When I deployed AWS Lambda smart apps in developer workspace, it is showing up as Label on the smartthings app. Even the Smart Lighting App is showing as Label.
I am seeing the same thing, so, it might be an issue in general. Did it start to happen to you after the AWS Lambda SmartApp?
I already had one deployed, so, it might be the same reason.
Edit: It might not be. I just unlisted it and see the same…I’ll report it to the engineering team.
Those issues were on iOS only as well? That’s interesting. I didn’t have issues installing a SmartApp on Android earlier today, so, this one is only on iOS…
@nayelyz
It does show Label even without Lambda Smartapp.
Even so, Smart Lighting can be installed. But my custom smartapp is not able to be installed at all. AWS Lambda is not receiving any calls at all for installation.
Hi @ph007 , I’m Alejandro from the dev support team
We created a report about your problem, the corresponding team is working on it, unfortunately, we don’t have updates yet, sorry. As soon as they share their feedback with us, we will inform you.
The SmartApps aren’t installed on the hub, they run on the servers, for this reason maybe the problem is not the hub, Can you share the code of the smart app to check it? and What is the region where the Lambda is?
