Does anyone have a picture of their wiring for the Monoprice 11990 Dual Relay? I can’t seem to wrap my head around it. Basic install here; no 3-way or anything. Currently the switch looks like:
Source (black)->Bottom of switch
Black (to light)->Top of switch
Neutrals tied together in the box
Thanks.
tgauchat
2
Are you using it as single or dual? (I only have personal experience with the single).
Do you have the latest user manual (sometimes the web version is more up to date)?
I basically have it figured out, but what confuses me is the diagram showing the Load going to the Neutral. It appears my load is on the Black wire, and the Neutral is just tied through. So, will it work not using the Neutral for the Load? I will have Live and Neutral into the Relay.
Hope this makes sense.
tgauchat
5
It makes more sense with a diagram; … and I caution that the diagram included in the package may not be the correct diagram.
I got it, just like I figured. I will try to put together a little diagram in the next couple days to help others out. This relay with the Device/SmartApp others put together work great!
Okay, so I took some time to put together a better wiring diagram for anyone else that is confused/needs help. Hopefully this will be useful. Please let me know if you have any comments/questions.
Thank you for this. I tried putting one in , but the more I looked at the manual that came with it the more I got confused.
Follow up question: I have a box with two switched, but two separate Hots from the panel (Live). Is there a way to wire a module with two hots, but do they HAVE to be from one source? I assume from your diagram two sources are a no go, but thought I would ask.
