Sorry not sure if this is the correct forum for this?
Is it possible for me to setup Alexa routines using the temp sensors built into smarthings motion, multipurpose sensors?
I see them but they only allow me to use the motion part of the sensor in a routine.
Is this possible?
rontalley
(Ron Talley)
2
Yes, you can create a virtual thermostat and use the multipurpose sensor as the temp sensor. Then Alexa will be able to read the temp.
Ah, thanks very much I’ll check it out.
