There are tons of threads here about motorized shades. The most popular are probably the Bali shades with Somfy motors. Latest gen support zwave natively.
Fortunately, the community-created wiki has quick browse lists for just this purpose. Check the Project Reports section for “shades and window coverings.” (Lots of info there. When you get the results, in particular check the “Graber” thread for one very recent offering.)
The main issue with the DIY solution is making sure that it’s safe. Automated Window coverings can severely injure children or pets, or even worse. The issue isn’t getting one to move. The issue is getting it to stop when it should, particularly when an obstruction is encountered.
Yes, they are just Bali Autoview cellular from Home Depot. We didn’t get the room darkening ones as our application we don’t need / want those. They are in our family room behind furniture, so manual shades were a pain. We really like the light so when we have them down a ton of light still comes in but prevents neighbors from seeing in when we don’t want them to.
They each come with a 2 button remote which I wrote a DH for to be used for other things. I have 5 of them. One of the best remotes I’ve tried.
Thanks for sharing this. I was just comparing these with Graber and the manufacturer seems to be common for the z-wave portion, it is just re-branded. Also, both use Somfy motors. Bali seems to be a lot cheaper though.
Bought mine, Bali Roller, at Costco and love them. Works perfect with ST. Make sure you don’t get the old ones with the RTS connector to Z wave module. Some stores still carry them. I think Lowes is one of them.
Thanks for posting your Device Handler Type, much appreciated. I have it installed and it’s working for almost all of the Bali motorized blinds I installed. I have the newer model with the Zwave motors.
On my patio door I have a giant blind that’s 8’ tall. On that one for some reason I keep getting disconnected. For example, I can pair it and operate it so that it goes up. But if it’s left in the up/on position for more than a minute I can’t control it on the app anymore. This happens with the generic zwave switch device handler too. I can reset it by manually hitting opening the blind so that it goes back to the off position.
Would you have any guesses as to what might be causing it?
So I opened the blinds and you can see at 9:13:39 it shows that it stopped. Then at 9:14:26 I tried to set it at 80% and it wouldn’t budge. I tried to set it at 0 to close it and nothing either…
No clue why it doesn’t respond after it’s in the up position.
Both are manufactured by the same company. Graber is their premium line of products while Bali is their Big Box Store brand. Slight difference in quality, but that’s about it.
