I have a multi sensor on my garage door that would tell me if it was open or closed. Prior to my upgrade to v2, it worked fine. Now it says open all the time. How can I fix this?
You need to go into IDE and change the device type to Smartsense Garage Door Sensor. Have had the same problem, but once I made the change, the status of my garage door is now being reported correctly.
