To the best of my knowledge there are NO Edge Drivers for Tuya WiFi devices. There is only the official c2c (cloud to cloud) integration which is pretty limited in what is included.
In the Tuya or SmartLife App open the device tile, click on 3 dots or pencil in the upper right corner and the page that opens should list a 3rd Party Supported section. If SmartThings is not listed or the section is missing you are out of luck. There are work arounds for bulbs, switch, plugs, garage doors and others on/off devices. But there are not many for sensors and thermostats.
Hi. Thanks for the reply. Smartlife does work with Smartthings and all my other devices from Smartlife do sync automatically except the moes wifi Thermostats
Am just wondering when the app gets synced, then all the devices should be shown
How come Thermostats are not showing in Smartthings app.
I tried deleting and repairing the integration between 2 apps as well but my Thermostats are not showing in Smartthings app
Tuya only provides SmartThings integration if the vendor (Moes in this case) pays for it.
And the integrated devices are typically simple on/off devices like bulbs, plugs and switches.
Did you check in the Tuya app as suggested above to see if SmartThings integration is available for your device? If it is not listed there is not much you can do.
You might be able to get some partial integration with ST via Alexa, Google Home, or IFTTT if they are listed as 3rd party controllers. So what do you want to do with the thermostat in ST?
