I integrated my Smartthings with Alexa recently and found the multi-purpose sensor does not come through. I was wanting to be able to ask Alexa for temperature info from the multi-purpose sensor.
I use this app. You basically tie the sensor to the Virtual Thermostat and then enable the Virtual Thermostat in the Alexa App. From there, you can ask what the temperature is. Pretty simple.
Hi, I created a “virtual thermostat by Smartthings” with the ‘built in’ SmartApp (under “Climate control”) within the Smartthings app. I used a Multipurpose sensor as the temperature device. Once i had created it I tried to let Alexa know about it through the Alex smartapp within Smartthings. It does not show up as an option under Thermostats. Any ideas?
You are responding to a thread which is two years old, and a lot has changed in that time. In particular, Alexa does many more things out of the box with smartthings sensors than it used to. So now you may not need to Use AskAlexa depending on exactly what you want to do.
That said, AskAlexa is a community-developed project that uses an Amazon developers account to get you access to many additional features. They have a detailed article in the community – created wiki that explains everything. Very powerful, but set up is also fairly complicated, so you might want to just check and see if what you want to do is already available through the official features.
