latestValue('switch')} ${device.latestValue('level')} "
} else if (cmd.value == 0xFF) {
//result << createEvent(name: "switch", value: "on")
log.debug "Reported state is open; device is ${device.latestValue('switch')} ${device.latestValue('level')} "
} else { // This has never happend
//result << createEvent(name: "switch", value: "default")
log.debug "Reported state is neither open or closed; device is ${device.latestValue('switch')} ${device.latestValue('level')} "
return result
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
def result = []
log.debug "SwitchBinaryReport cmd.value: ${cmd.value}"
} else { // this has never happened
//result << createEvent(name:"switch", value: cmd.value ? "on" : "off")
//result << createEvent(name: "level",value: cmd.value, unit:"%",
//descriptionText:"${device.displayName} dimmed ${cmd.value==255 ? 100 : cmd.value}%")
return result
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelReport cmd)
def result = []
log.trace "SwitchMultilevelReport cmd.value: ${cmd.value}"
} else {
return result
def on() {
int level = 100
log.trace "on() treated as open()"
setLevel(level)
def off() {
int level = 0
log.trace "off() treated as close()"
setLevel(level)
def setLevel() {
log.trace "setLevel() treated as my/stop"
setLevel(50)
def open() {
log.trace "open()"
on()
def close() {
log.trace "close()"
off()
def presetPosition() {
log.trace "presetPosition() treated as my/stop"
setLevel()
def refresh() {
log.trace "refresh()"
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
zwave.switchMultilevelV1.switchMultilevelGet().format(),
//zwave.meterV2.meterGet(scale: 0).format(), // get kWh
//zwave.meterV2.meterGet(scale: 2).format(), // get Watts
//zwave.sensorMultilevelV1.sensorMultilevelGet().format(),
//zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType:1, scale:1).format(), // get temp in Fahrenheit
//zwave.batteryV1.batteryGet().format(),
zwave.basicV1.basicGet().format(),
], 3000)
// If you add the Polling capability to your device type, this command
// will be called approximately every 5 minutes to check the device's state
// zrtsII does not provide accurate status of shade position
//def poll() {
// log.trace "Poll"
// zwave.basicV1.basicGet().format()
def setLevel(level) {
log.trace "setLevel(level) {$level}"
log.debug "level.inspect " + level.inspect()
int newlevel = level
if (level > null) {
sendEvent(name: "level", value: level)
if (level >= 75) {
sendEvent(name: "windowShade", value: "lifting up")
newlevel = 100
delayBetween([
zwave.switchMultilevelV1.switchMultilevelSet(value: 0xFF).format(),
sendEvent(name: "switch", value: "on"),
sendEvent(name: "windowShade", value: "up")
], 5000)
} else if (level <= 25) {
sendEvent(name: "windowShade", value: "opening")
newlevel = 0
delayBetween([
zwave.switchMultilevelV1.switchMultilevelSet(value: 0x00).format(),
sendEvent(name: "switch", value: "off"),
sendEvent(name: "windowShade", value: "open")
], 5000)
} else {
delayBetween([
zwave.switchMultilevelV1.switchMultilevelStopLevelChange().format(),
sendEvent(name: "switch", value: "default"),
sendEvent(name: "windowShade", value: "closed")
], 5000)
// this code below causes commands not be sent/received by the Somfy ZRTSII - assume delayBetween is asynchronous...
//log.trace("finished level adjust")
//if (newlevel != level) {
//log.trace("finished level adjust1")
//delayBetween([
//sendEvent(name: "level", value: newlevel)
//], 1000)
// this appears to never be called
//def setLevel(level, duration) {
// log.trace "setLevel(level, duration) {$level} ${duration}"
// setLevel(level)
// return
