So here’s my issue… I’m looking to replace several light fixtures with the Monoprice single relay device. The problem is that several of my lights are wired so that the power comes in to the light itself and then proceeds on to the switch. Here’s what I mean: http://www.buildmyowncabin.com/electrical/wiring-switch-power-into-light.html
When you wire the light like this it seems to “remove” the neutral. Can anybody provide insight? Is there still a way to write the relay in there? TIA
Your relay must be at the light fixture box for your wiring configuration and here’s the link to the manual of the monoprice relay. Hope that will clear up a little.
