If I remember correctly, you are an iOS user, correct?
Unfortunately, this is a bit easier for Android (using SharpTools, Tasker, and AutoLocation).
IFTTT with a virtual switch should work just fine since this isn’t something that is critically time sensitive (meaning if it fires with a 5-10 second delay due to IFTTT, that won’t make or break your automation).
bamarayne
#3
The a look at IFTTT. I’m not sure about iOS, but there is an android channel that works with location. When your phone arrives somewhere IFTTT can trigger a switch in ST, which can run your automation.
